Uno Wifi Rev2 issue with script compiling
  • avpman
    Originally posted by juanvaldes View Post
    The problem seems to be with the WIFI drivers being different than that on the the regular UNO. Did you get a chance to take a look, this is a nice simple board that would be great for attached monitoring. Please advise if you plan to write the routines for the Arduino Uno Wifi Rev. 2
    Same here, would like to use with Uno WiFi Rev 2 board. If not, please recommend a board known to work with the plugin that has WiFi. Thanks!
  • juanvaldes
  • RJS
    Did you ever get the Uno Wifi Rev 2 working?
    Robert
  • remtam
    I'm connecting using USB.
  • enigmatheatre
    OK, it compiles here for Uno and Unowifi. Are you trying to connect it with wifi or USB? I have not used that board and I think it needs special libraries for the wifi.
  • remtam
    Here is the sketch.
    I selected "Arduino" and I selected the Uno button
    Arduino to Homeseer 3 Plugin written by Enigma Theatre.
    V1.0.0.166 *Beta* *
    *******Do not Change any values below*******************
    //Global Variables
    #define ISIP 0
    #define BoardType 0
    #define Uno 1
    const byte BoardAdd = 4;
    byte Byte1, Byte2, Byte3;
    unsigned int Byte4, Byte5;
    char* Version = "1.0.0.166";
    bool IsConnected = false;
    byte AlivePin = 255;
    unsigned long LastAlive = 0;
    bool WaitForAck = false;
    int Available = 0;
    byte count = 0;
    #define Debug false
    #if BoardType == 2
    int PrevWiFiStatus = 0;
    void resetFunc() {
    #if Debug
    Serial.println(F("Reset"));
    #endif
    ESP.reset();
    #else
    void(* resetFunc) (void) = 0;
    #endif
    //******************************Ethernet Setup*****************************
    #if ISIP == 1
    #if BoardType == 2
    #include <ESP8266WiFi.h>
    #include <WiFiUdp.h>
    #include <ESP8266mDNS.h>
    #include <ArduinoOTA.h>
    char ssid[] = "TALKTALK73651A";
    char pass[] = "44749T8W";
    #else
    #include <SPI.h>
    #include <Ethernet.h>
    #include <EthernetUdp.h>
    #endif
    char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
    byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x04};
    IPAddress ip(192,168,1,7); //IP entered In HS config.
    const unsigned int localPort = 8903; //port entered In HS config.
    IPAddress HomeseerIP(192,168,1,3); //Homeseer IP address
    IPAddress gateway(192,168,1,1);
    IPAddress subnet(255,255,255,0);
    #if BoardType == 2
    WiFiUDP Udp;
    WiFiUDP SendPort;
    #else
    EthernetUDP Udp;
    #endif
    void UDPCheck() {
    Available = Udp.parsePacket();;
    if (Available)
    #if BoardType == 2
    if (Udp.remoteIP() != HomeseerIP) {
    HomeseerIP = Udp.remoteIP();
    Byte1 = Udp.parseInt();
    Udp.read();
    Byte2 = Udp.read();
    Udp.read();
    Byte3 = Udp.parseInt();
    Udp.read();
    Byte4 = Udp.parseInt();
    Udp.read();
    Byte5 = Udp.parseInt();
    DataEvent();
    #else
    Udp.read();
    Byte2 = Udp.read();
    Byte3 = Udp.parseInt();;
    Byte5 = Udp.parseInt();;
    DataEvent();
    #endif
    #endif
    //********************************Input Setup*******************************
    unsigned int debounceDelay = 30;
    byte NoOfInPins = 0;
    #if Uno == 1
    byte InPinArray[20] = { 255 };
    unsigned long lastDebounceTime [20] = { 0 };
    bool lastButtonState [20] = {LOW};
    bool buttonState[20] = {LOW};
    #else
    byte InPinArray[40] = { 255 };
    unsigned long lastDebounceTime [40] = { 0 };
    bool lastButtonState [40] = {LOW};
    bool buttonState[40] = {LOW};
    #endif
    static byte InputCount = 0;
