Replacing Arduino and sheild issue
    So I cooked via a bad power supply my mega-3 board. After replacing it, the plugin doesn't seem to connect. I replaced the network shield too. I was under the impression you can just replace these things and the plugin will load the same sketch and off you go. Am I wrong to assume this? What do I need to do to make it work again?
    You would need to download the sketch from the plugin page then upload it to the new board like you did for the first one.
    Scripts =
    Various
      Thanks… it's been so long since I've played with this I've actually forgotten that step...
        No Problems. You should just replace your board, Upload the sketch and your good to go.
        Greig.
        Scripts =
        Various
