PZEM-004T support ?
    PZEM-004T support ?
    Hi
    I am looking at your plugin to replace my actual NodeMcu setup going through MQTT but I need to know does your plugin support the PZEM-004T voltage current device ?
    thanks
    The standard sketch will not support this but through the API mode in the plugin can interface with any input device if you code it.
    Greig.
    Sent from my SM-G950F using Tapatalk
    Scripts =
    Various
      Ahh, Ok thanks I'll have to stick with my setup since I won't be able to build the sketch.
        Hi goldriver
        I have a similar setup and i just finished creating sketch for PZEM
        if you want i can share it and have a talk with you
          Originally posted by tfoutfou View Post
          Hi goldriver
          have you been able to compile with the latest 'letscontrolit' environment ? That was my main issue as I am ising this interfac for many of my devices and prefer to keep everything on same basis and version for an easy support