    void InputCheck() {
    if (InputCount >= NoOfInPins ) {
    InputCount = 0;
    if (InPinArray[InputCount] < 255) {
    if (millis() < lastDebounceTime[InputCount]) {
    lastDebounceTime[InputCount] = millis();
    bool Inputpinread = (digitalRead(InPinArray[InputCount]));
    if (Inputpinread != lastButtonState[InputCount]) {
    if ((millis() - lastDebounceTime[InputCount]) > debounceDelay) {
    if (Inputpinread != buttonState[InputCount]) {
    buttonState[InputCount] = Inputpinread;
    Send(String(BoardAdd));
    Send(F(" I "));
    Send(String(InputCount + 1));
    Send(F(" "));
    Send(String(Inputpinread));
    Send();
    lastButtonState[InputCount] = Inputpinread;
    InputCount++;
    //*******************************Output toggle/flash****************************
    byte OutputCount = 0;
    #if Uno == 1
    unsigned long previousOutMillis[15] = {0};
    unsigned int OutputFlash[15] = { 0 };
    bool OutputState[15] = {LOW};
    byte OutPinArray[15] = { 255 };
    word OutputMillis[15];
    #else
    unsigned long previousOutMillis[40] = {0};
    unsigned int OutputFlash[40] = { 0 };
    bool OutputState[40] = {LOW};
    byte OutPinArray[40] = { 255 };
    word OutputMillis[40];
    #endif
    void OutputCheck() {
    if (millis() < previousOutMillis[OutputCount]) { // we wrapped around, lets just try again
    previousOutMillis[OutputCount] = millis();
    if (previousOutMillis[OutputCount] + OutputMillis[OutputCount] < millis() ) {
    if (OutPinArray[OutputCount] < 255 ) {
    // if the Output is off turn it on and vice-versa
    digitalWrite(OutPinArray[OutputCount], !OutputState[OutputCount]);
    OutputState[OutputCount] = !OutputState[OutputCount];
    if (OutputFlash[OutputCount] == 1) {
    OutputFlash[OutputCount] = 0;
    OutPinArray[OutputCount] = 255;
    previousOutMillis[OutputCount] = 0;
    OutputCount++;
    #if Uno == 1
    if (OutputCount == 20 ) {
    OutputCount = 0;
    #else
    if (OutputCount == 40 ) {
    OutputCount = 0;
    #endif
    return;
    //*******************************Analogue Setup****************************
    //#if Uno == 1
    //byte AnalogPinArray[5] = {255};
    //unsigned int AnalogStateArray[5];
    //unsigned long PrevAnalogeMillis[5];
    // int AnalogDelay[10];
    //#else
    byte AnalogPinArray[10] = {255};
    unsigned int AnalogStateArray[10];
    unsigned long PrevAnalogeMillis[10];
    unsigned int AnalogDelay[10] = {0};
    //#endif
    word AnalogInvert = 0;
    byte NoOfAnalogPins = 0;
    unsigned int AnalogueCount = 0;
    void AnalogCheck() {
    if (AnalogueCount >= NoOfAnalogPins) {
    AnalogueCount = 0;
    if (AnalogPinArray[AnalogueCount] < 255) {
    if (millis() < PrevAnalogeMillis[AnalogueCount]) { // we wrapped around, lets just try again
    PrevAnalogeMillis[AnalogueCount] = millis();
    if (AnalogDelay[AnalogueCount] + PrevAnalogeMillis[AnalogueCount] < millis()) {
    int pinread;
    pinread = analogRead(AnalogPinArray[AnalogueCount]);
    if (AnalogStateArray[AnalogueCount] != pinread) {
    AnalogStateArray[AnalogueCount] = pinread;
    Send(F(" A "));
    Send(String(AnalogueCount + 1));
    Send(F(" "));
    if (bitRead(AnalogInvert, AnalogueCount) == 1) {
    Send(String(map(AnalogStateArray[AnalogueCount], 0, 1023, 1023, 0)));
    Send();
    WaitForAck = true;
    else {
    Send(String(AnalogStateArray[AnalogueCount]));
    Send();
    WaitForAck = true;
    #if Debug
    Serial.print(F("AnalogueCount = "));
    Serial.print(AnalogueCount);
    Serial.print(F(", NoOfAnalogPins = "));
    Serial.print(NoOfAnalogPins);
    Serial.print(F(", PrevAnalogeMillis[AnalogueCount] = "));
