Hi, just looking for some feedback before I take the plunge and upgrade.
May-26 10:58:39 PM | Arduino Plugin | Error = Exception in RecievedData4 : Index was outside the bounds of the array. |
May-26 10:58:39 PM | Arduino Plugin | Error = Exception in RecievedData3 : Index was outside the bounds of the array. |
May-26 10:58:39 PM | Arduino Plugin | Error = Exception in RecievedData1 : Index was outside the bounds of the array. |
May-26 10:58:19 PM | Arduino Plugin | Error = Exception in RecievedData4 : Index was outside the bounds of the array. |
May-26 10:58:19 PM | Arduino Plugin | Error = Exception in RecievedData3 : Index was outside the bounds of the array. |
May-26 10:58:19 PM | Arduino Plugin | Error = Exception in RecievedData1 : Index was outside the bounds of the array. |
May-26 10:58:09 PM | Arduino Plugin | Error = Exception in RecievedData4 : Index was outside the bounds of the array. |
May-26 10:58:09 PM | Arduino Plugin | Error = Exception in RecievedData3 : Index was outside the bounds of the array. |
May-26 10:58:09 PM | Arduino Plugin | Error = Exception in RecievedData1 : Index was outside the bounds of the array. |
May-26 10:57:59 PM | Arduino Plugin | Error = Exception in RecievedData4 : Index was outside the bounds of the array. |
May-26 10:57:59 PM | Arduino Plugin | Error = Exception in RecievedData3 : Index was outside the bounds of the array. |
May-26 10:57:59 PM | Arduino Plugin | Error = Exception in RecievedData1 : Index was outside the bounds of the array. |
May-26 10:57:49 PM | Arduino Plugin | Error = Exception in RecievedData4 : Index was outside the bounds of the array. |
May-26 10:57:49 PM | Arduino Plugin | Error = Exception in RecievedData3 : Index was outside the bounds of the array. |
