SendToHs () String
    SendToHs () String
    Hi
    Just trying out this plugin and have it setup and running.
    I need to send data to HS as a string and I have tried using the SendToHs (1140,content), where content is a variable that holds data in the format 57-B5-B2-1C
    When I try this, the sketch wont compile which I assume is because the data being send back is defined as a float, Int or Long.
    Is there a way to send string data back to a HS Device?
    I know this is rather late, and I don't know about string data, but your SendToHS command should be SendToHS(1,content). The device number is the Arduino plugin input device number, not the Homeseer device number.
    Mike
