Updating values on Board No: 2 - why is this every X minutes ?
    I am using a arduino mega as a pwm / dimmer / controller for the lights in my workshop.
    Everything is actually working just fine, i was hoping that the lights would come on at the same time since they all have there own pwm pin.
    But when i turn the lights on its like they are old fluoresent lights with starters.
    Anyway, this is not really a problem since they dim and go on/off.
    What i did notice every X minutes is this :
    Click image for larger version  Name:	4wkVkWY.jpg Views:	0 Size:	334.0 KB ID:	1422243
    I have turned the debug log on but i can't see any disconnects from the board.
    This looks like that this is what happens, because when i press disconnect in homeseer and connect right after it this pin update cycle starts.
    The few errors you see in the log are from me pressing disconnect/connect.
    What i did notice is the relays are not updating, it seems like the PWM assinged pins are giving this response by turning them off/on in a sort of cycle mode.
    The lights go off/on as well in my workshop and while working this is quite anoying .
    ***************************************LOG****************** ****************************
    27/9/2020 ,14:44:13.918 Data Received:1 I 5 1
    27/9/2020 ,14:44:13.919 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:13.921 Board1, Input:5, Value:1
    27/9/2020 ,14:44:13.924 Running Send to port, Data = h
    27/9/2020 ,14:44:13.925 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:17.096 Data Received:1 I 5 0
    27/9/2020 ,14:44:17.097 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:17.102 Board1, Input:5, Value:0
    27/9/2020 ,14:44:17.105 Running Send to port, Data = h
    27/9/2020 ,14:44:17.106 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:33.504 Data Received:1 I 5 1
    27/9/2020 ,14:44:33.506 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:33.514 Board1, Input:5, Value:1
    27/9/2020 ,14:44:33.520 Running Send to port, Data = h
    27/9/2020 ,14:44:33.523 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:34.321 postBackProc id=BoardsDropList&BoardsDropList=2
    27/9/2020 ,14:44:34.323 Board Tab 2 Selected
    27/9/2020 ,14:44:34.324 Calling BuildBoardSetupTab With Param Board = 2, NoPopulate = False
    27/9/2020 ,14:44:34.391 Lcd ref = -1
    27/9/2020 ,14:44:34.395 Exit BuildBoardSetupTab with Param Board = 2
    27/9/2020 ,14:44:35.035 Data Received:1 I 6 1
    27/9/2020 ,14:44:35.037 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:35.045 Board1, Input:6, Value:1
    27/9/2020 ,14:44:35.051 Running Send to port, Data = h
    27/9/2020 ,14:44:35.053 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:36.673 Data Received:1 I 5 0
    27/9/2020 ,14:44:36.674 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:36.677 Board1, Input:5, Value:0
    27/9/2020 ,14:44:36.681 Running Send to port, Data = h
    27/9/2020 ,14:44:36.681 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:36.782 Data Received:1 I 5 1
    27/9/2020 ,14:44:36.783 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:36.793 Board1, Input:5, Value:1
    27/9/2020 ,14:44:36.798 Running Send to port, Data = h
    27/9/2020 ,14:44:36.800 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:36.926 postBackProc &id=Disconnect&Disconnect=Submit
    27/9/2020 ,14:44:36.930 Running Send to port, Data = D
    27/9/2020 ,14:44:36.933 Sent to IP:10.0.0.17 Port No:8901 = 2 D ,Disconnect Command
    27/9/2020 ,14:44:36.948 Disconnected from Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:44:38.207 Data Received:1 I 6 0
    27/9/2020 ,14:44:38.210 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:38.222 Board1, Input:6, Value:0
    27/9/2020 ,14:44:38.236 Running Send to port, Data = h
    27/9/2020 ,14:44:38.239 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:38.532 Data Received:1 I 6 1
    27/9/2020 ,14:44:38.532 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:38.537 Board1, Input:6, Value:1
    27/9/2020 ,14:44:38.539 Running Send to port, Data = h
    27/9/2020 ,14:44:38.540 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:39.748 postBackProc &id=Connect&Connect=Submit
    27/9/2020 ,14:44:39.750 ComNoArr = 1001 , ComPortEnum.Ethernet.ToString() = Ethernet , BoardIPArr = 10.0.0.17 , BoardPortArr = 8901
    27/9/2020 ,14:44:39.752 Connecting Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:44:39.753 Running Send to port, Data = C
    27/9/2020 ,14:44:39.754 Sent to IP:10.0.0.17 Port No:8901 = 2 C ,Connect Command
    27/9/2020 ,14:44:39.840 Data Received:1 I 5 0
    27/9/2020 ,14:44:39.841 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:39.844 Board1, Input:5, Value:0
    27/9/2020 ,14:44:39.847 Running Send to port, Data = h
    27/9/2020 ,14:44:39.848 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:40.287 Data Received:Version 2 1.0.0.166 HS3
    27/9/2020 ,14:44:40.307 Board 2 Version 1.0.0.166 and Plugin Version 1.0.0.166 are compatible.
