Arduino IDE Upload Errors
    I'm working with a "Genuine" Arduino Uno. My first attempt at a working configuration using the plugin Version 1.0.0.131 was partially successful. Post config and install I was able to connect and control outputs, but received no response from test inputs (o.c. switch at device between Gnd & Pin 2,12,or 13) . I was also experiencing sporadic connection issues. My thought was the "Beta" Version 1.0.0.166 may solve my problems, it did not. Now after deleting all things Arduino V1.6.8 and starting over with V1.8.9 using all the same procedures as before the sketch will not upload. The Arduino IDE returns the following: (Any help or direction is greatly appreciated)
    Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator1\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator1\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_128129 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_204 -prefs=build.warn_data_percentage=75 -verbose C:\Program Files (x86)\Arduino\HomeseerBoard1\HomeseerBoard1.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator1\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator1\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10809 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_128129 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_204 -prefs=build.warn_data_percentage=75 -verbose C:\Program Files (x86)\Arduino\HomeseerBoard1\HomeseerBoard1.ino
    Using board 'uno' from platform in folder: C:\Users\Administrator1\AppData\Local\Arduino15\packages\ard uino\hardware\avr\1.6.8
    Using core 'arduino' from platform in folder: C:\Users\Administrator1\AppData\Local\Arduino15\packages\ard uino\hardware\avr\1.6.8
    WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
    WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
    WARNING: Category '' in library SoftwareSerial is not valid. Setting to 'Uncategorized'
    WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
    Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI\\SPI.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Dhcp.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Dns.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Ethernet2.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetClient.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetServer.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetUdp2.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Twitter.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\utility\\socket.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\utility\\w5500.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM\\SoftPWM.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\avr\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\megaavr\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\nrf52\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\sam\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\samd\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src\\stm32f4\\Servo.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\OneWire\\OneWire.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature\\DallasTemperat ure.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_ I2C.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire\\utility " "C:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire\\Wire.cp p" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire\\utility " "C:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire\\utility \\twi.c" -o nul
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\sketch\\HomeseerBoard1.ino.cpp.o"
    Compiling libraries...
    Compiling library "SPI"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\SPI\\SPI.cpp.o"
    Compiling library "Ethernet2-master"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Dhcp.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\Dhcp.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetClient.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\EthernetClient.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetUdp2.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\EthernetUdp2.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Twitter.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\Twitter.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Dns.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\Dns.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\EthernetServer.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\EthernetServer.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\cores\\arduino" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\variants\\standard" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SoftPWM" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Servo\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\OneWire" "-IC:\\Program Files (x86)\\Arduino\\libraries\\DallasTemperature" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Administrator1\\AppData\\Local\\Arduino15\\packa ges\\arduino\\hardware\\avr\\1.6.8\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\libraries\\Ethernet2-master\\src\\Ethernet2.cpp" -o "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_12 8129\\libraries\\Ethernet2-master\\Ethernet2.cpp.o"
    C:\Program Files (x86)\Arduino\libraries\Ethernet2-master\src\Ethernet2.cpp: In member function 'int EthernetClass::begin(uint8_t*)':
    C:\Program Files (x86)\Arduino\libraries\Ethernet2-master\src\Ethernet2.cpp:100:1: internal compiler error: Segmentation fault
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
    Using library SPI at version 1.0 in folder: C:\Users\Administrator1\AppData\Local\Arduino15\packages\ard uino\hardware\avr\1.6.8\libraries\SPI
    Using library Ethernet2-master at version 1.0 in folder: C:\Program Files (x86)\Arduino\libraries\Ethernet2-master
    Using library SoftPWM in folder: C:\Program Files (x86)\Arduino\libraries\SoftPWM (legacy)
    Using library Servo at version 1.1.3 in folder: C:\Program Files (x86)\Arduino\libraries\Servo
    Using library OneWire at version 2.3.2 in folder: C:\Program Files (x86)\Arduino\libraries\OneWire
    Using library DallasTemperature at version 3.7.6 in folder: C:\Program Files (x86)\Arduino\libraries\DallasTemperature
    Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal_I2C
    Using library Wire at version 1.0 in folder: C:\Users\Administrator1\AppData\Local\Arduino15\packages\ard uino\hardware\avr\1.6.8\libraries\Wire
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    Starts
    February 9, 2020
    Ends
    February 10, 2020
    I cannot tell from your post if you have had this working in the past. I do recommend v1.0.0.166, it is reliable and stable. It is important that the IDE and libraries are the correct versions. In case some of this is out of sync I would:
    • Make sure that you are running 1.0.0.166
    • Uninstall the IDE
    • Delete the entire c\Program Files (x86)\Arduino directory structure
    • Reinstall IDE 1.8.9
    • Make sure and add NodeMCU support if you are going to use them. This is outlined in the help file under “To add a NodeMCU board to the plugin:”
    • Download the libraries from the plug-in, unzip and copy them to the \Arduino\libraries directory
    • Configure your board, carefully considering the IP address and port. Let the plug-in suggest a MAC and use it. Download a sketch, upload it to a board.
      Hello rprade
      I've attached a screen shot of the Arduino IDE currently in use and also the HS3 profile below.
      I did have the Arduino plugin version v1.0.0.131 working partially (outputs but no inputs). For that
      reason I did perform all the steps you laid out, with the exception of the fifth step regarding "NodeMCU".
      I will read the procedure again and add that step.
      Thank you.
