Contacting HomeSeer This Week
See more
See less
Trying to understand the Blink function.
  • Trying to understand the Blink function.
    What version of the plugin are you using?
    Blink will make the led blink on and off continually but flash should just perform the on and off once.
    If the board is disconnected from the plugin it will reset the board after 3mi to try and fix the connection.
    If you need the board to continue flashing you would need to use the API and put the flash in the section that runs when disconnected.
    Greig.
    Sent from my SM-G950F using Tapatalk
    Scripts =
    Various
      I am using version 1.0.0.146.
      When I disconnect the Ethernet connection and set up HS3 to use the serial connection (COM6) instead, the Blink function seems to continue and the Blink rate is steady.
      Thanks for the info. Where in the sketch calls for the reconnect after 3 mins? Will it also do this for serial connection?
        No it will not do this on Serial. I would need to check when the code was added to do this but it is in the Beta.
        Greig.
        Scripts =
        Various
