One wire temp problems over 300 degrees
  • One wire temp problems over 300 degrees
    I am using a Thermocouple Amplifier with 1-Wire Breakout Board - MAX31850K with a thermocouple work great till the temp goes over 300 than I get errors
    Any ideas why this happens
    Are you using the normal or API sketch?
    Greig.
    Sent from my SM-G950F using Tapatalk
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      the normal
        debug log
        Attracted is a copy of Arduino debug log
        Device id is 930
        Address is 83626ACE12F420A
        I am using this to monitor a coal stove any help would be greatly applicated.
          Yes the plugin uses the values of if more that -100C and less than 150C then error as most one wire sensors only have a range of -55C to 125C. . I could build something into the plugin to set the max temp from a sensor before an error but I have lots of other work to do first.
          I suggest using the API to get the values you are looking for.
          Greig.
          Scripts =
          Various
