Updates every 2 minutes
  • Updates every 2 minutes
    Hi Greg
    Why do I get these messages every two minutes?
    Jul-05 09:32:31 Arduino Plugin Updating Values on Board No: 3
    Jul-05 09:32:30 Arduino Plugin Updating pins on Board No: 3
    Jul-05 09:32:30 Arduino Plugin Connected to Board No:3 at ip address 192.168.0.18 Port No:8902
    Jul-05 09:32:30 Arduino Plugin Board 3 Version 1.0.0.145 and Plugin Version 1.0.0.147 are compatible.
    Jul-05 09:32:30 Arduino Plugin Connecting Board No:3 at ip address 192.168.0.18 Port No:8902
    Each time it does this, it triggers the relays on the attached relay board, thus tripping the Velux controller attached. What can I do to stop it happening? I have already disabled the auto-reconnect option.
    Cheers
    Scott
    Scott,
    This is the board resetting because of a problem. Can you please send me a debug so I can look at it and try and pin it down for you.
    Greig.
    Scripts =
    Various
      I've seen this kind of action with a flakey power supply to the board.
      Just wondering... what Velux controller are you're using?
        Hi Greg. I moved the board to a different location & the messages stopped! Don't know what was causing the problem - dead spot maybe...
        langnet - I'm connecting the NodeMCU to a relay board and that connects to a KLF200 - My plan is to test replacing the Relay board with some optocouplers as soon as I get them delivered.
        Cheers
        Scott
          Originally posted by enigmatheatre View Post
          Scott,
          Greig.
          Hi Greg - how do I get the debug? - ignore this!!
            Greg
            Sorry, it's still doing it - here's the degbug
              Hi Scott,
              Are the relays powered from there own power supply and not throught the board?
              The debug is not showing enough info so if you can enable debugging then wait 1min then connect your board then wait for it to cycle a couple of time then turn off debugging then send key the file again.
              Cheers.
              Greig.
              Sent from my SM-G950F using Tapatalk
              Scripts =
              Various
                Hi Greg
                OK, I have replaced the relay with Optocouplers and it's working great. I'm still getting the messages but cannot upload the debug file as I'm getting an error ("Upload failed due to failure writing temporary file"). I'll try later in case it's a problem with this forum server.
                I don't think updating the pins are changing the opto's so it's not actually causing any harm, so there's no rush
                Cheers
                Scott
