Pass PC time to Arduino?
  • Pass PC time to Arduino?
    Rather than use an RTC, can the PC time be passed to the Arduino via Ethernet?
    Not necessarily "from" your PC, but look at the time.h library, you can use configTime to sync with an NTP source.
    Z
      For what reason? Are you using the API?
      Sent from my SM-G950F using Tapatalk
      Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
      Scripts =
      Various
        Hi, I need same functionality. I am using API mode for one Arduino and real time is necessary in case of disconnection from HS3 (Not frequently but is is critical). I am not sure how to use NTP, as Ethernet Shield is used by the plug-in... Also thinking about the option of passing current time from the plug-in into the Arduino.
        Sent from my ONEPLUS A5000 using Tapatalk