    Serial.print(PrevAnalogeMillis[AnalogueCount]);
    Serial.print(F(", AnalogPinArray[AnalogueCount] = "));
    Serial.print(AnalogPinArray[AnalogueCount]);
    Serial.print(F(", AnalogDelay[AnalogueCount] = "));
    Serial.println(AnalogDelay[AnalogueCount]);
    #endif
    AnalogueCount++;
    return;
    //*****************************PWM Setup****************************
    #if BoardType == 0
    #include <SoftPWM.h>
    #endif
    //*****************************Servo Setup***************************
    #include <Servo.h>
    unsigned long lastServoMove = 0;
    bool ServoActive = false;
    Servo myservo[6];
    void ServoCheck() {
    if (800 + lastServoMove < millis() && ServoActive == true) {
    for (int i = 0; i < 6; i++) {
    myservo[i].detach();
    //***************************One Wire Setup**************************
    #include <OneWire.h>
    #include <DallasTemperature.h>
    byte OneWirePin = 255;
    byte TEMPERATURE_PRECISION = 9;
    DeviceAddress tempDeviceAddress;
    unsigned long lastTempRequest = 0;
    bool waitingForTempsGlobal = false;
    float Temps[15] = {0};
    unsigned long lastUpdated[15] = {0};
    bool OWStartup = false;
    void OneWireCheck() {
    if (OneWirePin < 255) {
    OneWire oneWire(OneWirePin);
    DallasTemperature sensors(&oneWire);
    if (OWStartup == false && millis() - lastTempRequest > 10000) {
    #if Debug
    Serial.print(F("OneWire Setup run with pin "));
    Serial.println(OneWirePin);
    #endif
    sensors.setResolution(TEMPERATURE_PRECISION);
    sensors.setWaitForConversion(false);
    if (sensors.isParasitePowerMode()) {
    sensors.setCheckForConversion(true);
    OWStartup = true;
    if (waitingForTempsGlobal && lastTempRequest + 1000 < millis() ) {
    sensors.begin();
    #if Debug
    Serial.println(F("conversionDelay passed"));
    #endif
    for (int i = 0; i < sensors.getDeviceCount(); i++) {
    if (millis() < lastUpdated[i]) { // we wrapped around, lets just try again
    lastUpdated[i] = millis();
    sensors.getAddress(tempDeviceAddress, i);
    float Temp = sensors.getTempC(tempDeviceAddress);
    #if Debug
    Serial.print(F("Device count = "));
    Serial.print(String(sensors.getDeviceCount()));
    Serial.print(F(", Device = "));
    Serial.print(String(tempDeviceAddress[i]));
    Serial.print(F(", sensors.getTempC = "));
    Serial.println(Temp);
    #endif
    if ((Temps[i] != Temp && sensors.validAddress(tempDeviceAddress)) || ( millis() - lastUpdated[i] >= 60000 && sensors.validAddress(tempDeviceAddress))) {
    Temps[i] = Temp;
    Send(F(" Rom "));
    for (uint8_t i = 0; i < 8; i++)
    if (tempDeviceAddress[i] < 16) Send("0");
    Send(String(tempDeviceAddress[i]));
    Send(F(" "));
    Send(String(Temp));
    Send();
    //WaitForAck = true;
    if (!waitingForTempsGlobal && millis() - lastTempRequest > 15000) {
    lastTempRequest = millis();
    waitingForTempsGlobal = true;
    sensors.requestTemperatures();
    #if Debug
    Serial.println(F("Requesting Temperatures"));
    #endif
    #include <LiquidCrystal_I2C.h>
    LiquidCrystal_I2C lcd(0x27, 4, 20);
    bool LCDInit = false;
    //**********************************Alive Check***********************************
    void AliveCheck() {
    if ( millis() - LastAlive < 40000 && IsConnected == true) { //if connected and data recieved within 40sec set Alive pin High.
    if (AlivePin < 255 ) {
    digitalWrite(AlivePin, HIGH);
    else if (millis() - LastAlive > 60000 && millis() - LastAlive < 60005 && IsConnected == true) { //if connected but no data recieved for 81sec reset Ack.
