Hi folks - I'm new to Arduino and planning my first project - would love some help validating my approach and filling in some gaps.
I have a Heat N Glo fireplace that only works with their RF remote (ugh!). I want to be able to control it via home automation (duh .
I found this project: https://github.com/milksteakmatt/Ardufuego where someone created an Arduino RF setup to send the Heat N Glo commands (he reverse engineered the protocol).
So my plan is to replicate what he did, then hook it to HomeSeer. Here's my rough plan:
A. Use a Wifi shield for board #2 (haven't researched that yet)
B. Combine it all into one board by putting the ethernet/wifi shield onto the board from #1. Not sure what that means in terms of configuring via the plugin.
Would love any and all suggestions! Also tutorials (or things to keep in mind) would be great! Thanks for the support .
- Build what he did, then test that it works to control the fire place
- Buy another Arduino board and an Ethernet shield
- Download the arduino plugin for Homeseer, and configure it to address what I've built in #2
- Hook a wire from a pin in board #2 to a pin in board #1
- Use the plugin to write a sketch to board #2 that creates a device for each fire place setting (e.g. flame height, fan speed, on/off), and then .... I think ....paste my code into the plugin (so it auto generates it into a sketch). The code would send a signal over the wire I describe in #4 to send the proper RF command.