    27/9/2020 ,14:44:41.702 Data Received:1 I 6 0
    27/9/2020 ,14:44:41.703 Timer 1 Reset Loc 1
    27/9/2020 ,14:44:41.705 Board1, Input:6, Value:0
    27/9/2020 ,14:44:41.709 Running Send to port, Data = h
    27/9/2020 ,14:44:41.713 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:44:42.140 Data Received:Connected 2
    27/9/2020 ,14:44:42.142 Connected to Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:44:42.144 Updating pins on Board No: 2
    27/9/2020 ,14:44:42.145 Running Send to port, Data = X
    27/9/2020 ,14:44:42.146 Sent to IP:10.0.0.17 Port No:8901 = 2 X ,Pin Reset Command
    27/9/2020 ,14:44:42.242 Updating values on Board No: 2
    27/9/2020 ,14:44:42.246 Running Send to port, Data = O 32 0 1
    27/9/2020 ,14:44:42.250 Sent to IP:10.0.0.17 Port No:8901 = 2 O 32 0 1 ,Output Set Command
    27/9/2020 ,14:44:42.255 Running Send to port, Data = O 33 0 2
    27/9/2020 ,14:44:42.259 Sent to IP:10.0.0.17 Port No:8901 = 2 O 33 0 2 ,Output Set Command
    27/9/2020 ,14:44:42.263 Running Send to port, Data = O 34 1 3
    27/9/2020 ,14:44:42.267 Sent to IP:10.0.0.17 Port No:8901 = 2 O 34 1 3 ,Output Set Command
    27/9/2020 ,14:44:42.271 Running Send to port, Data = O 35 1 4
    27/9/2020 ,14:44:42.275 Sent to IP:10.0.0.17 Port No:8901 = 2 O 35 1 4 ,Output Set Command
    27/9/2020 ,14:44:42.279 Running Send to port, Data = O 36 0 5
    27/9/2020 ,14:44:42.281 Sent to IP:10.0.0.17 Port No:8901 = 2 O 36 0 5 ,Output Set Command
    27/9/2020 ,14:44:42.284 Running Send to port, Data = O 37 0 6
    27/9/2020 ,14:44:42.286 Sent to IP:10.0.0.17 Port No:8901 = 2 O 37 0 6 ,Output Set Command
    27/9/2020 ,14:44:42.288 Running Send to port, Data = O 38 0 7
    27/9/2020 ,14:44:42.290 Sent to IP:10.0.0.17 Port No:8901 = 2 O 38 0 7 ,Output Set Command
    27/9/2020 ,14:44:42.293 Running Send to port, Data = P 9 0
    27/9/2020 ,14:44:42.294 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 0 ,PWM Command
    27/9/2020 ,14:44:42.400 Running Send to port, Data = F 9 0
    27/9/2020 ,14:44:42.404 Sent to IP:10.0.0.17 Port No:8901 = 2 F 9 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:42.507 Running Send to port, Data = P 9 255
    27/9/2020 ,14:44:42.509 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 255 ,PWM Command
    27/9/2020 ,14:44:42.512 Running Send to port, Data = P 8 0
    27/9/2020 ,14:44:42.514 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 0 ,PWM Command
    27/9/2020 ,14:44:42.624 Running Send to port, Data = F 8 0
    27/9/2020 ,14:44:42.627 Sent to IP:10.0.0.17 Port No:8901 = 2 F 8 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:42.732 Running Send to port, Data = P 8 255
    27/9/2020 ,14:44:42.736 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 255 ,PWM Command
    27/9/2020 ,14:44:42.740 Running Send to port, Data = P 7 0
    27/9/2020 ,14:44:42.744 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 0 ,PWM Command
    27/9/2020 ,14:44:42.849 Running Send to port, Data = F 7 0
    27/9/2020 ,14:44:42.853 Sent to IP:10.0.0.17 Port No:8901 = 2 F 7 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:42.957 Running Send to port, Data = P 7 255
    27/9/2020 ,14:44:42.961 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 255 ,PWM Command
    27/9/2020 ,14:44:42.965 Running Send to port, Data = P 14 0
    27/9/2020 ,14:44:42.969 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 0 ,PWM Command
    27/9/2020 ,14:44:43.073 Running Send to port, Data = F 14 0
    27/9/2020 ,14:44:43.077 Sent to IP:10.0.0.17 Port No:8901 = 2 F 14 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:43.182 Running Send to port, Data = P 14 255
    27/9/2020 ,14:44:43.186 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 255 ,PWM Command
    27/9/2020 ,14:44:43.190 Running Send to port, Data = P 15 0
    27/9/2020 ,14:44:43.194 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 0 ,PWM Command
    27/9/2020 ,14:44:43.299 Running Send to port, Data = F 15 0
    27/9/2020 ,14:44:43.302 Sent to IP:10.0.0.17 Port No:8901 = 2 F 15 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:43.406 Running Send to port, Data = P 15 255
    27/9/2020 ,14:44:43.410 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 255 ,PWM Command
    27/9/2020 ,14:44:43.415 Running Send to port, Data = P 16 0
    27/9/2020 ,14:44:43.422 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 0 ,PWM Command
    27/9/2020 ,14:44:43.524 Running Send to port, Data = F 16 0
    27/9/2020 ,14:44:43.528 Sent to IP:10.0.0.17 Port No:8901 = 2 F 16 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:43.632 Running Send to port, Data = P 16 255
    27/9/2020 ,14:44:43.637 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 255 ,PWM Command
    27/9/2020 ,14:44:43.640 Running Send to port, Data = P 17 0
    27/9/2020 ,14:44:43.644 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 0 ,PWM Command
    27/9/2020 ,14:44:43.747 Running Send to port, Data = F 17 0
    27/9/2020 ,14:44:43.750 Sent to IP:10.0.0.17 Port No:8901 = 2 F 17 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:43.855 Running Send to port, Data = P 17 255
    27/9/2020 ,14:44:43.859 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 255 ,PWM Command
    27/9/2020 ,14:44:43.863 Running Send to port, Data = P 18 0
    27/9/2020 ,14:44:43.866 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 0 ,PWM Command
    27/9/2020 ,14:44:43.971 Running Send to port, Data = F 18 0
    27/9/2020 ,14:44:43.975 Sent to IP:10.0.0.17 Port No:8901 = 2 F 18 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:44.076 Running Send to port, Data = P 18 255
    27/9/2020 ,14:44:44.081 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 255 ,PWM Command
    27/9/2020 ,14:44:44.085 Running Send to port, Data = P 19 0
    27/9/2020 ,14:44:44.089 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 0 ,PWM Command
    27/9/2020 ,14:44:44.190 Running Send to port, Data = F 19 0
    27/9/2020 ,14:44:44.192 Sent to IP:10.0.0.17 Port No:8901 = 2 F 19 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:44.293 Running Send to port, Data = P 19 255
    27/9/2020 ,14:44:44.294 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 255 ,PWM Command
    27/9/2020 ,14:44:44.295 Running Send to port, Data = P 20 0
    27/9/2020 ,14:44:44.296 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 0 ,PWM Command
    27/9/2020 ,14:44:44.402 Running Send to port, Data = F 20 0