    WaitForAck = false;
    if (LCDInit == true ) {
    lcd.clear();
    lcd.setCursor(2, 1);
    lcd.print(F("Connection Error"));
    Send(F("Alive "));
    Send();
    else {
    if (AlivePin < 255 && millis() - LastAlive > 81000 && millis() - LastAlive < 81005) {
    if (LCDInit == true) {
    lcd.clear();
    lcd.print(F("Connection Failed"));
    Send(F("Connect "));
    Send();
    digitalWrite(AlivePin, LOW);
    if (millis() - LastAlive > 90000 && IsConnected == true) { //if connected but no data recieved for 90sec reset the board.
    lcd.setCursor(6, 2);
    lcd.print(F("Reseting"));
    delay(1000);
    resetFunc();
    bool UdpSend = false;
    //**********************************Send Data***********************************
    void Send(const String& Data)
    #if ISIP == 0
    Serial.print(Data);
    #else
    if (UdpSend == false) {
    UdpSend = true;
    Udp.beginPacket(HomeseerIP, 8888);
    Udp.print(Data);
    else {
    Udp.print(Data);
    #if Debug
    Serial.print(Data);//debug
    #endif
    #endif
    void Send()
    #if ISIP == 0
    Serial.println();
    #else
    Udp.endPacket();
    UdpSend = false;
    #if Debug
    Serial.print(F(", Sent to "));//debug
    Serial.println(HomeseerIP);//debug
    #endif
    #endif
    //*****************************Data Input********************************
    Used Data Input Cases
    D Disconnect
    r reset
    F PWM Fade Time Set
    P PWM State Set
    K Keepalive
    W OneWire Pin Set
    p PinMode set PWM
    a PinMode AnalogInverted Set
    A PinMode Analog Input Set
    H PinMode Alive
    h acknowledge Data
    I PinMode Digital Input Set
    L Lcd Display Data
    l Lcd Backlight control
    O PinMode Output Set
    d Input debounceDelay time set
    S Servo set Pos
    s PinMode Servo set
    C Connect request
    c Connection established - reUdp current status
    X Board PinMode Reset
    void DataEvent() {
    if (Byte1 == BoardAdd) {
    LastAlive = millis();//Reset the Alive timer if board Data recieved
    #if Debug
    Serial.print(Byte2);//debug
    Serial.print(",");
    Serial.print(Byte3);
    Serial.print(",");
    Serial.print(Byte4);
    Serial.print(",");
    Serial.println(Byte5);
    #endif
    switch (Byte2) {
    case 'X':
    #if Debug
    Serial.println(F("Pin Reset Recieved"));
    #endif
    NoOfInPins = 0;
    NoOfAnalogPins = 0;
    OneWirePin = 255;
    break;
    case 'c':
    #if Debug
    Serial.println(F("Sending Pin Values"));
    Serial.print(F("NoOfInPins = "));
    Serial.println(NoOfInPins);
    #endif
    byte pinread;
    for (count = 0; count < NoOfInPins; count++) {
    pinread = digitalRead(InPinArray[count]);
    Send(F(" I "));
    Send(String(count + 1));
    Send(F(" "));
    Send(String(pinread));
    Send();
    lastButtonState[count] = pinread;
    #if Debug
    Serial.println(F("IsConnected = true"));
    #endif
    IsConnected = true;
    break;
    case 'C':
    #if Debug
    Serial.println(F("Recieved C"));
    #endif
    lcd.clear();
    lcd.setCursor(5, 0);
    lcd.print(F("Board No:"));
    lcd.print(BoardAdd);
    lcd.setCursor(5, 1);
    lcd.print(F("V"));
    lcd.print(Version);
    lcd.setCursor(5, 2);
    lcd.print(F("Connecting"));
    lcd.setCursor(0, 3);
    lcd.print(F(" HS "));
    #if ISIP
    lcd.print(Udp.remoteIP());
    #endif
    // delay(2000);
    #if Debug
    Serial.println(F("Sending Version"));
    #endif
    Send(F("Version "));
    Send(F(" "));
    Send(String(Version));
    Send(F(" HS3"));
    Send();
    delay(1000);
    #if Debug
    Serial.println(F("Sending Connected"));
    #endif
    Send(F("Connected "));
    Send();
    // delay(100);
    lcd.print(F("Connected "));
    // delay(1000);
    // lcd.clear();
    break;
    case 'S':
    myservo[Byte3 - 1].attach(Byte4);
    myservo[Byte3 - 1].write(Byte5);
    lastServoMove = millis();
    ServoActive = true;
    #if Debug
    Serial.print(F("Servo No:"));
    Serial.print(F(", Pin No:"));
    Serial.print(F(", Set to "));
    #endif
    break;
    case 'd':
    #if Debug
