Is it okay to change below the line that says Don't Change?
  • Is it okay to change below the line that says Don't Change?
    In the boiler plate script for API mode, is it okay to change Ethernet.h to Ethernet2.h and EthernetUdp.h to EthernetUdp2.h in the include statements below to accommodate a w5500 series Ethernet shield instead of a w5100?
    HTML Code:
    //************Do not change anything after Here*****************
    #define ISIP 1
    #define BoardType 1
    const byte BoardAdd = 1;
    #include <EEPROM.h>
    #if BoardType == 3
    #include <ESP8266WiFi.h>
    #include <WiFiUdp.h>
    #include <ESP8266mDNS.h>
    #include <ArduinoOTA.h>
    char ssid[] = "TALKTALK-C94ECC";
    char pass[] = "YNH9EXWA";
    #else
    #include <SPI.h>
    #include <Ethernet.h>
    #include <EthernetUdp.h>
    #endif
    Looking for some guidance on what to do when my sketch contains an #include that conflicts with the stock #include.
      It might and it might not. Depends on if the same function names and parameters are the same in each.
      Change the include names and try and compile and link. If everything resolves it would be worth testing.
        I posted this -
        https://forums.homeseer.com/showthread.php?t=193745
        I changed to the W5100 boards and I'm having trouble getting them to power up on a restart. It is a power supply issue from what I'm reading, but is keeping me from deploying the hardware in remote locations. So I'd be interested in your experimenting.
        Barry
          FYI if you are using the Beta version the is a check box called Ethernet Shield V2 that is for this. If it is checked then the sketch is downloaded you will see the changes.
          Greig.
          Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
          Scripts =
          Various
