How can I cycle a pin on and off every second?
  • How can I cycle a pin on and off every second?
    I'm using a nodemcu and the downloaded script from enigmatheatre on my board #5. I'd like to get a pin (D5) to cycle high and low every second to flash a LED when an event fires. On the Device page it shows a "Blink" option but that just turns it on, not blink. When I go to the status page, the control use option is set to on and there is no blink in the options menu. To cut to the chase, is there a way to do this? I'm not that great at writing code but if someone can lead me in the right direction I'd really appreciate it.
    The plugin creates 2 devices for each output the first is the one you have found with on, off, blink One Flash and Toggle and the second it output time that you need to set to the value you require for the Blink and One Flash. I am guessing you have filtered out the Output Time Device and have not set it.
    Greig.
    Scripts =
    Various
      No, have not filtered them out but had no idea what they were used for until now. So what you're saying is that I select blink and adjust the time in milliseconds? If that's the case, I feel a bit dumb. This plugin is beyond great, best investment yet.
        Yes, but you need to set the time then press blink to update it.
        Greig.
        Scripts =
        Various
