I'm having a strange problem using the 1..0.0.131 version of this plugin. I'm running a standard Uno with Ethernet shield (88000 or something like that) and have outputs and inputs configured. Running latest released HS3 version on a fresh Win 10 Pro install with disabled firewall. I performed the installation of everything (version of the Arduino software, etc...) to the letter of the install instructions posted with this plugin (on a fresh Arduino board)
I moved three out of four inputs to different floor and room assignments from their original 'Arduino Plugin' ones. Wired up some normally closed (contact closure) door sensors and motion sensor to the inputs (between the inputs and a common ground pin) and all was working well. The one input I was not using had nothing connected to it and it remained in the original Arduino plugin floor and room assignments. All outputs worked as normal.
This morning woke up and noticed the three hardwired inputs were all 'closed' or connected to ground and stayed that way, even when the door/motion was opened. What is weird is that when I went to the one input that was not used and manually connected it to ground via a wire at the board, it worked (was showing open, then closed when I touched the wire between its input and ground).
With the terminal board off (no I/O connections to the board) I had to remove the hardwired input pins from the plugin, re enter them (and not move them from their original floor and room assignments), reset the board (manually pushed the button) disabled then re-enabled the plugin, and now all the inputs are showing open correctly.
I'm going to leave the system running all day today with no I/O connected.
Are their any other troubleshooting hints I should try?
Thanks for the help!
BSR
UPDATE: System running for 2.5 hours. Manually tested each input by placing a wire between ground and each input. All working well. Left one pin attached to ground for continued testing.
Current Date/Time: 4/29/2020 8:13:29 AM
System Uptime: 0 Days 0 Hours 55 Minutes 16 Seconds
IP Address: 192.168.1.5
Number of Devices: 199
Number of Events: 18
Available Threads: 400
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
In Virtual Machine: No MFG: dell inc.
Enabled Plug-Ins
1.0.0.131: Arduino Plugin
2.0.48.0: BLSecurity
3.0.2.0: Z-Wave
BSR
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.2.0: Z-Wave
