HS3 Arduino plugin on HS4
    #16
    Have you checked your AV and Firewall?
    Scripts =
    Various
      #17
      I can ping fine from the HS to the boards and the firewall is off. Thanks for following up with me so quickly.
        #18
        can you do me a full debug? enable it in the plugin settings then try and connect a board then leave the plugin for 5 min, turn off debugging then send me the file.
        Scripts =
        Various
          #19
          I appreciated all your help, I finally upgrade to the same machine and it is working. Although the other machine had the firewall off, was still blocking those boards. Again, thanks for your fast response.
            #20
            Good news. Have fun.
            Scripts =
            Various
              #21
              I bought the hs4 version of this plugin, but reverted back to hs3 for now. Any way to use the hs3 plugin until hs4 is running more smoothly?
                #22
                unfortunately, the licence is only for the HS4 version and not backwards compatible. What problems are you having with HS4 as I have it running here without problems?
                Scripts =
                Various
                  #23
                  Some older plugins and generally stability issues, because of WAF I do not want to convert my 150+ device and 8+ plugins over just yet. Would still be great to able to use this plugin. I understand one would get free HS4 license if HS3 license was purchased now? Would not be too different the other way around, would it? Also, eventually I will of course revert over to HS4.
