This is a small write-up to show how we are monitoring temperature from 5 different points in our garage around the gas water heater. It started out as a project to see if we could monitor temperature using the API sketch and it grew to include humidity and a 4 line LCD.
The NodeMCU units are fairly small and reasonably priced, so we use them throughout the house to monitor and report on a number of things, such as contacts, temperature, and humidity,
This unit has 4 DS18B20 One Wire temperature sensors hanging off the NodeMCU. One temp sensor for each water line (hot and cold), the other two sensors monitor temperature from the top and bottom of the water heater unit. The unit also has two LEDs on it that I flash from one to the other as a visual indication that the NodeMCU is reading through the sensors. As the lights jump from one to the other, the LCD also has a flashing spot up in the right upper quadrant. In that section of the LCD there two asterisks that move left and right, sorta like a ping pong ball effect. I have not had any issue with the unit since it was deployed. these things just seem to work. The unit uses the Arduino plugin API to function.
The NodeMCU unit is mounted in a small Tupperware container. This helps to protect it and also finds a cool use for some of our old Tupperware containers. I also used some Knexs to hold the LCD and right now the digital temperature and humidity sensor is just hanging off to the side. Over the years, along with our kids, we have built countless things with the Knexs (see https://www.knex.com/). Funny, I found a use for them years later with Home Automation. The plan is to mount it in a more suitable location in the garage in the future.
Some pictures of the completed device in its working location.
This is a picture of complete unit resting on the side of the water heater, it has the LCD angled down for easy viewing from the workbench.
This is a picture showing the mounting of two DS18B20 waterproof temperature sensors, one for each water line (hot and cold).
This picture shows a close-up of the LCD. Two pictures showing the double asterisks bouncing back and forth.
This is a picture of the inside of the Tupperware container, showing the breadboard, connections, lights power connection and screw terminals. (If you would like more pictures let me know)
These are links the parts used in the project. FYI, I have no vested interested in the sellers of the parts on Amazon. These worked for me, they delivered what I ordered, it was on time and at the time had a reasonable price.
This is a screenshot of the HomeSeer devices.
This is a screenshot of the Arduino plugin setup for board 5.
This is the sketch, I changed the SID, password field and removed the IP addresses. Using Arduino Plugin version 1.0.0.147
I hope this helps, if you need additional information, please let me know.
Description | Link |
Breadboard | https://www.amazon.com/gp/product/B01IMNVZDC/ |
Screw Terminals | https://www.amazon.com/gp/product/B07GPQ7DBH/ |
Digital Temperature and Humidity Sensor | https://www.amazon.com/gp/product/B0795F19W6/ |
DS18B20 Waterproof Temperature Sensors | https://www.amazon.com/gp/product/B07782SXCZ/ |
Blue Backlight LCD 20 x 4 | https://www.amazon.com/gp/product/B01L8ZCRE2/ |
NodeMCU - ESP8266 | https://www.amazon.com/gp/product/B010N1SPRK/ |