    27/9/2020 ,14:44:44.406 Sent to IP:10.0.0.17 Port No:8901 = 2 F 20 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:44.509 Running Send to port, Data = P 20 255
    27/9/2020 ,14:44:44.511 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 255 ,PWM Command
    27/9/2020 ,14:44:44.513 Running Send to port, Data = P 21 0
    27/9/2020 ,14:44:44.515 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 0 ,PWM Command
    27/9/2020 ,14:44:44.618 Running Send to port, Data = F 21 0
    27/9/2020 ,14:44:44.620 Sent to IP:10.0.0.17 Port No:8901 = 2 F 21 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:44.723 Running Send to port, Data = P 21 255
    27/9/2020 ,14:44:44.725 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 255 ,PWM Command
    27/9/2020 ,14:44:44.728 Running Send to port, Data = P 22 0
    27/9/2020 ,14:44:44.730 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 0 ,PWM Command
    27/9/2020 ,14:44:44.833 Running Send to port, Data = F 22 1286
    27/9/2020 ,14:44:44.835 Sent to IP:10.0.0.17 Port No:8901 = 2 F 22 1286 ,PWM Fade Time Command
    27/9/2020 ,14:44:44.937 Running Send to port, Data = P 22 255
    27/9/2020 ,14:44:44.938 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 255 ,PWM Command
    27/9/2020 ,14:44:44.939 Running Send to port, Data = P 24 0
    27/9/2020 ,14:44:44.941 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 0 ,PWM Command
    27/9/2020 ,14:44:45.043 Running Send to port, Data = F 24 2375
    27/9/2020 ,14:44:45.045 Sent to IP:10.0.0.17 Port No:8901 = 2 F 24 2375 ,PWM Fade Time Command
    27/9/2020 ,14:44:45.147 Running Send to port, Data = P 24 255
    27/9/2020 ,14:44:45.148 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 255 ,PWM Command
    27/9/2020 ,14:44:45.150 Running Send to port, Data = P 25 0
    27/9/2020 ,14:44:45.151 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 0 ,PWM Command
    27/9/2020 ,14:44:45.256 Running Send to port, Data = F 25 0
    27/9/2020 ,14:44:45.259 Sent to IP:10.0.0.17 Port No:8901 = 2 F 25 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:45.364 Running Send to port, Data = P 25 255
    27/9/2020 ,14:44:45.368 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 255 ,PWM Command
    27/9/2020 ,14:44:45.372 Running Send to port, Data = P 26 0
    27/9/2020 ,14:44:45.376 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 0 ,PWM Command
    27/9/2020 ,14:44:45.481 Running Send to port, Data = F 26 0
    27/9/2020 ,14:44:45.485 Sent to IP:10.0.0.17 Port No:8901 = 2 F 26 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:45.587 Running Send to port, Data = P 26 255
    27/9/2020 ,14:44:45.588 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 255 ,PWM Command
    27/9/2020 ,14:44:45.590 Running Send to port, Data = P 27 0
    27/9/2020 ,14:44:45.592 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 0 ,PWM Command
    27/9/2020 ,14:44:45.697 Running Send to port, Data = F 27 0
    27/9/2020 ,14:44:45.699 Sent to IP:10.0.0.17 Port No:8901 = 2 F 27 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:45.804 Running Send to port, Data = P 27 255
    27/9/2020 ,14:44:45.807 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 255 ,PWM Command
    27/9/2020 ,14:44:45.811 Running Send to port, Data = P 28 0
    27/9/2020 ,14:44:45.815 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 0 ,PWM Command
    27/9/2020 ,14:44:45.917 Running Send to port, Data = F 28 0
    27/9/2020 ,14:44:45.920 Sent to IP:10.0.0.17 Port No:8901 = 2 F 28 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:46.022 Running Send to port, Data = P 28 255
    27/9/2020 ,14:44:46.024 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 255 ,PWM Command
    27/9/2020 ,14:44:46.026 Running Send to port, Data = P 29 0
    27/9/2020 ,14:44:46.028 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 0 ,PWM Command
    27/9/2020 ,14:44:46.134 Running Send to port, Data = F 29 0
    27/9/2020 ,14:44:46.138 Sent to IP:10.0.0.17 Port No:8901 = 2 F 29 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:46.242 Running Send to port, Data = P 29 255
    27/9/2020 ,14:44:46.246 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 255 ,PWM Command
    27/9/2020 ,14:44:46.251 Running Send to port, Data = P 30 0
    27/9/2020 ,14:44:46.255 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 0 ,PWM Command
    27/9/2020 ,14:44:46.359 Running Send to port, Data = F 30 0
    27/9/2020 ,14:44:46.362 Sent to IP:10.0.0.17 Port No:8901 = 2 F 30 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:46.466 Running Send to port, Data = P 30 255
    27/9/2020 ,14:44:46.470 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 255 ,PWM Command
    27/9/2020 ,14:44:46.475 Running Send to port, Data = P 31 0
    27/9/2020 ,14:44:46.478 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 0 ,PWM Command
    27/9/2020 ,14:44:46.582 Running Send to port, Data = F 31 0
    27/9/2020 ,14:44:46.584 Sent to IP:10.0.0.17 Port No:8901 = 2 F 31 0 ,PWM Fade Time Command
    27/9/2020 ,14:44:46.687 Running Send to port, Data = P 31 255
    27/9/2020 ,14:44:46.689 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 255 ,PWM Command
    27/9/2020 ,14:44:46.695 Running Send to port, Data = d 0 30
    27/9/2020 ,14:44:46.697 Sent to IP:10.0.0.17 Port No:8901 = 2 d 0 30 ,Debounce Set Command
    27/9/2020 ,14:44:46.790 Running Send to port, Data = c
    27/9/2020 ,14:44:46.794 Sent to IP:10.0.0.17 Port No:8901 = 2 c ,Connection established Command
    27/9/2020 ,14:45:09.608 Running Send to port, Data = r
    27/9/2020 ,14:45:09.610 Sent to IP:10.0.0.17 Port No:8901 = 2 r ,Reset Command
    27/9/2020 ,14:45:09.612 Board: 2 Connection FAILED running Reset.
    27/9/2020 ,14:45:11.627 Running Send to port, Data = K
    27/9/2020 ,14:45:11.631 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:45:11.634 Keeping Board: 1 Alive.
    27/9/2020 ,14:45:11.672 Data Received:Alive 1
    27/9/2020 ,14:45:11.676 Timer 1 Reset Loc 2
    27/9/2020 ,14:45:13.317 Data Received:Connect 2
    27/9/2020 ,14:45:13.323 ComNoArr = 1001 , ComPortEnum.Ethernet.ToString() = Ethernet , BoardIPArr = 10.0.0.17 , BoardPortArr = 8901
    27/9/2020 ,14:45:13.335 Connecting Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:45:13.337 Running Send to port, Data = C
    27/9/2020 ,14:45:13.341 Sent to IP:10.0.0.17 Port No:8901 = 2 C ,Connect Command
    27/9/2020 ,14:45:13.752 Data Received:Version 2 1.0.0.166 HS3
    27/9/2020 ,14:45:13.761 Board 2 Version 1.0.0.166 and Plugin Version 1.0.0.166 are compatible.
