Greg I have a nodemcu with a simple sketch with 8 led lights attached. has been working well for sometime. However it seems to be degrading over time. Board #8 seems to be reconnecting itself to HS3, I notice because the lights cycle thru and then reset according to what is set in HS3. I can't see where it is losing wifi connection. It looks to be to HS3. It use to be I could reboot HS3 and it would stop the reconnection issue. but that seems to be not working anymore either. I've attached a debug, hopefully I did it right, and you can take a look and see what is happening.
as a test...I set the lights on the board thru hs3 and then disabled the plugin. so far the board has not reset the lights.