Name:	Ardino LDE 1.8.9.png
      Current Date/Time: 2/9/2020 2:41:08 PM
      System Uptime: 0 Days 3 Hours 58 Minutes 35 Seconds
      IP Address: 192.168.0.140
      Number of Devices: 151
      Number of Events: 66
      Available Threads: 800
      HSTouch Enabled: True
      Event Threads: 0
      Event Trigger Eval Queue: 0
      Device Exec Queue: 0
      HSTouch Event Queue: 0
      Email Send Queue: 0
      In Virtual Machine: No MFG: hewlett-packard
      Enabled Plug-Ins
      3.0.0.29: ADIO-100
      1.0.0.166: Arduino Plugin
      1.0.6890.36333: DeviceCompare
      5.0.0.59: Global Cache Pro
      3.0.0.117: LutronRA2
      3.0.1.252: Z-Wave
        The NodeMCU board support is only needed if you are going to use those boards. You have the correct IDE for .166. The sketch in your screenshot is not one from the plug-in. Are you building an API or standard sketch?
          rprade
          Maybe I'm missing something, but it sounds like the params requested are for a Wifi configuration when I'm setting this up
          with an Ethernet Shield on my LAN. Does this change your recommended setup?
            sorry
            Standard Sketch
              Originally posted by charlie468 View Post
              rprade
              Yes, you will need to select Arduino and not NodeMCU for the board Type on the plugin config page. It will then have only the network-based setup and not the WIFI setup you are seeing.
              1. After you set up your network settings you need to select the board number (I guess in your case 1) from the dropdown next to Download Sketch for board no:
              2. Then click the arrow to generate and download the sketch for that board. Then open the Arduino IDE and load that sketch you just downloaded.
              3. Next, make sure you have the correct board and comport selected in the IDE (I can see by the screenshot you have the correct board and you have com 5 set) then click the Right hand facing arrow at the top of the IDE to upload the sketch to the board.
              4. After upload, the board should connect to HS. If not then try and press the Disconnect button on the plugin config page then the connect button again to connect the board.
              If you have any problems upload your sketch to the board and tell me any errors you have in the log.
              Greig,
              Scripts =
              Various
                rprade
                You stated at the top you are using an UNO. If you are seeing WiFi setup, that is for a different board - NodeMCU. For an UNO it would be either IP or Com, type: Arduino or Arduino API, then select Board is UNO
                  rprade
                  My Overview:
                  Since Homeseer decided to no longer support the ADIO100s in my setup I thought at some time they
                  will no longer function reliably. To that end I looked to Arduino to fill that role. I purchased
                  the plugin, two Ethernet Shields an Uno and a Due board. (I don't know yet if the Due is compatible)
                  I started with the v1.0.0.131 plugin and installed Arduino v1.6.8 as recommended by the plugin.
                  The install / configuration was relatively painless and I was able to control outputs on the Uno as
                  per design, however I was unable to receive any input from the Uno (o.c. switch at device between
                  Gnd & Pin 2,12, or 13) at the HS3 Device Status Page. This added to the fact I was experiencing
                  sporadic connection issues led me to try Plugin v1.0.0.166 and Arduino v1.8.9 I deleted all things
                  Arduino started with a clean install, thought I followed all the same steps as in the previous setup
                  and when the sketch upload attempt completed I was left with the error I submitted.
                  My goal is to install the two boards in different locations in my system to monitor and interface with inputs,
                  and communicate with them via Ethernet.
                  Additional:
                  Both of my Ethernet Shields have defined MAC Addresses and I have fixed an I.P. Address to each in my router.
                  I verified both on my system and used these parameters in the plugin setup.
                    Thank you gentlemen. I will uninstall all things Arduino and make another clean start. The error presents when I perform the sketch upload process. If after a "from scratch" attempt I receive another error I will submit it here. I appreciate your help.
                      1 Remove all reference to Node MCU from Additional Boards Manager,
                      and set Tools-Board Type to "Arduino/Genuino Uno"
                      2 Completely Un-Installed Arduino IDE v1.8.9
                      3 Completely Un-Installed Arduino Plugin v1.0.0.166
                      4 Shut Down HS3
                      5 Reboot PC
                      6 Downloaded and installed new copy of v1.8.9 from Aruino
                      7 Restart HS3 and Re-Install Arduino Plugin v1.0.0.166
                      8 HS3 Arduino Plugin Config:
                      Added Board 1
                      Set Connection = IP / Type = Arduino / Selected Board is UNO
                      Set I.P. 192.168.0.146 / MAC A8:61:0A:AE:5D:00
                      Selected Ethernet Shield v2
                      Set Board no to 1 in Download Section
                      Download /Extract /Copy & Paste Arduino (individual) Libraries to
                      c:>Program Files(x86)>Arduino>Libraries
                      Download Sketch HomeseerBoard1 to Folder HomeseerBoard1 and Copy & Paste
                      it to c:>Program Files(x86)>Arduino
                      9 Open Arduino IDE v1.8.9 / Tools
                      Verify Board Type "Arduino/Genuino Uno"
                      Communication Port "Com5Arduion/Genuino Uno"
                      Open File / HomeseerBoard1 / HomeseerBoard1
                      Upload Sketch
                      ---- Error ----
                        Hello enigmatheatre,
                        I have continued to work at this upload issue and have found that the error message only presents when attempted on the machine running HS3.
                        If I perform the same process on another computer running Win10 64 I am able to complete the sketch upload ????? I'm going to keep after that.
                        Can you tell me if I should be able to communicate with other Arduino devices (beside Uno) from your plugin.
                        Charlie-
                          Charlie-
                          I would recommend the Arduino Mega with an ethernet shield or if you are running the beta version of the plugin the NodeMCU will connect with WIFI.
                          Greig.
                          Scripts =
                          Various