    Serial.println(F("debounceDelay Setup recieved"));
    #endif
    debounceDelay = Byte4;
    break;
    case 'l':
    if (LCDInit == false) {
    #if Debug
    Serial.println(F("LCD int display"));
    #endif
    lcd.init(); // initialize the lcd
    lcd.init();
    LCDInit = true;
    lcd.backlight();
    lcd.clear();
    lcd.print(F("V"));
    lcd.print(Version);
    lcd.setCursor(2, 2);
    lcd.print(F("Initializing LCD"));
    // delay(3000);
    // lcd.clear();
    if (Byte3 == 0) {
    lcd.noBacklight();
    if (Byte3 == 1) {
    lcd.backlight();
    if (Byte3 == 2) {
    lcd.clear();
    break;
    case 'L':
    #if Debug
    Serial.println(F("LCD Value update"));
    #endif
    lcd.init();
    LCDInit = true;
    lcd.setCursor(0, Byte3 - 1);
    #if ISIP == 1
    Udp.read();
    Available = (Available - 9);
    for (count = 1; count < Available ; count++) {
    lcd.write(Udp.read());
    #else
    Serial.read();
    Available = (Available - 11);
    lcd.write(Serial.read());
    #endif
    break;
    case 'o':
    //Change state , one flash
    pinMode(Byte3, OUTPUT);
    digitalWrite(Byte3, !OutputState[Byte5 - 1]);
    previousOutMillis[Byte5 - 1] = millis();
    OutputMillis[Byte5 - 1] = Byte4;
    OutPinArray[Byte5 - 1] = Byte3;
    OutputFlash[Byte5 - 1] = 1;
    OutputState[Byte5 - 1] = !OutputState[Byte5 - 1];
    #if Debug
    Serial.println(F("One flash Recieved"));//debug
    Serial.print(F("Values"));
    Serial.print(F(", OutPinArray = "));
    Serial.print(F(", OutputMillis = "));
    Serial.print(F(", Index = "));
    #endif
    break;
    case 'O':
    if (Byte4 > 1) {//Blink
    #if Debug
    Serial.println(F("Blink Recieved"));//debug
    #endif
    OutputFlash[Byte5 - 1] = 0;
    else
    { //Toggle
    Serial.println(F("Output Change state or Toggle Recieved"));//debug
    Serial.print(F(", Pin = "));
    Serial.print(F(", Value = "));
    digitalWrite(Byte3, Byte4);
    OutPinArray[Byte5 - 1] = 255;
    previousOutMillis[Byte5 - 1] = 0;
    OutputState[Byte5 - 1] = Byte4;
    break;
    case 'H':
    #if Debug
    Serial.println(F("Alive Pin Setup Recieved"));
    #endif
    AlivePin = Byte3;
    break;
    case 'h':
    WaitForAck = false;
    break;
    case 'I':
    #if Debug
    Serial.print(F("Input Pin Setup"));
    Serial.print(F(", Byte3 = "));
    #endif
    pinMode(Byte4, INPUT_PULLUP);
    if (Byte3 > NoOfInPins) {
    NoOfInPins = Byte3;
    Serial.print(F(", NoOfInPins set to = "));
    InPinArray[Byte3 - 1] = Byte4;
    #if Debug
    Serial.print(F(", NoOfInPins = "));
    #endif
    break;
    case 'A':
    #if Debug
    Serial.println(F("Analog Setup Recieved"));
    Serial.print(F("Byte5 = "));
    #endif
    pinMode(Byte4, INPUT);
    if (Byte3 > NoOfAnalogPins) {
    NoOfAnalogPins = Byte3;
    AnalogDelay[Byte3 - 1] = Byte5;
    AnalogPinArray[Byte3 - 1] = Byte4;
    PrevAnalogeMillis[Byte3 - 1] = 0;
    break;
    case 'a':
    #if Debug
    Serial.println(F("Analog Setup Value Recieved"));
    #endif
    bitWrite(AnalogInvert, Byte3 - 1, Byte4);
    break;
    case 'W':
    #if Debug
    Serial.println(F("Onewire Setup Recieved"));
    #endif
    if (OneWirePin != Byte3) {
    OneWirePin = Byte3;
    lastTempRequest = millis() - 30000;
    if (TEMPERATURE_PRECISION != Byte4) {
    TEMPERATURE_PRECISION = Byte4;
    #if Debug
    Serial.print(F("TEMPERATURE_PRECISION = "));
    Serial.println(TEMPERATURE_PRECISION);
    #endif
    break;
    case 'K':
    #if Debug
    Serial.println(F("Keep Alive Recieved"));
    #endif
    Send(F("Alive "));
    Send();
    break;
    #if BoardType == 0
    case 'P':
    SoftPWMSet(Byte3, Byte4);
    #if Debug
    Serial.print(F("PWM Value Set = "));//debug
    Serial.println(Byte3);
    #endif
    break;
    case 'F':
    SoftPWMSetFadeTime(Byte3, Byte4, Byte4);
    #if Debug
    Serial.print(F("PWM Time Set = "));//debug
    #endif
    break;
    #endif
    case 'r':
    lcd.clear();
    lcd.setCursor(6, 1);
    delay(200);
    resetFunc();
    break;
    case 'D':
    #if Debug
