Fatal error can't proceed pls help
  • Fatal error can't proceed pls help
    I'm getting this error and can't proceed further. All libraries are downloaded and installed properly. Pls help. I'm very excited about this plug-in and want to try it asap.
    C:\Program Files (x86)\Arduino\libraries\SoftPWM/SoftPWM_timer.h:22:20: fatal error: avr/io.h: No such file or directory
    This is a library that is not installed correctly. Make sure you replace all installed libraries with the plugin libraries.
    Greig.
    Scripts =
    Various
      Hi Greig,
      Thanks for the prompt response. I can do that, however I just noticed that you mandate the use of Arduino IDE 1.6.8 while I have the latest version 1.8.5. Could this be the reason ? If yes than it is a problem for me as I do have multiple other projects going that use IDE 1.8.5. I don't want to make this one working while losing everything else. I tried to install IDE 1.6.8 in a separate directory but it won't let me. It asks me to remove IDE 1.8.5 first. Can you suggest a resolution to this problem? Thanks.
      RISquare
        You could update to the Beta version of the plugin which will run on 1.8.1 of the IDE. The beta is stable and has many new features.
        Scripts =
        Various
          I have been running the beta 1.0.0.147 using the 1.8.1 IDE and it is wonderfully stable and reliable.
          Randy Prade
          Aurora, CO
          Prades.net
            Thanks for the support guys. I did upgrade the plug-in to the latest version. I did download the homeseerboard1.ino file as well as the zipped libraries. I have stuff in my \library folder already so I renamed it to \library1 and created a new \library folder for the purpose of this plug-in that I'm very interested in making working. I unzipped the library file into this newly created empty folder \library. Now I'm getting another compilation error.
            C:\Users\ivan\Documents\Arduino\HomeseerBoard1\HomeseerBoard 1.ino:49:22: fatal error: Ethernet.h: No such file or directory
            my board is Lolin32 based on ESP32 MCU.
Name:	Screenshot (101).png
                ... above is the content of the Arduino/libraries folder containing only files downloaded from HS3 Arduino plug-in beta. Notably last two files show old date while the top three files show the current date and hour of the unzip of the downloaded Libraries zip file. Yet I'm getting this compiling error
                  ... latest info ... after judging the error messages by their names I've ventured to add Ethernet and Servo libraries to /libraries folder. Now I went full circle and got back to the original error message
                    You need to leave the default libraries in the folder and when you add the plugin supplied libraries into the folder you need to overwrite any that are conflicting so you have both but the correct ones for the plugin.
                    I think you were closest when you had the Ethernet.h: error as this is supplied with the IDE and should be there.
                    Greig.
                    Scripts =
                    Various
                      Greig, thanks for the suggestion. I think I've done that but let me do it again just to be sure. I'll report soon.
                        No luck still getting the dreaded message
                        C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:26:20: fatal error: avr/io.h: No such file or directory
                          ... here is how does the combined library folder look. Click image for larger version
Name:	Screenshot (102).png
                            I see you are using the main Libraries folder are there any in the \Documents\Arduino folder as duplicates could cause problems too.
                            Scripts =
                            Various
                              Risquare
                              I set up a "portable installation" purely for HS and I have another one for Tasmota firmware....that way you keep it all seperate
                              HS 2.2.0.11
