Ethernet connection errors
  • Ethernet connection errors
    Hi,
    I am currently using a Uno board with the Ethernet shield. I just noticed that the logs are showing periodic Ethernet disconnects, about 4 /day. The connection seems to come right back up. I can't see any obvious reason for this and short of replacing the shield, any thoughts as to how I could troubleshoot this?
    Thanks, Doug
    Current Date/Time: 8/25/2018 11:43:59 AM
    HomeSeer Version: HS3 Standard Edition 3.0.0.435
    Operating System: Microsoft Windows 10 Home - Work Station
    System Uptime: 3 Days 21 Hours 52 Minutes 17 Seconds
    IP Address: 192.168.140.68
    Number of Devices: 200
    Number of Events: 180
    Available Threads: 400
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed: Windows Defender AVG Antivirus
    Enabled Plug-Ins
    1.0.0.142: Arduino Plugin
    3.1.3.33206: Blue-Iris
    2.0.0.1: EZFlora
    3.0.6.3: Insteon Thermostat
    3.0.6.23: Insteon
    3.0.1.109: PHLocation
    1.0.0.7: Restart
    3.1.0.24: Sonos
    Sadly the only thing I could suggest is the shield. Varying success with clone ethernet board from Ebay and Aliexpress. I went to the latest BETA version and haev still noticed 2 of my MEGA boards "occasionally" reset where the 3rd never has issues. I've never been able to get to the bottom of it
    Pete
    HS 2.2.0.11
      Thanks Pete,
      Would you happen to know if I change just the ethernet board, would I have to download the sketch again?
      Doug
        Originally posted by field888 View Post
        Thanks Pete,
        Doug
        I’m not Pete
        You can change the shield without uploading a new sketch, as long as they are the same version. The V2 shield uses a different library than the original.
        Randy Prade
        Aurora, CO
        Prades.net
          Thanks Randy,
          I'll give it a go, hope that's the only problem.
            I will add that I did see random connection issues when I was using clone (not genuine) Arduino boards and shields. I would always recommend spending the money on genuine Arduino boards and Ethernet shields. I have 4 genuine Arduino Megas with Arduino shields and rarely see a disconnect. When I had clone Megas I saw a lot of disconnects and had a couple of output pin failures. I had two of 4 clone shields fail within a month. The first failed to connect and the second would drop a connection every few hours. I switched to all genuine in 2015.
            Randy Prade
            Aurora, CO
            Prades.net