    Serial.println(F("Disconnect Recieved"));
    #endif
    lcd.clear();
    lcd.setCursor(4, 1);
    lcd.print(F("Disconnected"));
    digitalWrite(AlivePin, LOW );
    break;
    #if ISIP == 0
    //*****************************Serial Event*********************************
    void serialEvent() {
    while (Serial.available() > 0) {
    delay(17);
    Available = Serial.available();
    Byte1 = Serial.parseInt();
    Serial.read();
    Byte2 = Serial.read();
    Byte3 = Serial.parseInt();
    Byte4 = Serial.parseInt();
    Byte5 = Serial.parseInt();
    DataEvent();
    #endif
    //*****************************Setup Void*********************************
    void setup() {
    #if Debug
    Serial.begin(115200);
    Serial.println("debug Start......");//debug
    #endif
    #if BoardType == 2
    PrevWiFiStatus = 0;
    #else
    SoftPWMBegin();
    #endif
    #if ISIP == 1
    #if BoardType == 2
    WiFi.begin(ssid, pass);
    WiFi.config(ip, gateway, subnet);
    OTA();
    WiFi.mode(WIFI_STA);
    while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    WiFiStatus();
    #else
    Ethernet.begin(mac, ip, gateway, gateway, subnet);
    #endif
    Udp.begin(localPort);
    Udp.setTimeout(0);
    #else
    Serial.flush();
    Serial.setTimeout(0);
    #endif
    //#############Reset Varibles########
    //Reset Inputs
    NoOfInPins = 0;
    for (count = 0; count < (sizeof(InPinArray) / sizeof(InPinArray[0])); count++) {
    InPinArray[count] = 255;
    lastDebounceTime [count] = 0;
    lastButtonState [count] = LOW;
    buttonState[count] = LOW;
    //Reset Outputs
    for (count = 0; count < (sizeof(OutPinArray) / sizeof(OutPinArray[0])); count++) {
    previousOutMillis[count] = 0;
    OutputFlash[count] = 0;
    OutputState[count] = LOW;
    OutPinArray[count] = 255;
    OutputMillis[count] = 0;
    //Reset Analog
    NoOfAnalogPins = 0;
    AnalogueCount = 0;
    for (count = 0; count < (sizeof(AnalogPinArray) / sizeof(AnalogPinArray[0])); count++) {
    AnalogPinArray[count] = 255;
    AnalogStateArray[count] = 0;
    PrevAnalogeMillis[count] = 0;
    AnalogDelay[count] = 0;
    //Reset Onewire
    OneWirePin = 255;
    delay(1500);
    Send();
    //*******************************OTA Update*************************
    void OTA() {
    #if BoardType == 2
    char OTAName[50];
    sprintf(OTAName, "Homeseer Board:%02i", BoardAdd );
    ArduinoOTA.setHostname(OTAName);
    ArduinoOTA.onStart([]() {
    lcd.clear();
    lcd.print(F("Performing"));
    lcd.print(F("OTA Update"));
    ArduinoOTA.onEnd([]() {
    delay(1000);
    lcd.clear();
    lcd.print(F("Complete"));
    lcd.setCursor(3, 3);
    lcd.print(F("Please Wait..."));
    delay(1000);
    ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    lcd.setCursor(4, 3);
    lcd.print(F("Progress:"));
    lcd.setCursor(13, 3);
    lcd.print(progress / (total / 100));
    lcd.print(F("%"));
    ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    lcd.clear();
    lcd.print(F("OTA Error:"));
    if (error == OTA_AUTH_ERROR) lcd.print(F("Auth Failed"));
    else if (error == OTA_BEGIN_ERROR) lcd.print(F("Begin Failed"));
    else if (error == OTA_CONNECT_ERROR) lcd.print(F("Connect Failed"));
    else if (error == OTA_RECEIVE_ERROR) lcd.print(F("Receive Failed"));
    else if (error == OTA_END_ERROR) lcd.print(F("End Failed"));
    ArduinoOTA.begin();
    #endif
    #if BoardType == 2
    void WiFiStatus() {
    if (PrevWiFiStatus - 10 > WiFi.RSSI() || PrevWiFiStatus + 10 < WiFi.RSSI()) {
    Send(F("WiFi "));
    Send(" ");
    Send(String(WiFi.RSSI()));
    Send();
    PrevWiFiStatus = WiFi.RSSI();
    #endif
    //*****************************Loop Void*********************************
    void loop() {
    #if ISIP == 1
    UDPCheck();
    #if BoardType == 2
    ArduinoOTA.handle();
    #endif
    #endif
    AliveCheck();
    if (IsConnected == true)
    #if BoardType == 2
    WiFiStatus();
    #endif
    InputCheck();
    OutputCheck();
    AnalogCheck();
    OneWireCheck();
    #if BoardType == 0
    ServoCheck();
    #endif
