How to use Updater Override?
  • How to use Updater Override?
    Looking for some clarification on how to use the updater_override.txt. Perhaps I am missing the obvious.
    The file updater_override.txt goes in the HomeSeer root directory. Then the .zip file goes in \HomeSeer HS3\Updates3\Zips. Then click on Update Listing under Plug-in’s>Manage and you will be offered to install or update. If updater_override.txt remains after the installation, remove it so that you get back to the normal updater.
    Since this plug-in is now in the updater (under Analog and Digital Input/Output Device), you shouldn’t need updater_override.txt.
    Randy Prade
    Aurora, CO
    Prades.net
      What Randy said but if this is for the Arduino plugin there is no zip files as they are all downloaded, so just put the updater override in the HS root and click update listings in the updater to get the update.
      Greig.
      Sent from my SM-G950F using Tapatalk
      Scripts =
      Various
        Greig.
        I thought that since your plug-in is in the HS updater now the updater_override.txt was no longer needed.
        Randy Prade
        Aurora, CO
        Prades.net