/************************************************************* Arduino to Homeseer 3 Plugin API written by Enigma Theatre. V1.0.0.146 * * *************************************************************/ int FromHS[50]; boolean IsConnected = false; //************************************************************ //**************Declare your variables here******************* #include <OneWire.h> #include <DallasTemperature.h> #include "DHT.h" #include <Wire.h> // Comes with Arduino IDE #include <LiquidCrystal_I2C.h> /********************************************************************/ // Data wire is plugged into a pin on the Arduino #define v_one_wire_bus_0 0 // NodeMCU D3 the number of the pin #define v_one_wire_bus_2 2 // NodeMCU D4 the number of the pin #define v_one_wire_bus_14 14 // NodeMCU D5 the number of the pin #define v_one_wire_bus_13 13 // NodeMCU D7 the number of the pin /********************************************************************/ // Setup a oneWire instance to communicate with any OneWire devices // (not just Maxim/Dallas temperature ICs) OneWire oneWire_0(v_one_wire_bus_0); OneWire oneWire_2(v_one_wire_bus_2); OneWire oneWire_14(v_one_wire_bus_14); OneWire oneWire_13(v_one_wire_bus_13); /********************************************************************/ // Pass our oneWire reference to Dallas Temperature. DallasTemperature v_sensors_0(&oneWire_0); DallasTemperature v_sensors_2(&oneWire_2); DallasTemperature v_sensors_14(&oneWire_14); DallasTemperature v_sensors_13(&oneWire_13); int v_current_fahrenheit_0 = 0; int v_current_fahrenheit_2 = 0; int v_current_fahrenheit_14 = 0; int v_current_fahrenheit_13 = 0; int v_last_fahrenheit_0 = 0; int v_last_fahrenheit_2 = 0; int v_last_fahrenheit_14 = 0; int v_last_fahrenheit_13 = 0; // Text Distance " 0 1 2 3 4 5 6 7 8 9"; String v_lcd_line_01; String v_lcd_line_02; String v_lcd_line_03; String v_lcd_line_04; String v_lcd_status; /********************************************************************/ // Data wire is plugged into a pin on the Arduino #define v_dht_pin_12 12 // DHT Sensor 1 Pin // Define Sensor #define v_dht_type22_12 DHT22 // DHT 22 Device 1 (AM2302) DHT v_dht_12(v_dht_pin_12, v_dht_type22_12); int v_current_fahrenheit_12 = 0; int v_current_humidity_12 = 0; int v_last_fahrenheit_12 = 0; int v_last_humidity_12 = 0; // constants won't change. Used here to set a pin number: const int v_ledPin_15 = 15; // NodeMCU D8 the number of the pin int v_ledState_15 = HIGH; // v_ledState used to set the LED int v_ledValue_15 = 100; // v_ledValue used to send to HomeSeer // constants won't change. Used here to set a pin number: const int v_ledPin_16 = 16; // NodeMCU D0 the number of the pin int v_ledState_16 = HIGH; // v_ledState used to set the LED int v_ledValue_16 = 100; // v_ledValue recieved from HomeSeer // Generally, you should use "unsigned long" for variables that hold time // The value will quickly become too large for an int to store unsigned long previousMillis = 0; // will store last time LED was updated // constants do not change: const long interval = 5000; // interval at which to blink (milliseconds) 5 seconds // LCD Connections // Connect the VCC pin on the LCD display to the VIN pin on the NodeMCU. // The VIN pin on the NodeMCU is tied directly to the 5V pin on the incoming USB port. // If you plan on powering the NodeMCU with something other than USB // you will have to find another way to provide 5V to the display. // Connect the GND pin on the LCD display to one of the GND pins on the NodeMCU. // Connect the SCL pin on the LCD display to the D1 pin on the NodeMCU. // Connect the SDA pin on the LCD display to the D2 pin on the NodeMCU. LiquidCrystal_I2C