    27/9/2020 ,14:45:15.174 Data Received:Connected 2
    27/9/2020 ,14:45:15.178 Connected to Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:45:15.181 Updating pins on Board No: 2
    27/9/2020 ,14:45:15.182 Running Send to port, Data = X
    27/9/2020 ,14:45:15.184 Sent to IP:10.0.0.17 Port No:8901 = 2 X ,Pin Reset Command
    27/9/2020 ,14:45:15.268 Updating values on Board No: 2
    27/9/2020 ,14:45:15.269 Running Send to port, Data = O 32 0 1
    27/9/2020 ,14:45:15.270 Sent to IP:10.0.0.17 Port No:8901 = 2 O 32 0 1 ,Output Set Command
    27/9/2020 ,14:45:15.271 Running Send to port, Data = O 33 0 2
    27/9/2020 ,14:45:15.271 Sent to IP:10.0.0.17 Port No:8901 = 2 O 33 0 2 ,Output Set Command
    27/9/2020 ,14:45:15.273 Running Send to port, Data = O 34 1 3
    27/9/2020 ,14:45:15.273 Sent to IP:10.0.0.17 Port No:8901 = 2 O 34 1 3 ,Output Set Command
    27/9/2020 ,14:45:15.274 Running Send to port, Data = O 35 1 4
    27/9/2020 ,14:45:15.275 Sent to IP:10.0.0.17 Port No:8901 = 2 O 35 1 4 ,Output Set Command
    27/9/2020 ,14:45:15.276 Running Send to port, Data = O 36 0 5
    27/9/2020 ,14:45:15.277 Sent to IP:10.0.0.17 Port No:8901 = 2 O 36 0 5 ,Output Set Command
    27/9/2020 ,14:45:15.278 Running Send to port, Data = O 37 0 6
    27/9/2020 ,14:45:15.280 Sent to IP:10.0.0.17 Port No:8901 = 2 O 37 0 6 ,Output Set Command
    27/9/2020 ,14:45:15.282 Running Send to port, Data = O 38 0 7
    27/9/2020 ,14:45:15.284 Sent to IP:10.0.0.17 Port No:8901 = 2 O 38 0 7 ,Output Set Command
    27/9/2020 ,14:45:15.286 Running Send to port, Data = P 9 0
    27/9/2020 ,14:45:15.288 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 0 ,PWM Command
    27/9/2020 ,14:45:15.389 Running Send to port, Data = F 9 0
    27/9/2020 ,14:45:15.392 Sent to IP:10.0.0.17 Port No:8901 = 2 F 9 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:15.495 Running Send to port, Data = P 9 255
    27/9/2020 ,14:45:15.496 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 255 ,PWM Command
    27/9/2020 ,14:45:15.497 Running Send to port, Data = P 8 0
    27/9/2020 ,14:45:15.498 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 0 ,PWM Command
    27/9/2020 ,14:45:15.600 Running Send to port, Data = F 8 0
    27/9/2020 ,14:45:15.601 Sent to IP:10.0.0.17 Port No:8901 = 2 F 8 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:15.703 Running Send to port, Data = P 8 255
    27/9/2020 ,14:45:15.704 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 255 ,PWM Command
    27/9/2020 ,14:45:15.705 Running Send to port, Data = P 7 0
    27/9/2020 ,14:45:15.706 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 0 ,PWM Command
    27/9/2020 ,14:45:15.807 Running Send to port, Data = F 7 0
    27/9/2020 ,14:45:15.810 Sent to IP:10.0.0.17 Port No:8901 = 2 F 7 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:15.912 Running Send to port, Data = P 7 255
    27/9/2020 ,14:45:15.913 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 255 ,PWM Command
    27/9/2020 ,14:45:15.914 Running Send to port, Data = P 14 0
    27/9/2020 ,14:45:15.915 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 0 ,PWM Command
    27/9/2020 ,14:45:16.017 Running Send to port, Data = F 14 0
    27/9/2020 ,14:45:16.018 Sent to IP:10.0.0.17 Port No:8901 = 2 F 14 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:16.120 Running Send to port, Data = P 14 255
    27/9/2020 ,14:45:16.121 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 255 ,PWM Command
    27/9/2020 ,14:45:16.122 Running Send to port, Data = P 15 0
    27/9/2020 ,14:45:16.123 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 0 ,PWM Command
    27/9/2020 ,14:45:16.226 Running Send to port, Data = F 15 0
    27/9/2020 ,14:45:16.227 Sent to IP:10.0.0.17 Port No:8901 = 2 F 15 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:16.329 Running Send to port, Data = P 15 255
    27/9/2020 ,14:45:16.330 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 255 ,PWM Command
    27/9/2020 ,14:45:16.331 Running Send to port, Data = P 16 0
    27/9/2020 ,14:45:16.332 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 0 ,PWM Command
    27/9/2020 ,14:45:16.433 Running Send to port, Data = F 16 0
    27/9/2020 ,14:45:16.434 Sent to IP:10.0.0.17 Port No:8901 = 2 F 16 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:16.535 Running Send to port, Data = P 16 255
    27/9/2020 ,14:45:16.536 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 255 ,PWM Command
    27/9/2020 ,14:45:16.537 Running Send to port, Data = P 17 0
    27/9/2020 ,14:45:16.538 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 0 ,PWM Command
    27/9/2020 ,14:45:16.640 Running Send to port, Data = F 17 0
    27/9/2020 ,14:45:16.641 Sent to IP:10.0.0.17 Port No:8901 = 2 F 17 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:16.742 Running Send to port, Data = P 17 255
    27/9/2020 ,14:45:16.743 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 255 ,PWM Command
    27/9/2020 ,14:45:16.744 Running Send to port, Data = P 18 0
    27/9/2020 ,14:45:16.747 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 0 ,PWM Command
    27/9/2020 ,14:45:16.847 Running Send to port, Data = F 18 0
    27/9/2020 ,14:45:16.848 Sent to IP:10.0.0.17 Port No:8901 = 2 F 18 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:16.951 Running Send to port, Data = P 18 255
    27/9/2020 ,14:45:16.952 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 255 ,PWM Command
    27/9/2020 ,14:45:16.953 Running Send to port, Data = P 19 0
    27/9/2020 ,14:45:16.953 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 0 ,PWM Command
    27/9/2020 ,14:45:17.055 Running Send to port, Data = F 19 0
    27/9/2020 ,14:45:17.056 Sent to IP:10.0.0.17 Port No:8901 = 2 F 19 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:17.157 Running Send to port, Data = P 19 255
    27/9/2020 ,14:45:17.158 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 255 ,PWM Command
