NodeMCU with Lightning Detector
  • enigmatheatre
    Originally posted by Rmasci64 View Post
    Greig;
    Thank you for the code. I made the change, and inserted the sketch into the NodeMCU API. The good news it now compiles, and loads! But when it executes I get continuous WatchDog Timer (WDT) reset:
    Playing With Fusion: AS3935 Lightning Sensor, SEN-39001
    beginning boot procedure....
    set up for outdoor operation
    disturber detection enabled
    capacitance set to 8x15
    AS3935 manual cal complete
    Soft WDT reset
    ctx: cont
    sp: 3ffefac0 end: 3ffefcb0 offset: 01b0
    >>>stack>>>
    3ffefc70: 3ffe8a00 a501a8c0 feefeffe feefeffe
    3ffefc80: 3fffdad0 00000000 3ffeec80 4020286b
    3ffefc90: 3fffdad0 00000000 3ffeec80 40207950
    3ffefca0: feefeffe feefeffe 3ffeec90 40100718
    <<<stack<<<
    ets Jan 8 2013,rst cause:2, boot mode3,6)
    load 0x4010f000, len 1384, room 16
    tail 8
    chksum 0x2d
    csum 0x2d
    v3de0c112
    ~ld
    I know the code runs clean on an Arduino uno. Is this another NodeMCU code difference compared to the Uno?
    Rick
    Rick,
    Not sure how I can test this without the unit but I will investigate more and see what I can find.
    Greig
  • BigBadBuzz
    Ah, the fun world of software! Hang in there, Rick!
    Paul
  • Rmasci64
    Greig;
    Soft WDT reset
    ctx: cont
    >>>stack>>>
    <<<stack<<<
    tail 8
    chksum 0x2d
    csum 0x2d
    v3de0c112
    ~ld
    Rick
  • enigmatheatre
    Anyone try to connect this Lightning Detector to a NodeMCU:
    https://www.playingwithfusion.com/pr...ew.php?pdid=22
    When I compile the sketch for the NodeMCU I get the following error:
    exit status 1
    error compiling for board NodeMCU 1.0(ESP.12E Modules)
    If I switch to the Arduino Mega it compiles, loads, and runs fine. Any suggestions as to why it won't work with the NodeMCU?
    Rick
    Rick,
    Sorry I missed your post. Did you get the new modified Library I attached as I can not see it and it works fine here? Try from Here
    If not open the PWFusion_AS3935.h file that should be located in \Documents\Arduino\libraries\sen39001_arduino_spi_r00 and change the top section:
    #include "Arduino.h"
    #include "avr/pgmspace.h"
    #include "util/delay.h"
    #include "stdlib.h"
    #include "SPI.h"
    to be
    #if defined(ESP8266)
      #include <pgmspace.h>
     #define _delay_ms(ms) delayMicroseconds((ms) * 1000)
    #else
    #endif
    #include "stdlib.h"
    #include "SPI.h"
    save it and compile again.
    Greig
  • Rmasci64
    Greig;
    I loaded the modified Library. Below are the results from trying to run the sketch 2 ways. The first is when I insert the sketch into the NodeMCU API. The second is just the sketch stand-alone.
    1) The following error message is when I try to compile the SPI sketch within the NodeMCU API:
    Arduino: 1.8.1 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
    In file included from C:\Users\Rick\Downloads\APIBoard6\APIBoard6.ino:16:0:
    C:\Users\Rick\Documents\Arduino\libraries\sen39001_arduino_s pi_r00/PWFusion_AS3935.h:51:26: fatal error: avr/pgmspace.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
    _______________________________________________-
    2) The following error message is when I try to compile the sketch by itself:
    In file included from C:\Users\Rick\Documents\Arduino\libraries\sen39001_arduino_s pi_r00\Examples\as3935_lightning_snsr_nocal\as3935_lightning _snsr_nocal.ino:69:0:
    exit status 1
    Any suggestions??
    Rick
  • enigmatheatre
    If you have the SPI version please remove the old and the attached modified Library and get back to me. It should work on the Nodemcu. It compiles here but I do not have one to test.
  • Rmasci64
    Just to close out this thread.....The supplied sketch with the Lightning Detector has a function the NodeMCU doesn't support: #include "avr/pgmspace.h". I tried many work-arounds, to replace the function with other code, but no success.
    So I switched to an Arduino Uno, and the device works fine.
    Rick
  • logbuilder
    I have no problems with a nodeMCU as board 1.
  • Rmasci64
    Thanks for the response..
    When you state "...Downloading the latest Arduino", are I you referring to the latest Arduino IDE??
    Rick
  • usLEDsupply
    also I found it seems you can't have a NodeMCU board as board 1 (it won't connect)? i just added board 1 with nothing on it and put the NodeMCU as board 2 and it worked fine (was on a linux box)
  • usLEDsupply
    i got s similar error yesterday with a standard NodeMCU board and the only way i could get it to work was by downloading the latest arduino and it worked first try (there were some notes saying there was a bug for the NodeMCU boards that was fixed in the newer versions)
  • Rmasci64
    started a topic NodeMCU with Lightning Detector
    exit status 1
    Rick
