It seems that when the Arduino plug in is turned on HS freezes. Events still take place but when a command is sent the device doesn't change state. When you manually click the on off button for a device nothing happens either. If I reboot HS it will work for a while 5-10 min then freezes again. When I turn the plug in off this doesn't happen.
Arduino overloading HS?
Are you using the API sketch? If so please post it.
GreigZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
