NodeMCU with Lightning Detector
    Anyone try to connect this Lightning Detector to a NodeMCU:
    https://www.playingwithfusion.com/pr...ew.php?pdid=22
    When I compile the sketch for the NodeMCU I get the following error:
    exit status 1
    error compiling for board NodeMCU 1.0(ESP.12E Modules)
    If I switch to the Arduino Mega it compiles, loads, and runs fine. Any suggestions as to why it won't work with the NodeMCU?
    Rick
    i got s similar error yesterday with a standard NodeMCU board and the only way i could get it to work was by downloading the latest arduino and it worked first try (there were some notes saying there was a bug for the NodeMCU boards that was fixed in the newer versions)
      also I found it seems you can't have a NodeMCU board as board 1 (it won't connect)? i just added board 1 with nothing on it and put the NodeMCU as board 2 and it worked fine (was on a linux box)
        Thanks for the response..
        When you state "...Downloading the latest Arduino", are I you referring to the latest Arduino IDE??
        Rick
          I have no problems with a nodeMCU as board 1.
            Just to close out this thread.....The supplied sketch with the Lightning Detector has a function the NodeMCU doesn't support: #include "avr/pgmspace.h". I tried many work-arounds, to replace the function with other code, but no success.
            So I switched to an Arduino Uno, and the device works fine.
            Rick
              If you have the SPI version please remove the old and the attached modified Library and get back to me. It should work on the Nodemcu. It compiles here but I do not have one to test.
              Scripts =
              Various
                Greig;
                I loaded the modified Library. Below are the results from trying to run the sketch 2 ways. The first is when I insert the sketch into the NodeMCU API. The second is just the sketch stand-alone.
                1) The following error message is when I try to compile the SPI sketch within the NodeMCU API:
                Arduino: 1.8.1 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
                In file included from C:\Users\Rick\Downloads\APIBoard6\APIBoard6.ino:16:0:
                C:\Users\Rick\Documents\Arduino\libraries\sen39001_arduino_s pi_r00/PWFusion_AS3935.h:51:26: fatal error: avr/pgmspace.h: No such file or directory
                compilation terminated.
                exit status 1
                Error compiling for board NodeMCU 1.0 (ESP-12E Module).
                _______________________________________________-
                2) The following error message is when I try to compile the sketch by itself:
                In file included from C:\Users\Rick\Documents\Arduino\libraries\sen39001_arduino_s pi_r00\Examples\as3935_lightning_snsr_nocal\as3935_lightning _snsr_nocal.ino:69:0:
                exit status 1
                Any suggestions??
                Rick
                  exit status 1
                  Rick
                  Rick,
                  Sorry I missed your post. Did you get the new modified Library I attached as I can not see it and it works fine here? Try from Here
                  If not open the PWFusion_AS3935.h file that should be located in \Documents\Arduino\libraries\sen39001_arduino_spi_r00 and change the top section:
                  #include "Arduino.h"
                  #include "util/delay.h"
                  #include "stdlib.h"
                  #include "SPI.h"
                  to be
                  #if defined(ESP8266)
                    #include <pgmspace.h>
                   #define _delay_ms(ms) delayMicroseconds((ms) * 1000)
                  #else
                  #endif
                  #include "stdlib.h"
                  #include "SPI.h"
                  save it and compile again.
                  Greig
                  Scripts =
                  Various
                    Greig;
                    Thank you for the code. I made the change, and inserted the sketch into the NodeMCU API. The good news it now compiles, and loads! But when it executes I get continuous WatchDog Timer (WDT) reset:
                    Playing With Fusion: AS3935 Lightning Sensor, SEN-39001
                    beginning boot procedure....
                    set up for outdoor operation
                    disturber detection enabled
                    capacitance set to 8x15
                    AS3935 manual cal complete
                    Soft WDT reset
                    ctx: cont
                    sp: 3ffefac0 end: 3ffefcb0 offset: 01b0
                    >>>stack>>>
                    3ffefc70: 3ffe8a00 a501a8c0 feefeffe feefeffe
                    3ffefc80: 3fffdad0 00000000 3ffeec80 4020286b
                    3ffefc90: 3fffdad0 00000000 3ffeec80 40207950
                    3ffefca0: feefeffe feefeffe 3ffeec90 40100718
                    <<<stack<<<
                    ets Jan 8 2013,rst cause:2, boot mode3,6)
                    load 0x4010f000, len 1384, room 16
                    tail 8
                    chksum 0x2d
                    csum 0x2d
                    v3de0c112
                    ~ld
                    I know the code runs clean on an Arduino uno. Is this another NodeMCU code difference compared to the Uno?
                    Rick
                      Ah, the fun world of software! Hang in there, Rick!
                      Paul
                        Greig;
                        Soft WDT reset
                        ctx: cont
                        >>>stack>>>
                        <<<stack<<<
                        tail 8
                        chksum 0x2d
                        csum 0x2d
                        v3de0c112
                        ~ld
                        Rick
                        Rick,
                        Not sure how I can test this without the unit but I will investigate more and see what I can find.
                        Greig
                        Scripts =
                        Various