v_lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address /********************************************************************/ //**************************************************************** void HSSetup() { //************************ //Add YOUR SETUP HERE; //************************ pinMode(v_ledPin_15, OUTPUT); // set the digital pin as output: pinMode(v_ledPin_16, OUTPUT); // set the digital pin as output: // start serial port Serial.begin(9600); Serial.println("Temperature Display"); // Start up the library v_sensors_0.begin(); v_sensors_2.begin(); v_sensors_14.begin(); v_sensors_13.begin(); v_dht_12.begin(); //Start Sensor 16 v_lcd.begin(20,4); // initialize the lcd for 20 chars 4 lines, turn on backlight // ------- Quick 3 blinks of backlight ------------- for(int i = 0; i< 3; i++) { v_lcd.backlight(); v_lcd.noBacklight(); } v_lcd.backlight(); // finish with backlight on //-------- Write characters on the display ------------------ // NOTE: Cursor Position: Lines and Characters start at 0 // ("0 1 2 3 4 5 6 7 8 9 "); v_lcd_line_01 = String("Tmp #1: ???F ** **"); v_lcd_line_02 = String("Tmp #2: ???F "); v_lcd_line_03 = String("Tmp #3: ???F #4 ???F"); v_lcd_line_04 = String("Tmp/Hum ???F ???%"); v_lcd_status = String("** "); v_lcd.setCursor(0,0); v_lcd.print(v_lcd_line_01); v_lcd.setCursor(0,1); v_lcd.print(v_lcd_line_02); v_lcd.setCursor(0,2); v_lcd.print(v_lcd_line_03); v_lcd.setCursor(0,3); v_lcd.print(v_lcd_line_04); } void HSloop() { //************************ //Add YOUR CODE HERE; //************************ /* To Send Data to Homeseer use SendToHS(Device,Value) Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes. Eg.. FromHS[5] would be the data from API Output device 5 All code that is located just below this block will execute regardless of connection status! You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue. If you only want code to execute when HomeSeer is connected, put it inside the if statement below. */ /*Execute regardless of connection status*/ if (IsConnected == true) { /*Execute ONLY when HomeSeer is connected*/ // Serial.print("LED is: " ); // Serial.println(FromHS[0]); // check to see if it's time to blink the LED; that is, if the difference // between the current time and last time you blinked the LED is bigger than // the interval at which you want to blink the LED. unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { // save the last time you blinked the LED previousMillis = currentMillis; // if the LED is off turn it on and vice-versa: if (v_ledState_15 == LOW) { v_ledState_15 = HIGH; v_ledValue_15 = 100; v_ledState_16 = LOW; v_ledValue_16 = 0; v_lcd.setCursor(15,0); v_lcd.print("** "); } else { v_ledState_15 = LOW; v_ledValue_15 = 0; v_ledState_16 = HIGH; v_ledValue_16 = 100; v_lcd.setCursor(15,0); v_lcd.print(" **"); } digitalWrite(v_ledPin_15, v_ledState_15); // set the LED with the ledState of the variable: SendToHS(1,v_ledValue_15); digitalWrite(v_ledPin_16, v_ledState_16); // set the LED with the ledState of the variable: SendToHS(2,v_ledValue_16); v_sensors_0.requestTemperatures(); // Send the command to get temperature readings v_sensors_2.requestTemperatures(); // Send the command to get temperature readings v_sensors_14.requestTemperatures(); // Send the command to get temperature readings v_sensors_13.requestTemperatures(); // Send the command to get temperature readings /********************************************************************/ v_current_fahrenheit_0 = v_sensors_0.getTempCByIndex(0)* 