I last upgraded the plugin and sketches about 2 years ago.
Just upgraded to current beta plugin and sketches.
PWM was working fine before with fade in and out, but was a relatively low PWM rate.
Now, the lights are flickering every couple of seconds (irregular intervals) up to 100% then 0% quickly before returning to a set level. THe effect is like when a florescent light is flicking on and off. What should I check? Would this be because I've got old devices in Homeseer, do they need to be upgraded?
Also If the Arduino loses network connection for a while, then it returns, the plugin does not auto connect. I have to click connect, and sometimes even that does not work, I have to restart HS3 for connection to restart.
I am using genuine Arduino Uno + genuine Ethernet shield, and also a genuine Arduino Ethernet. Auto connect is ticked on board setup.
Is this expected behaviour?
Cheers
Cheers