    yield();
    //****************************************End***************** *********************************
  • enigmatheatre
    Sorry I missed this post. I have not tried the wifi Uno with this and am not sure if it will work without modification to the sketch after you download it. What board type do you have it set to? Can you post the sketch?
  • remtam
    started a topic Uno Wifi Rev2 issue with script compiling
    I think think is something simple and obvious but when I try to compile the downloaded script for this Uno Wifi Rev2, I get a bunch of errors as follows :
    In file included from C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:27:0:
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp: In function 'void TIMER2_COMPA_vect()':
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:34:36: warning: 'TIMER2_COMPA_vect' appears to be a misspelled 'signal' handler, missing '__vector' prefix [-Wmisspelled-isr]
    #define SOFTPWM_TIMER_INTERRUPT TIMER2_COMPA_vect
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:70:5: note: in expansion of macro 'SOFTPWM_TIMER_INTERRUPT'
    ISR(SOFTPWM_TIMER_INTERRUPT)
    In file included from C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:29:0:
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp: In function 'void SoftPWMBegin(uint8_t)':
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:37:3: error: 'TIFR2' was not declared in this scope
    TIFR2 = (1 << TOV2); /* clear interrupt flag */ \
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:156:3: note: in expansion of macro 'SOFTPWM_TIMER_INIT'
    SOFTPWM_TIMER_INIT(SOFTPWM_OCR);
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:37:3: note: suggested alternative: 'TIMERB2'
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:37:17: error: 'TOV2' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:37:17: note: suggested alternative: 'TCB2'
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:38:3: error: 'TCCR2B' was not declared in this scope
    TCCR2B = (1 << CS21); /* start timer (ck/8 prescalar) */ \
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:38:3: note: suggested alternative: 'TCB2'
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:38:18: error: 'CS21' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:39:3: error: 'TCCR2A' was not declared in this scope
    TCCR2A = (1 << WGM21); /* CTC mode */ \
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:39:3: note: suggested alternative: 'TCB2'
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:39:18: error: 'WGM21' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:40:3: error: 'OCR2A' was not declared in this scope
    OCR2A = (ocr); /* We want to have at least 30Hz or else it gets choppy */ \
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:41:3: error: 'TIMSK2' was not declared in this scope
    TIMSK2 = (1 << OCIE2A); /* enable timer2 output compare match interrupt */ \
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:41:3: note: suggested alternative: 'TIMERB2'
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:41:18: error: 'OCIE2A' was not declared in this scope
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp: In function 'void SoftPWMSet(int8_t, uint8_t, uint8_t)':
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:35:37: error: 'TCNT2' was not declared in this scope
    #define SOFTPWM_TIMER_SET(val) (TCNT2 = (val))
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:205:5: note: in expansion of macro 'SOFTPWM_TIMER_SET'
    SOFTPWM_TIMER_SET(0);
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM_timer.h:35:37: note: suggested alternative: 'TCB2'
    exit status 1
    Error compiling for board Arduino Uno WiFi Rev2.
    Clearly its having issues with the SoftPWM library. I downloaded the library files again and copied them into the folder as I had before, but no change.
    This is a new Uno Wifi Rev2 board. I have compiled and loaded a few other scripts to it and it was fine.
    As I said, I suspect its something stupid/simple......