1.8 + 32.0; v_current_fahrenheit_2 = v_sensors_2.getTempCByIndex(0)* 1.8 + 32.0; v_current_fahrenheit_14 = v_sensors_14.getTempCByIndex(0)* 1.8 + 32.0; v_current_fahrenheit_13 = v_sensors_13.getTempCByIndex(0)* 1.8 + 32.0; v_current_fahrenheit_12 = v_dht_12.readTemperature()* 1.8 + 32.0; v_current_humidity_12 = v_dht_12.readHumidity(); // // Display variable to monitor // // Serial.print("Temp #1x: "); // Serial.println(v_current_fahrenheit_0); // Serial.print("Temp #2x: "); // Serial.println(v_current_fahrenheit_2); // Serial.print("Temp #3x: "); // Serial.println(v_current_fahrenheit_14); // Serial.print("Temp #4x: "); // Serial.println(v_current_fahrenheit_13); // // Temp #1 D3 // if (v_current_fahrenheit_0 == -196) { v_lcd.setCursor(8,0); v_lcd.print("???"); Serial.print("Temp #1: "); Serial.println(v_current_fahrenheit_0); SendToHS(3,v_current_fahrenheit_0); } else if ((v_current_fahrenheit_0 > 9 && v_current_fahrenheit_0 < 99) && (v_current_fahrenheit_0 != v_last_fahrenheit_0)) { v_lcd.setCursor(8,0); v_lcd.print(" "); v_lcd.setCursor(9,0); v_lcd.print(v_current_fahrenheit_0); Serial.print("Temp #1: "); Serial.println(v_current_fahrenheit_0); SendToHS(3,v_current_fahrenheit_0); v_last_fahrenheit_0 = v_current_fahrenheit_0; } else if ((v_current_fahrenheit_0 > 99 && v_current_fahrenheit_0 < 195) && (v_current_fahrenheit_0 != v_last_fahrenheit_0)) { v_lcd.setCursor(8,0); v_lcd.print(v_current_fahrenheit_0); Serial.print("Temp #1: "); Serial.println(v_current_fahrenheit_0); SendToHS(3,v_current_fahrenheit_0); v_last_fahrenheit_0 = v_current_fahrenheit_0; } else if ((v_current_fahrenheit_0 == 1 && v_current_fahrenheit_0 > 9) && (v_current_fahrenheit_0 != v_last_fahrenheit_0)) { v_lcd.setCursor(8,0); v_lcd.print(" "); v_lcd.setCursor(10,0); v_lcd.print(v_current_fahrenheit_0); Serial.print("Temp #1: "); Serial.println(v_current_fahrenheit_0); SendToHS(3,v_current_fahrenheit_0); v_last_fahrenheit_0 = v_current_fahrenheit_0; } else if ((v_current_fahrenheit_0 < 0 && v_current_fahrenheit_0 > -196) && (v_current_fahrenheit_0 != v_last_fahrenheit_0)) { v_lcd.setCursor(8,0); v_lcd.print(" "); v_lcd.setCursor(10,0); v_lcd.print(v_current_fahrenheit_0); Serial.print("Temp #1: "); Serial.println(v_current_fahrenheit_0); SendToHS(3,v_current_fahrenheit_0); v_last_fahrenheit_0 = v_current_fahrenheit_0; } // // Temp #2 D4 // if (v_current_fahrenheit_2 == -196) { v_lcd.setCursor(8,1); v_lcd.print("???"); Serial.print("Temp #2: "); Serial.println(v_current_fahrenheit_2); SendToHS(4,v_current_fahrenheit_2); } else if ((v_current_fahrenheit_2 > 9 && v_current_fahrenheit_2 < 99) && (v_current_fahrenheit_2 != v_last_fahrenheit_2)) { v_lcd.setCursor(8,1); v_lcd.print(" "); v_lcd.setCursor(9,1); v_lcd.print(v_current_fahrenheit_2); Serial.print("Temp #2: "); Serial.println(v_current_fahrenheit_2); SendToHS(4,v_current_fahrenheit_2); v_last_fahrenheit_2 = v_current_fahrenheit_2; } else if ((v_current_fahrenheit_2 > 99 && v_current_fahrenheit_2 < 195) && (v_current_fahrenheit_2 != v_last_fahrenheit_2)) { v_lcd.setCursor(8,1); v_lcd.print(v_current_fahrenheit_2); Serial.print("Temp #2: "); Serial.println(v_current_fahrenheit_2); SendToHS(4,v_current_fahrenheit_2); v_last_fahrenheit_2 = v_current_fahrenheit_2; } else if ((v_current_fahrenheit_2 == 1 && v_current_fahrenheit_2 > 9) && (v_current_fahrenheit_2 != v_last_fahrenheit_2)) { v_lcd.setCursor(8,1); v_lcd.print(" "); v_lcd.setCursor(10,1); v_lcd.print(v_current_fahrenheit_2); Serial.print("Temp #2: "); Serial.println(v_current_fahrenheit_2); SendToHS(4,v_current_fahrenheit_2); v_last_fahrenheit_2 = v_current_fahrenheit_2; } else if ((v_current_fahrenheit_2 < 0 && v_current_fahrenheit_2 > -196) && (v_current_fahrenheit_2 != v_last_fahrenheit_2)) { v_lcd.setCursor(8,1); v_lcd.print(" "); v_lcd.setCursor(10,1); v_lcd.print(v_current_fahrenheit_2); Serial.print("Temp #2: "); Serial.println(v_current_fahrenheit_2); SendToHS(4,v_current_fahrenheit_2); v_last_fahrenheit_2 = v_current_fahrenheit_2; } // // Temp #3 D5 // if (v_current_fahrenheit_14 == -196) { v_lcd.setCursor(8,2); v_lcd.print("???"); Serial.print("Temp #3: "); Serial.println(v_current_fahrenheit_14); SendToHS(5,v_current_fahrenheit_14); } else if ((v_current_fahrenheit_14 > 9 && v_current_fahrenheit_14 < 99) && (v_current_fahrenheit_14 != v_last_fahrenheit_14)) { v_lcd.setCursor(8,2); v_lcd.print(" "); v_lcd.setCursor(9,2); v_lcd.print(v_current_fahrenheit_14); Serial.print("Temp #3: "); Serial.println(v_current_fahrenheit_14); SendToHS(5,v_current_fahrenheit_14); v_last_fahrenheit_14 = v_current_fahrenheit_14; } else if ((v_current_fahrenheit_14 > 99 && v_current_fahrenheit_14 < 195) && (v_current_fahrenheit_14 != v_last_fahrenheit_14)) { v_lcd.setCursor(8,2); v_lcd.print(v_current_fahrenheit_14); Serial.print("Temp #3: "); Serial.println(v_current_fahrenheit_14); SendToHS(5,v_current_fahrenheit_14); v_last_fahrenheit_14 = v_current_fahrenheit_14; } else if ((v_current_fahrenheit_14 == 1 && v_current_fahrenheit_14 > 9) && (v_current_fahrenheit_14 != v_last_fahrenheit_14)) { v_lcd.setCursor(8,2); v_lcd.print(" "); v_lcd.setCursor(10,2); v_lcd.print(v_current_fahrenheit_14); Serial.print("Temp #3: "); Serial.println(v_current_fahrenheit_14); SendToHS(5,v_current_fahrenheit_14); v_last_fahrenheit_14 = v_current_fahrenheit_14; } else if ((v_current_fahrenheit_14 < 0 && v_current_fahrenheit_14 > -196) && (v_current_fahrenheit_14 != v_last_fahrenheit_14)) { v_lcd.setCursor(8,2); v_lcd.print(" "); v_lcd.setCursor(10,2); v_lcd.print(v_current_fahrenheit_14); Serial.print("Temp #3: "); Serial.println(v_current_fahrenheit_14); SendToHS(5,v_current_fahrenheit_14); v_last_fahrenheit_14 = v_current_fahrenheit_14; } // // Temp #4 D7 // if (v_current_fahrenheit_13 == -196) { v_lcd.setCursor(16,2); v_lcd.print("???"); Serial.print("Temp #4: "); Serial.println(v_current_fahrenheit_13); SendToHS(6,v_current_fahrenheit_13); } else if ((v_current_fahrenheit_13 > 9 && v_current_fahrenheit_13 < 99) && (v_current_fahrenheit_13 != v_last_fahrenheit_13)) { v_lcd.setCursor(16,2); v_lcd.print(" "); v_lcd.setCursor(17,2); v_lcd.print(v_current_fahrenheit_13); Serial.print("Temp #4: "); Serial.println(v_current_fahrenheit_13); SendToHS(6,v_current_fahrenheit_13); v_last_fahrenheit_13 = v_current_fahrenheit_13; } else if ((v_current_fahrenheit_13 > 99 && v_current_fahrenheit_13 < 195) && (v_current_fahrenheit_13 != v_last_fahrenheit_13)) { v_lcd.setCursor(16,2); v_lcd.print(v_current_fahrenheit_13); Serial.print("Temp #4: "); Serial.println(v_current_fahrenheit_13); SendToHS(6,v_current_fahrenheit_13); v_last_fahrenheit_13 = v_current_fahrenheit_13; } else if ((v_current_fahrenheit_13 == 1 && v_current_fahrenheit_13 > 9) && (v_current_fahrenheit_13 != v_last_fahrenheit_13)) { v_lcd.setCursor(16,2); v_lcd.print(" "); v_lcd.setCursor(18,2); v_lcd.print(v_current_fahrenheit_13); Serial.print("Temp #4: "); Serial.println(v_current_fahrenheit_13); SendToHS(6,v_current_fahrenheit_13); v_last_fahrenheit_13 = v_current_fahrenheit_13; } else if ((v_current_fahrenheit_13 < 0 && v_current_fahrenheit_13 > -196) && (v_current_fahrenheit_13 != v_last_fahrenheit_13)) { v_lcd.setCursor(16,2); v_lcd.print(" "); v_lcd.setCursor(18,2); v_lcd.print(v_current_fahrenheit_13); Serial.print("Temp #4: "); Serial.println(v_current_fahrenheit_13); SendToHS(6,v_current_fahrenheit_13); v_last_fahrenheit_13 = v_current_fahrenheit_13; } // // Temperature D6 - Temp/Humidity Sensor // if (v_current_fahrenheit_12 == -196) { v_lcd.setCursor(8,3); v_lcd.print("???"); Serial.print("Temp #5: "); Serial.println(v_current_fahrenheit_12); SendToHS(7,v_current_fahrenheit_12); } else if ((v_current_fahrenheit_12 > 9 && v_current_fahrenheit_12 < 99) && (v_current_fahrenheit_12 != v_last_fahrenheit_12)) { v_lcd.setCursor(8,3); v_lcd.print(" "); v_lcd.setCursor(9,3); v_lcd.print(v_current_fahrenheit_12); Serial.print("Temp #5: "); Serial.println(v_current_fahrenheit_12); SendToHS(7,v_current_fahrenheit_12); v_last_fahrenheit_12 = v_current_fahrenheit_12; } else if ((v_current_fahrenheit_12 > 99 && v_current_fahrenheit_12 < 195) && (v_current_fahrenheit_12 != v_last_fahrenheit_12)) { v_lcd.setCursor(8,3); v_lcd.print(v_current_fahrenheit_12); Serial.print("Temp #5: "); Serial.println(v_current_fahrenheit_12); SendToHS(7,v_current_fahrenheit_12); v_last_fahrenheit_12 = v_current_fahrenheit_12; } else if ((v_current_fahrenheit_12 == 1 && v_current_fahrenheit_12 > 9) && (v_current_fahrenheit_12 != v_last_fahrenheit_12)) { v_lcd.setCursor(8,3); v_lcd.print(" "); v_lcd.setCursor(10,3); v_lcd.print(v_current_fahrenheit_12); Serial.print("Temp #5: "); Serial.println(v_current_fahrenheit_12); SendToHS(7,v_current_fahrenheit_12); v_last_fahrenheit_12 = v_current_fahrenheit_12; } else if ((v_current_fahrenheit_12 < 0 && v_current_fahrenheit_12 > -196) && (v_current_fahrenheit_12 != v_last_fahrenheit_12)) { v_lcd.setCursor(8,3); v_lcd.print(" "); v_lcd.setCursor(10,3); v_lcd.print(v_current_fahrenheit_12); Serial.print("Temp #5: "); Serial.println(v_current_fahrenheit_12); SendToHS(7,v_current_fahrenheit_12); v_last_fahrenheit_12 = v_current_fahrenheit_12; } // // Humidity D6 - Temp/Humidity Sensor // if (v_current_humidity_12 == -196) { v_lcd.setCursor(16,3); v_lcd.print("???"); Serial.print("Humd #5: "); Serial.println(v_current_humidity_12); SendToHS(8,v_current_humidity_12); } else if ((v_current_humidity_12 > 9 && v_current_humidity_12 < 99) && (v_current_humidity_12 != v_last_humidity_12)) { v_lcd.setCursor(16,3); v_lcd.print(" "); v_lcd.setCursor(17,3); v_lcd.print(v_current_humidity_12); Serial.print("Humd #5: "); Serial.println(v_current_humidity_12); SendToHS(8,v_current_humidity_12); v_last_humidity_12 = v_current_humidity_12; } else if ((v_current_humidity_12 > 99 && v_current_humidity_12 < 195) && (v_current_humidity_12 != v_last_humidity_12)) { v_lcd.setCursor(16,3); v_lcd.print(v_current_humidity_12); Serial.print("Humd #5: "); Serial.println(v_current_humidity_12); SendToHS(8,v_current_humidity_12); v_last_humidity_12 = v_current_humidity_12; } else if ((v_current_humidity_12 == 1 && v_current_humidity_12 > 9) && (v_current_humidity_12 != v_last_humidity_12)) { v_lcd.setCursor(16,3); v_lcd.print(" "); v_lcd.setCursor(18,3); v_lcd.print(v_current_humidity_12); Serial.print("Humd #5: "); Serial.println(v_current_humidity_12); SendToHS(8,v_current_humidity_12); v_last_humidity_12 = v_current_humidity_12; } else if ((v_current_humidity_12 < 0 && v_current_humidity_12 > -196) && (v_current_humidity_12 != v_last_humidity_12)) { v_lcd.setCursor(16,3); v_lcd.print(" "); v_lcd.setCursor(18,3); v_lcd.print(v_current_humidity_12); Serial.print("Humd #5: "); Serial.println(v_current_humidity_12); SendToHS(8,v_current_humidity_12); v_last_humidity_12 = v_current_humidity_12; } } } } //************Do not change anything after Here***************** #define ISIP 1 #define BoardType 3 const byte BoardAdd = 5; #include <EEPROM.h> #if BoardType == 3 #include <ESP8266WiFi.h> #include <WiFiUdp.h> #include <ESP8266mDNS.h> #include <ArduinoOTA.h> char ssid[] = "SID"; char pass[] = "PASSWORD"; #else #include <SPI.h> #include <Ethernet.h> #include <EthernetUdp.h> #endif #if ISIP == 1 byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x05}; IPAddress ip(123,123,123,123); //IP entered In HS config. const unsigned int localPort = 1234; //port entered In HS config. IPAddress HomeseerIP(123,123,123,123); //Homeseer IP address IPAddress ServerIP(EEPROM.read(2), EEPROM.read(3), EEPROM.read(4), EEPROM.read(5)); IPAddress gateway(123,123,123,123); IPAddress subnet(255,255,255,0); byte EEpromVersion = EEPROM.read(250); char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; const unsigned int ServerPort = 8888; #endif #if BoardType == 3 WiFiUDP Udp; WiFiUDP SendPort; #else EthernetUDP Udp; #endif #if BoardType == 3 void resetFunc() { ESP.restart(); } #else void(* resetFunc) (void) = 0; #endif char* Version = "API1.0.0.146"; byte Byte1, Byte2, Byte3; unsigned int Byte4, Byte5; void setup() { #if BoardType == 3 // WiFi.persistent(false); EEPROM.begin(256); EEpromVersion = EEPROM.read(250); #endif #if ISIP == 1 if (EEpromVersion != 22) { ServerIP = HomeseerIP; EEPROM.write(2, ServerIP[0]); EEPROM.write(3, ServerIP[1]); EEPROM.write(4, ServerIP[2]); EEPROM.write(5, ServerIP[3]); EEPROM.write(250, 22); //Store the version where the eeprom data layout was last changed EEpromVersion = 22; } #if BoardType == 3 //Serial.begin(115200); WiFi.begin(ssid, pass); WiFi.config(ip, gateway, subnet); OTA(); WiFi.mode(WIFI_STA); while (WiFi.status() != WL_CONNECTED) { delay(500); } #else Ethernet.begin(mac, ip, gateway, gateway, subnet); #endif Udp.begin(localPort); Udp.setTimeout(0); delay(1000); SendConnect(); #else Serial.begin(115200); Serial.flush(); Serial.setTimeout(0); delay(1000); Serial.print("Connect "); Serial.println(BoardAdd); #endif= IsConnected = false; HSSetup(); } void loop() { #if BoardType == 3 ArduinoOTA.handle(); #endif HSloop(); #if ISIP == 1 UDPCheck(); #endif } void SendConnect() { #if ISIP == 0 Serial.print("Connect "); Serial.println(BoardAdd); #else Udp.beginPacket(HomeseerIP, ServerPort); //First send a connect packet to the dynamic IP stored in eeprom Udp.print("Connect "); Udp.print(BoardAdd); Udp.endPacket(); if (ServerIP != HomeseerIP) { Udp.beginPacket(HomeseerIP, ServerPort); //Then if the stored value doesn't match the pre-specified one, send a connect packet there also Udp.print("Connect "); Udp.print(BoardAdd); Udp.endPacket(); } #endif } #if ISIP == 1 void UDPCheck() { int packetSize = Udp.parsePacket(); if (packetSize) { #if BoardType == 3 IPAddress remote = Udp.remoteIP(); Byte1 = Udp.parseInt(); Udp.read(); Byte2 = Udp.read(); Udp.read(); Byte3 = Udp.parseInt(); Udp.read(); Byte4 = Udp.parseInt(); Udp.read(); Byte5 = Udp.parseInt(); DataEvent(); #else ServerIP = Udp.remoteIP(); Byte1 = Udp.parseInt(); Udp.read(); Byte2 = Udp.read(); Byte3 = Udp.parseInt();; Byte4 = Udp.parseInt(); Byte5 = Udp.parseInt();; DataEvent(); #endif } } #else void serialEvent() { while (Serial.available() > 0) { delay(17); Byte1 = Serial.parseInt(); Serial.read(); Byte2 = Serial.read(); Byte3 = Serial.parseInt(); Byte4 = Serial.parseInt(); Byte5 = Serial.parseInt(); DataEvent(); } } #endif /* Used Data Input Cases D Disconnect r reset K Keepalive O PinMode Output Set d Input debounce time set C Connect request c Connection established - report current status */ void DataEvent() { if (Byte1 == BoardAdd) { #if ISIP == 1 if (Udp.remoteIP() != ServerIP) { ServerIP = Udp.remoteIP(); EEPROM.write(2, ServerIP[0]); EEPROM.write(3, ServerIP[1]); EEPROM.write(4, ServerIP[2]); EEPROM.write(5, ServerIP[3]); } #endif switch (Byte2) { case 'c': IsConnected = true; break; case 'C': #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print("Version "); Udp.print(BoardAdd); Udp.print(" "); Udp.print(Version); Udp.println(" HS3"); Udp.endPacket(); Udp.beginPacket(HomeseerIP, ServerPort); delay(100); Udp.print("Connected "); Udp.println(BoardAdd); Udp.endPacket(); #else Serial.print("Version "); Serial.print(BoardAdd); Serial.print(" "); Serial.print(Version); Serial.println(" HS3"); delay(100); Serial.print("Connected "); Serial.println(BoardAdd); #endif delay(100); IsConnected = false; break; case 'K': delay(200); #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print("Alive "); Udp.println(BoardAdd); Udp.endPacket(); if (Udp.remoteIP() != ServerIP) { ServerIP = Udp.remoteIP(); EEPROM.write(2, ServerIP[0]); EEPROM.write(3, ServerIP[1]); EEPROM.write(4, ServerIP[2]); EEPROM.write(5, ServerIP[3]); } #else Serial.print("Alive "); Serial.println(BoardAdd); #endif break; case 'r': delay(200); resetFunc(); //call reset break; case 'O': FromHS[Byte3] = Byte4; break; case 'D': IsConnected = false; break; } } } void SendToHS(byte Device, long Data) { if (IsConnected == true) { #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print(BoardAdd); Udp.print(" API "); Udp.print(Device); Udp.print(" "); Udp.print(Data); Udp.endPacket(); #else Serial.print(BoardAdd); Serial.print(" API "); Serial.print(Device); Serial.print(" "); Serial.println(Data); #endif } } void SendToHS(byte Device, int Data) { if (IsConnected == true) { #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print(BoardAdd); Udp.print(" API "); Udp.print(Device); Udp.print(" "); Udp.print(Data); Udp.endPacket(); #else Serial.print(BoardAdd); Serial.print(" API "); Serial.print(Device); Serial.print(" "); Serial.println(Data); #endif } } void SendToHS(byte Device, float Data) { if (IsConnected == true) { #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print(BoardAdd); Udp.print(" API "); Udp.print(Device); Udp.print(" "); Udp.print(Data); Udp.endPacket(); #else Serial.print(BoardAdd); Serial.print(" API "); Serial.print(Device); Serial.print(" "); Serial.println(Data); #endif } } void SendToHS(byte Device, double Data) { if (IsConnected == true) { #if ISIP == 1 Udp.beginPacket(HomeseerIP, ServerPort); Udp.print(BoardAdd); Udp.print(" API "); Udp.print(Device); Udp.print(" "); Udp.print(Data); Udp.endPacket(); #else Serial.print(BoardAdd); Serial.print(" API "); Serial.print(Device); Serial.print(" "); Serial.println(Data); #endif } } //*******************************OTA Update************************* void OTA() { #if BoardType == 3 char OTAName[50]; sprintf(OTAName, "Homeseer API Board:%02i", BoardAdd ); ArduinoOTA.setHostname(OTAName); ArduinoOTA.onStart([]() { }); ArduinoOTA.onEnd([]() { }); ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) { }); ArduinoOTA.onError([](ota_error_t error) { }); ArduinoOTA.begin(); #endif }