    27/9/2020 ,14:45:17.159 Running Send to port, Data = P 20 0
    27/9/2020 ,14:45:17.160 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 0 ,PWM Command
    27/9/2020 ,14:45:17.263 Running Send to port, Data = F 20 0
    27/9/2020 ,14:45:17.265 Sent to IP:10.0.0.17 Port No:8901 = 2 F 20 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:17.366 Running Send to port, Data = P 20 255
    27/9/2020 ,14:45:17.367 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 255 ,PWM Command
    27/9/2020 ,14:45:17.368 Running Send to port, Data = P 21 0
    27/9/2020 ,14:45:17.369 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 0 ,PWM Command
    27/9/2020 ,14:45:17.471 Running Send to port, Data = F 21 0
    27/9/2020 ,14:45:17.472 Sent to IP:10.0.0.17 Port No:8901 = 2 F 21 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:17.575 Running Send to port, Data = P 21 255
    27/9/2020 ,14:45:17.576 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 255 ,PWM Command
    27/9/2020 ,14:45:17.577 Running Send to port, Data = P 22 0
    27/9/2020 ,14:45:17.578 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 0 ,PWM Command
    27/9/2020 ,14:45:17.680 Running Send to port, Data = F 22 1286
    27/9/2020 ,14:45:17.681 Sent to IP:10.0.0.17 Port No:8901 = 2 F 22 1286 ,PWM Fade Time Command
    27/9/2020 ,14:45:17.783 Running Send to port, Data = P 22 255
    27/9/2020 ,14:45:17.784 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 255 ,PWM Command
    27/9/2020 ,14:45:17.785 Running Send to port, Data = P 24 0
    27/9/2020 ,14:45:17.786 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 0 ,PWM Command
    27/9/2020 ,14:45:17.887 Running Send to port, Data = F 24 2375
    27/9/2020 ,14:45:17.888 Sent to IP:10.0.0.17 Port No:8901 = 2 F 24 2375 ,PWM Fade Time Command
    27/9/2020 ,14:45:17.994 Running Send to port, Data = P 24 255
    27/9/2020 ,14:45:17.997 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 255 ,PWM Command
    27/9/2020 ,14:45:18.000 Running Send to port, Data = P 25 0
    27/9/2020 ,14:45:18.003 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 0 ,PWM Command
    27/9/2020 ,14:45:18.105 Running Send to port, Data = F 25 0
    27/9/2020 ,14:45:18.107 Sent to IP:10.0.0.17 Port No:8901 = 2 F 25 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:18.211 Running Send to port, Data = P 25 255
    27/9/2020 ,14:45:18.215 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 255 ,PWM Command
    27/9/2020 ,14:45:18.219 Running Send to port, Data = P 26 0
    27/9/2020 ,14:45:18.223 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 0 ,PWM Command
    27/9/2020 ,14:45:18.325 Running Send to port, Data = F 26 0
    27/9/2020 ,14:45:18.327 Sent to IP:10.0.0.17 Port No:8901 = 2 F 26 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:18.429 Running Send to port, Data = P 26 255
    27/9/2020 ,14:45:18.430 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 255 ,PWM Command
    27/9/2020 ,14:45:18.432 Running Send to port, Data = P 27 0
    27/9/2020 ,14:45:18.432 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 0 ,PWM Command
    27/9/2020 ,14:45:18.539 Running Send to port, Data = F 27 0
    27/9/2020 ,14:45:18.542 Sent to IP:10.0.0.17 Port No:8901 = 2 F 27 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:18.646 Running Send to port, Data = P 27 255
    27/9/2020 ,14:45:18.650 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 255 ,PWM Command
    27/9/2020 ,14:45:18.655 Running Send to port, Data = P 28 0
    27/9/2020 ,14:45:18.659 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 0 ,PWM Command
    27/9/2020 ,14:45:18.763 Running Send to port, Data = F 28 0
    27/9/2020 ,14:45:18.767 Sent to IP:10.0.0.17 Port No:8901 = 2 F 28 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:18.869 Running Send to port, Data = P 28 255
    27/9/2020 ,14:45:18.870 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 255 ,PWM Command
    27/9/2020 ,14:45:18.871 Running Send to port, Data = P 29 0
    27/9/2020 ,14:45:18.872 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 0 ,PWM Command
    27/9/2020 ,14:45:18.977 Running Send to port, Data = F 29 0
    27/9/2020 ,14:45:18.980 Sent to IP:10.0.0.17 Port No:8901 = 2 F 29 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:19.085 Running Send to port, Data = P 29 255
    27/9/2020 ,14:45:19.088 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 255 ,PWM Command
    27/9/2020 ,14:45:19.096 Running Send to port, Data = P 30 0
    27/9/2020 ,14:45:19.099 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 0 ,PWM Command
    27/9/2020 ,14:45:19.204 Running Send to port, Data = F 30 0
    27/9/2020 ,14:45:19.208 Sent to IP:10.0.0.17 Port No:8901 = 2 F 30 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:19.308 Running Send to port, Data = P 30 255
    27/9/2020 ,14:45:19.310 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 255 ,PWM Command
    27/9/2020 ,14:45:19.311 Running Send to port, Data = P 31 0
    27/9/2020 ,14:45:19.312 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 0 ,PWM Command
    27/9/2020 ,14:45:19.414 Running Send to port, Data = F 31 0
    27/9/2020 ,14:45:19.415 Sent to IP:10.0.0.17 Port No:8901 = 2 F 31 0 ,PWM Fade Time Command
    27/9/2020 ,14:45:19.517 Running Send to port, Data = P 31 255
    27/9/2020 ,14:45:19.519 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 255 ,PWM Command
    27/9/2020 ,14:45:19.520 Running Send to port, Data = d 0 30
    27/9/2020 ,14:45:19.521 Sent to IP:10.0.0.17 Port No:8901 = 2 d 0 30 ,Debounce Set Command
    27/9/2020 ,14:45:19.603 Running Send to port, Data = c
    27/9/2020 ,14:45:19.604 Sent to IP:10.0.0.17 Port No:8901 = 2 c ,Connection established Command
    27/9/2020 ,14:45:41.753 Running Send to port, Data = K
    27/9/2020 ,14:45:41.756 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:45:41.758 Keeping Board: 1 Alive.
