OK. I have been able to create a new board, compile and upload to the NodeMCU. I will set this up for several 1-wire Temp sensors and let you know how that goes.
The Good News: I have been running with two 1-2wire DS18B20 temp sensors for several hours now and have not seen any timeout errors.
The Bad News: When I shut down HS3 and then restart HS3 and then go to the Arduino Plugin config page, I again start seeing the "Error=Exception in BuildConnectionButtons : Index was outside the bounds of the array." error message. On the config page the section that allows one to edit a board configuration is no longer there.
This is what that looks like after starting HS3.
If I delete the board and the 1-wire devices and then re-create them everything works great, until I shut down HS and restart.
Installed .165. When I enabled the plugin the first time it immediately recognized my Board 1 and everything came right up and connected. I'll let it run overnight and see how it looks tomorrow.
I have had version .165 running now for over 24 hours. I have two DS18B20 connected and everything is working great. No timeouts, no error of any sort. If I had more I would have them hooked up as well. I have another 10 on order but have not received them yet.
Greig -
I was talking to Randy and he said you were still looking for feedback on multiple 1-wire connection with .165. I now running multiple NodeMCU boards with up to 4 1-wire DS18B20 sensors. Since upgrading to .165 when you released it they are all running with NO ROM timeout errors. Thanks!
I used to have 11 DS18B20 temp sensors working on a dedicated Uno with ver 1.3X, daisy-chained AND star(s) configuration.
I unplugged the 1-wire totally when Uno where not supported after a major update.
Now running 1.66 I tried to plug the 1-wire to a pin of my general purpose Mega (Input/Outpus and relay board), but cannot have more than two DS18... working at the same time...
I tried changing the pull-up resistor with no success.
