Dear Greg,
I'm using your plugin for 2 Arduino boards. The plugin works great. But when I set one or more outputs the response is very slow. This is the log with a script that sets 4 outputs by capi:
I'm using
Arduino 1.0.0.148
Homeseer 3.0.0.435
I use the capi controll by a script, but also when i set one device manual on the home page in HS then this has also a very slow response.
I need a quick response for my tasks.
Can you please help?
jun-16 15:48:37 | Warning | Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:37 | Warning | Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:29 | Warning | Dropping event callbacks due to full queue (Type: 1024) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:28 | Warning | Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:17 | Arduino Plugin | Change of Device Screen living links 1-4 BC set position 3rd digit To Value 0 |
jun-16 15:48:17 | Warning | Dropping event callbacks due to full queue (Type: 2) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:17 | Warning | Dropping event callbacks due to full queue (Type: 2048) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:17 | Warning | Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:17 | Warning | Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:48:17 | Arduino Plugin | Change of Device Screen living links 1-3 BC set position 2nd digit To Value 1 |
jun-16 15:48:02 | Warning | Dropping event callbacks due to full queue (Type: 16384) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:47:59 | Warning | Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates |
jun-16 15:47:47 | Arduino Plugin | Change of Device Screen living links 1-2 BC set position 1st digit To Value 0 |
jun-16 15:47:47 | Arduino Plugin | Change of Device Screen living links 1-1 Go to position To Value 1 |
jun-16 15:47:47 | Device Control | Device: 3 Arduino Plugin Screen living links 1-4 BC set position 3rd digit to On (1) by/from: CAPI Control Handler |
jun-16 15:47:47 | Device Control | Device: 3 Arduino Plugin Screen living links 1-3 BC set position 2nd digit to Off (0) by/from: CAPI Control Handler |
jun-16 15:47:47 | Device Control | Device: 3 Arduino Plugin Screen living links 1-2 BC set position 1st digit to On (1) by/from: CAPI Control Handler |
jun-16 15:47:47 | Device Control | Device: 3 Arduino Plugin Screen living links 1-1 Go to position to Off (0) by/from: CAPI Control Handler |
jun-16 15:47:24 | Event | Running script in background: C:/Program Files/Homeseer HS3/scripts/ZZZ Ontwikkeling/Test 8.vb |
jun-16 15:47:24 | Event | Event Trigger "ZZ ontwikkelomgeving Test event" |
Arduino 1.0.0.148
Homeseer 3.0.0.435