    27/9/2020 ,14:45:41.863 Data Received:Alive 1
    27/9/2020 ,14:45:41.867 Timer 1 Reset Loc 2
    27/9/2020 ,14:46:11.062 Data Received:1 I 6 1
    27/9/2020 ,14:46:11.064 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:11.073 Board1, Input:6, Value:1
    27/9/2020 ,14:46:11.079 Running Send to port, Data = h
    27/9/2020 ,14:46:11.080 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:14.233 Data Received:1 I 6 0
    27/9/2020 ,14:46:14.234 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:14.239 Board1, Input:6, Value:0
    27/9/2020 ,14:46:14.247 Running Send to port, Data = h
    27/9/2020 ,14:46:14.249 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:14.784 Data Received:1 I 6 1
    27/9/2020 ,14:46:14.785 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:14.789 Board1, Input:6, Value:1
    27/9/2020 ,14:46:14.794 Running Send to port, Data = h
    27/9/2020 ,14:46:14.795 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:16.090 Data Received:1 I 5 1
    27/9/2020 ,14:46:16.091 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:16.105 Board1, Input:5, Value:1
    27/9/2020 ,14:46:16.110 Running Send to port, Data = h
    27/9/2020 ,14:46:16.121 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:17.958 Data Received:1 I 6 0
    27/9/2020 ,14:46:17.959 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:17.966 Board1, Input:6, Value:0
    27/9/2020 ,14:46:17.980 Running Send to port, Data = h
    27/9/2020 ,14:46:17.982 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:19.051 Data Received:1 I 6 1
    27/9/2020 ,14:46:19.054 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:19.065 Board1, Input:6, Value:1
    27/9/2020 ,14:46:19.075 Running Send to port, Data = h
    27/9/2020 ,14:46:19.080 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:19.380 Data Received:1 I 5 0
    27/9/2020 ,14:46:19.385 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:19.394 Board1, Input:5, Value:0
    27/9/2020 ,14:46:19.404 Running Send to port, Data = h
    27/9/2020 ,14:46:19.406 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:22.223 Data Received:1 I 6 0
    27/9/2020 ,14:46:22.227 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:22.238 Board1, Input:6, Value:0
    27/9/2020 ,14:46:22.256 Running Send to port, Data = h
    27/9/2020 ,14:46:22.260 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:24.733 Data Received:1 I 6 1
    27/9/2020 ,14:46:24.734 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:24.737 Board1, Input:6, Value:1
    27/9/2020 ,14:46:24.740 Running Send to port, Data = h
    27/9/2020 ,14:46:24.741 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:27.583 Data Received:1 I 5 1
    27/9/2020 ,14:46:27.586 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:27.598 Board1, Input:5, Value:1
    27/9/2020 ,14:46:27.611 Running Send to port, Data = h
    27/9/2020 ,14:46:27.614 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:27.797 Data Received:1 I 6 0
    27/9/2020 ,14:46:27.799 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:27.809 Board1, Input:6, Value:0
    27/9/2020 ,14:46:27.819 Running Send to port, Data = h
    27/9/2020 ,14:46:27.821 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:28.344 Data Received:1 I 6 1
    27/9/2020 ,14:46:28.347 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:28.358 Board1, Input:6, Value:1
    27/9/2020 ,14:46:28.369 Running Send to port, Data = h
    27/9/2020 ,14:46:28.373 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:30.752 Data Received:1 I 5 0
    27/9/2020 ,14:46:30.764 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:30.776 Board1, Input:5, Value:0
    27/9/2020 ,14:46:30.792 Running Send to port, Data = h
    27/9/2020 ,14:46:30.796 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:31.188 Data Received:1 I 5 1
    27/9/2020 ,14:46:31.191 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:31.198 Board1, Input:5, Value:1
    27/9/2020 ,14:46:31.205 Running Send to port, Data = h
    27/9/2020 ,14:46:31.208 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:31.518 Data Received:1 I 6 0
    27/9/2020 ,14:46:31.520 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:31.528 Board1, Input:6, Value:0
    27/9/2020 ,14:46:31.541 Running Send to port, Data = h
    27/9/2020 ,14:46:31.544 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:34.366 Data Received:1 I 5 0
    27/9/2020 ,14:46:34.369 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:34.387 Board1, Input:5, Value:0
    27/9/2020 ,14:46:34.405 Running Send to port, Data = h
    27/9/2020 ,14:46:34.410 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:47.052 Data Received:1 I 6 1
    27/9/2020 ,14:46:47.056 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:47.067 Board1, Input:6, Value:1
    27/9/2020 ,14:46:47.077 Running Send to port, Data = h
    27/9/2020 ,14:46:47.080 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:46:50.219 Data Received:1 I 6 0
    27/9/2020 ,14:46:50.222 Timer 1 Reset Loc 1
    27/9/2020 ,14:46:50.225 Board1, Input:6, Value:0
    27/9/2020 ,14:46:50.229 Running Send to port, Data = h
    27/9/2020 ,14:46:50.230 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:47:20.150 Running Send to port, Data = K
    27/9/2020 ,14:47:20.153 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:47:20.155 Keeping Board: 1 Alive.
    27/9/2020 ,14:47:20.191 Data Received:Alive 1
    27/9/2020 ,14:47:20.192 Timer 1 Reset Loc 2
    27/9/2020 ,14:47:47.202 Data Received:1 I 6 1
    27/9/2020 ,14:47:47.203 Timer 1 Reset Loc 1
    27/9/2020 ,14:47:47.207 Board1, Input:6, Value:1
    27/9/2020 ,14:47:47.211 Running Send to port, Data = h
    27/9/2020 ,14:47:47.212 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:47:50.373 Data Received:1 I 6 0
    27/9/2020 ,14:47:50.374 Timer 1 Reset Loc 1
    27/9/2020 ,14:47:50.377 Board1, Input:6, Value:0
    27/9/2020 ,14:47:50.381 Running Send to port, Data = h
    27/9/2020 ,14:47:50.382 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:48:13.387 Running Send to port, Data = r
    27/9/2020 ,14:48:13.391 Sent to IP:10.0.0.17 Port No:8901 = 2 r ,Reset Command
    27/9/2020 ,14:48:13.394 Board: 2 Connection FAILED running Reset.
    27/9/2020 ,14:48:18.485 Data Received:Connect 2
    27/9/2020 ,14:48:18.487 ComNoArr = 1001 , ComPortEnum.Ethernet.ToString() = Ethernet , BoardIPArr = 10.0.0.17 , BoardPortArr = 8901
    27/9/2020 ,14:48:18.490 Connecting Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:48:18.490 Running Send to port, Data = C
    27/9/2020 ,14:48:18.493 Sent to IP:10.0.0.17 Port No:8901 = 2 C ,Connect Command
    27/9/2020 ,14:48:18.923 Data Received:Version 2 1.0.0.166 HS3
    27/9/2020 ,14:48:18.925 Board 2 Version 1.0.0.166 and Plugin Version 1.0.0.166 are compatible.
    27/9/2020 ,14:48:20.408 Running Send to port, Data = K
    27/9/2020 ,14:48:20.412 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:48:20.415 Keeping Board: 1 Alive.
