Contacting HomeSeer This Week
See more
See less
Relays turning on and off
  • Relays turning on and off
    I'm new with this Plug-in and got my board working using WiFi. I'm using the Arduino Beta with a WEMO D1 R1 to control a relay (as a test). The problem I have is every couple of minutes the relay toggles off and on. It seems to happen whenever the board updates. My main question is why this is happening and why does the board keep reconnecting and updating? I'm sure this is not normal. I would think that once it is connected, it would stay connected.
    by what you have posted from your log, it is updating the watts being used. I see nowhere in your log where the relay is toggling off/on.
      The watts are from a fibaro switch not the arduino. Every time it updates the pins, the relay goes off then bacl on.
        You are correct that this should not happen. Where are you powering the relay from? If you power it directly from the board it might be pulling down the power enough to reset the board and the relay.
        Greig.
        Scripts =
        Various
          opps my bad...not enough coffee hahaha
            Greig.
            Yes, powered from the board. Heading down to the workshop to power it from a wall wart and see what happens.
              Well, that didn't work, relay still switching on and off. Have another brand new board, will try that one tonight.
                If you can not get it to work I have a D1 somewhere I can try.
                If you capture a debug log and send it to me I might see better what is going on.
                Greig.
                Sent from my SM-G950F using Tapatalk
                Scripts =
                Various
                  Solved! Opened up a new board and set it up as board #2 and BAM, it works. What are the chances that the first board I try (being new at this) turns out to be bad! That would make anyone question their own ability!
                  Thanks for the help.
