One-wire error
    One-wire error
    Hi
    I have problem to find my ds18b20 tempsor.
    I rewire everything. After that I can't get any value from all my old ds18b20. But when I connect a new sersor that one works.
    Have try to deleted the pin and assign it again. With no result. Have also deleted all tempsensor in HS3.
    And still don't get any of the old ones to work.
    ​​​​​​After try deleting the pin again with the new sensor install that one to stop working.
    Any clue!
    Does it need some data rest to forget all the old sensors??
    The pin must work fine if you have a test sensor on it so it must be hardware or that the sensor needs to change value to be found by the plugin. Try and warm it up or cool it down.
    Greig.
    Sent from my SM-G950F using Tapatalk
    Scripts =
    Various
