Very strange, last day I discovered on log this error:
Checking on arduino setup page, any 1-wire reference setup are missing:
In my case, 1-wire connected to pin N°4
As you can see, pin 4 is not available on pin Add list (because used for 1-wire), but in the previous picture pin4 is not displayed.
Same problem to my friend.
HS3 last version on raspberry (raspbian) and plugin version .148 (same problem with .147 version).
ago-22 12:03:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 12:02:59 Arduino Plugin Error = Exception in BuildOneWirePins : String was not recognized as a valid Boolean.
ago-22 12:02:58 Arduino Plugin Error = Rom = temperatura_calorifero_sala has an time out error
ago-22 12:02:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 12:02:36 Arduino Plugin Error = Exception in Rom Timer Tick : Object reference not set to an instance of an object
ago-22 12:02:15 Arduino Plugin Error = Exception in Rom Timer Tick : Object reference not set to an instance of an object
ago-22 12:01:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 12:00:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 11:59:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 11:58:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 11:57:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
ago-22 11:56:37 HSTouch Server Warning Exception on String Change callback: Value was either too large or too small for an Int32.