    27/9/2020 ,14:48:20.460 Data Received:Alive 1
    27/9/2020 ,14:48:20.464 Timer 1 Reset Loc 2
    27/9/2020 ,14:48:20.673 Data Received:Connected 2
    27/9/2020 ,14:48:20.680 Connected to Board No:2 at ip address 10.0.0.17 Port No:8901
    27/9/2020 ,14:48:20.682 Updating pins on Board No: 2
    27/9/2020 ,14:48:20.684 Running Send to port, Data = X
    27/9/2020 ,14:48:20.685 Sent to IP:10.0.0.17 Port No:8901 = 2 X ,Pin Reset Command
    27/9/2020 ,14:48:20.769 Updating values on Board No: 2
    27/9/2020 ,14:48:20.770 Running Send to port, Data = O 32 0 1
    27/9/2020 ,14:48:20.771 Sent to IP:10.0.0.17 Port No:8901 = 2 O 32 0 1 ,Output Set Command
    27/9/2020 ,14:48:20.772 Running Send to port, Data = O 33 0 2
    27/9/2020 ,14:48:20.772 Sent to IP:10.0.0.17 Port No:8901 = 2 O 33 0 2 ,Output Set Command
    27/9/2020 ,14:48:20.773 Running Send to port, Data = O 34 1 3
    27/9/2020 ,14:48:20.774 Sent to IP:10.0.0.17 Port No:8901 = 2 O 34 1 3 ,Output Set Command
    27/9/2020 ,14:48:20.775 Running Send to port, Data = O 35 1 4
    27/9/2020 ,14:48:20.775 Sent to IP:10.0.0.17 Port No:8901 = 2 O 35 1 4 ,Output Set Command
    27/9/2020 ,14:48:20.776 Running Send to port, Data = O 36 0 5
    27/9/2020 ,14:48:20.777 Sent to IP:10.0.0.17 Port No:8901 = 2 O 36 0 5 ,Output Set Command
    27/9/2020 ,14:48:20.777 Running Send to port, Data = O 37 0 6
    27/9/2020 ,14:48:20.778 Sent to IP:10.0.0.17 Port No:8901 = 2 O 37 0 6 ,Output Set Command
    27/9/2020 ,14:48:20.779 Running Send to port, Data = O 38 0 7
    27/9/2020 ,14:48:20.780 Sent to IP:10.0.0.17 Port No:8901 = 2 O 38 0 7 ,Output Set Command
    27/9/2020 ,14:48:20.781 Running Send to port, Data = P 9 0
    27/9/2020 ,14:48:20.782 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 0 ,PWM Command
    27/9/2020 ,14:48:20.884 Running Send to port, Data = F 9 0
    27/9/2020 ,14:48:20.885 Sent to IP:10.0.0.17 Port No:8901 = 2 F 9 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:20.987 Running Send to port, Data = P 9 255
    27/9/2020 ,14:48:20.988 Sent to IP:10.0.0.17 Port No:8901 = 2 P 9 255 ,PWM Command
    27/9/2020 ,14:48:20.989 Running Send to port, Data = P 8 0
    27/9/2020 ,14:48:20.990 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 0 ,PWM Command
    27/9/2020 ,14:48:21.096 Running Send to port, Data = F 8 0
    27/9/2020 ,14:48:21.100 Sent to IP:10.0.0.17 Port No:8901 = 2 F 8 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:21.204 Running Send to port, Data = P 8 255
    27/9/2020 ,14:48:21.209 Sent to IP:10.0.0.17 Port No:8901 = 2 P 8 255 ,PWM Command
    27/9/2020 ,14:48:21.212 Running Send to port, Data = P 7 0
    27/9/2020 ,14:48:21.216 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 0 ,PWM Command
    27/9/2020 ,14:48:21.319 Running Send to port, Data = F 7 0
    27/9/2020 ,14:48:21.322 Sent to IP:10.0.0.17 Port No:8901 = 2 F 7 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:21.423 Running Send to port, Data = P 7 255
    27/9/2020 ,14:48:21.425 Sent to IP:10.0.0.17 Port No:8901 = 2 P 7 255 ,PWM Command
    27/9/2020 ,14:48:21.426 Running Send to port, Data = P 14 0
    27/9/2020 ,14:48:21.427 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 0 ,PWM Command
    27/9/2020 ,14:48:21.530 Running Send to port, Data = F 14 0
    27/9/2020 ,14:48:21.533 Sent to IP:10.0.0.17 Port No:8901 = 2 F 14 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:21.637 Running Send to port, Data = P 14 255
    27/9/2020 ,14:48:21.641 Sent to IP:10.0.0.17 Port No:8901 = 2 P 14 255 ,PWM Command
    27/9/2020 ,14:48:21.645 Running Send to port, Data = P 15 0
    27/9/2020 ,14:48:21.649 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 0 ,PWM Command
    27/9/2020 ,14:48:21.754 Running Send to port, Data = F 15 0
    27/9/2020 ,14:48:21.758 Sent to IP:10.0.0.17 Port No:8901 = 2 F 15 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:21.861 Running Send to port, Data = P 15 255
    27/9/2020 ,14:48:21.863 Sent to IP:10.0.0.17 Port No:8901 = 2 P 15 255 ,PWM Command
    27/9/2020 ,14:48:21.866 Running Send to port, Data = P 16 0
    27/9/2020 ,14:48:21.868 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 0 ,PWM Command
    27/9/2020 ,14:48:21.972 Running Send to port, Data = F 16 0
    27/9/2020 ,14:48:21.976 Sent to IP:10.0.0.17 Port No:8901 = 2 F 16 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:22.080 Running Send to port, Data = P 16 255
    27/9/2020 ,14:48:22.084 Sent to IP:10.0.0.17 Port No:8901 = 2 P 16 255 ,PWM Command
    27/9/2020 ,14:48:22.089 Running Send to port, Data = P 17 0
    27/9/2020 ,14:48:22.093 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 0 ,PWM Command
    27/9/2020 ,14:48:22.197 Running Send to port, Data = F 17 0
    27/9/2020 ,14:48:22.208 Sent to IP:10.0.0.17 Port No:8901 = 2 F 17 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:22.313 Running Send to port, Data = P 17 255
    27/9/2020 ,14:48:22.317 Sent to IP:10.0.0.17 Port No:8901 = 2 P 17 255 ,PWM Command
    27/9/2020 ,14:48:22.321 Running Send to port, Data = P 18 0
    27/9/2020 ,14:48:22.325 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 0 ,PWM Command
    27/9/2020 ,14:48:22.429 Running Send to port, Data = F 18 0
    27/9/2020 ,14:48:22.433 Sent to IP:10.0.0.17 Port No:8901 = 2 F 18 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:22.535 Running Send to port, Data = P 18 255
    27/9/2020 ,14:48:22.537 Sent to IP:10.0.0.17 Port No:8901 = 2 P 18 255 ,PWM Command
    27/9/2020 ,14:48:22.539 Running Send to port, Data = P 19 0
    27/9/2020 ,14:48:22.540 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 0 ,PWM Command
    27/9/2020 ,14:48:22.646 Running Send to port, Data = F 19 0
    27/9/2020 ,14:48:22.650 Sent to IP:10.0.0.17 Port No:8901 = 2 F 19 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:22.755 Running Send to port, Data = P 19 255
    27/9/2020 ,14:48:22.758 Sent to IP:10.0.0.17 Port No:8901 = 2 P 19 255 ,PWM Command
    27/9/2020 ,14:48:22.763 Running Send to port, Data = P 20 0
    27/9/2020 ,14:48:22.767 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 0 ,PWM Command
