More commands
    More commands
    Hello.
    i have one question.
    Is possible nave more commands with the same switch?
    For example : if pull on switch for 2 seconds then....if pull on switch for 5 seconds then .....
    Yes, just use a homeseer timer. start it on the button press then stop it on release and trigger the events on the timer value.
    Event 1
    If the button is pressed then start the timer
    Event 2
    If the button is released
    and Timer < 2 sec
    then stop timer
    Do more stuff that you want
    Event 3
    and Timer > 2 sec
    and Timer < 5 sec
    then stop timer
    If timer > 10
    Stop timer
    This stops this timer rolling when not required.
    Repeat for all available times you need.
    Greig.
    Scripts =
    Various
      Works.
      Thank you, Greig
