Thermistor
    Thermistor
    Hi Guys,
    im trying to connect a Thermistor to my Arduino to measure some temps. iv got it connected and reading values but not shore on the math.
    it has a range from -20 to 105 so a variable of 125
    if an analog input has a range of 0 to 1023
    would adding (value/125)-20 to the sum area allow me to read the temp
    thanks
    Originally posted by jezza View Post
    Hi Guys,
    thanks
    I think that your analog input readings are depending of your circuit in which Thermistor is connected. Constant current for Thermistor is critical for precise reading without fluctuating values.
    Sent from my EML-L09 using Tapatalk
      Does this help?
      https://learn.adafruit.com/thermisto...g-a-thermistor
      What is the voltage output range that will go to the analog input?
      **** Do You "Cocoon"? ****
        Hi,
        yeah that's how i have it connected.
        im getting a value back in the 600 range most of the time.
        i think i have it wired correctly it would just be the math i dont understand.
        thanks