    27/9/2020 ,14:48:22.872 Running Send to port, Data = F 20 0
    27/9/2020 ,14:48:22.876 Sent to IP:10.0.0.17 Port No:8901 = 2 F 20 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:22.980 Running Send to port, Data = P 20 255
    27/9/2020 ,14:48:22.983 Sent to IP:10.0.0.17 Port No:8901 = 2 P 20 255 ,PWM Command
    27/9/2020 ,14:48:22.990 Running Send to port, Data = P 21 0
    27/9/2020 ,14:48:22.992 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 0 ,PWM Command
    27/9/2020 ,14:48:23.095 Running Send to port, Data = F 21 0
    27/9/2020 ,14:48:23.096 Sent to IP:10.0.0.17 Port No:8901 = 2 F 21 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:23.198 Running Send to port, Data = P 21 255
    27/9/2020 ,14:48:23.200 Sent to IP:10.0.0.17 Port No:8901 = 2 P 21 255 ,PWM Command
    27/9/2020 ,14:48:23.203 Running Send to port, Data = P 22 0
    27/9/2020 ,14:48:23.205 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 0 ,PWM Command
    27/9/2020 ,14:48:23.307 Running Send to port, Data = F 22 1286
    27/9/2020 ,14:48:23.308 Sent to IP:10.0.0.17 Port No:8901 = 2 F 22 1286 ,PWM Fade Time Command
    27/9/2020 ,14:48:23.412 Running Send to port, Data = P 22 255
    27/9/2020 ,14:48:23.416 Sent to IP:10.0.0.17 Port No:8901 = 2 P 22 255 ,PWM Command
    27/9/2020 ,14:48:23.427 Running Send to port, Data = P 24 0
    27/9/2020 ,14:48:23.431 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 0 ,PWM Command
    27/9/2020 ,14:48:23.536 Running Send to port, Data = F 24 2375
    27/9/2020 ,14:48:23.540 Sent to IP:10.0.0.17 Port No:8901 = 2 F 24 2375 ,PWM Fade Time Command
    27/9/2020 ,14:48:23.641 Running Send to port, Data = P 24 255
    27/9/2020 ,14:48:23.643 Sent to IP:10.0.0.17 Port No:8901 = 2 P 24 255 ,PWM Command
    27/9/2020 ,14:48:23.645 Running Send to port, Data = P 25 0
    27/9/2020 ,14:48:23.647 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 0 ,PWM Command
    27/9/2020 ,14:48:23.752 Running Send to port, Data = F 25 0
    27/9/2020 ,14:48:23.756 Sent to IP:10.0.0.17 Port No:8901 = 2 F 25 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:23.861 Running Send to port, Data = P 25 255
    27/9/2020 ,14:48:23.864 Sent to IP:10.0.0.17 Port No:8901 = 2 P 25 255 ,PWM Command
    27/9/2020 ,14:48:23.869 Running Send to port, Data = P 26 0
    27/9/2020 ,14:48:23.873 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 0 ,PWM Command
    27/9/2020 ,14:48:23.976 Running Send to port, Data = F 26 0
    27/9/2020 ,14:48:23.979 Sent to IP:10.0.0.17 Port No:8901 = 2 F 26 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:24.082 Running Send to port, Data = P 26 255
    27/9/2020 ,14:48:24.085 Sent to IP:10.0.0.17 Port No:8901 = 2 P 26 255 ,PWM Command
    27/9/2020 ,14:48:24.087 Running Send to port, Data = P 27 0
    27/9/2020 ,14:48:24.089 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 0 ,PWM Command
    27/9/2020 ,14:48:24.195 Running Send to port, Data = F 27 0
    27/9/2020 ,14:48:24.199 Sent to IP:10.0.0.17 Port No:8901 = 2 F 27 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:24.302 Running Send to port, Data = P 27 255
    27/9/2020 ,14:48:24.306 Sent to IP:10.0.0.17 Port No:8901 = 2 P 27 255 ,PWM Command
    27/9/2020 ,14:48:24.311 Running Send to port, Data = P 28 0
    27/9/2020 ,14:48:24.315 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 0 ,PWM Command
    27/9/2020 ,14:48:24.416 Running Send to port, Data = F 28 0
    27/9/2020 ,14:48:24.417 Sent to IP:10.0.0.17 Port No:8901 = 2 F 28 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:24.519 Running Send to port, Data = P 28 255
    27/9/2020 ,14:48:24.520 Sent to IP:10.0.0.17 Port No:8901 = 2 P 28 255 ,PWM Command
    27/9/2020 ,14:48:24.521 Running Send to port, Data = P 29 0
    27/9/2020 ,14:48:24.522 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 0 ,PWM Command
    27/9/2020 ,14:48:24.628 Running Send to port, Data = F 29 0
    27/9/2020 ,14:48:24.632 Sent to IP:10.0.0.17 Port No:8901 = 2 F 29 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:24.737 Running Send to port, Data = P 29 255
    27/9/2020 ,14:48:24.748 Sent to IP:10.0.0.17 Port No:8901 = 2 P 29 255 ,PWM Command
    27/9/2020 ,14:48:24.752 Running Send to port, Data = P 30 0
    27/9/2020 ,14:48:24.756 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 0 ,PWM Command
    27/9/2020 ,14:48:24.860 Running Send to port, Data = F 30 0
    27/9/2020 ,14:48:24.864 Sent to IP:10.0.0.17 Port No:8901 = 2 F 30 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:24.964 Running Send to port, Data = P 30 255
    27/9/2020 ,14:48:24.965 Sent to IP:10.0.0.17 Port No:8901 = 2 P 30 255 ,PWM Command
    27/9/2020 ,14:48:24.967 Running Send to port, Data = P 31 0
    27/9/2020 ,14:48:24.968 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 0 ,PWM Command
    27/9/2020 ,14:48:25.075 Running Send to port, Data = F 31 0
    27/9/2020 ,14:48:25.078 Sent to IP:10.0.0.17 Port No:8901 = 2 F 31 0 ,PWM Fade Time Command
    27/9/2020 ,14:48:25.183 Running Send to port, Data = P 31 255
    27/9/2020 ,14:48:25.189 Sent to IP:10.0.0.17 Port No:8901 = 2 P 31 255 ,PWM Command
    27/9/2020 ,14:48:25.194 Running Send to port, Data = d 0 30
    27/9/2020 ,14:48:25.198 Sent to IP:10.0.0.17 Port No:8901 = 2 d 0 30 ,Debounce Set Command
    27/9/2020 ,14:48:25.279 Running Send to port, Data = c
    27/9/2020 ,14:48:25.280 Sent to IP:10.0.0.17 Port No:8901 = 2 c ,Connection established Command
    27/9/2020 ,14:48:50.581 Running Send to port, Data = K
    27/9/2020 ,14:48:50.583 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:48:50.584 Keeping Board: 1 Alive.
    27/9/2020 ,14:48:50.642 Data Received:Alive 1
    27/9/2020 ,14:48:50.644 Timer 1 Reset Loc 2
    27/9/2020 ,14:49:20.732 Running Send to port, Data = K
    27/9/2020 ,14:49:20.734 Sent to IP:10.0.0.16 Port No:8900 = 1 K ,Keep Alive Command
    27/9/2020 ,14:49:20.735 Keeping Board: 1 Alive.
    27/9/2020 ,14:49:20.816 Data Received:Alive 1
    27/9/2020 ,14:49:20.820 Timer 1 Reset Loc 2
    27/9/2020 ,14:49:29.675 Data Received:1 I 6 1
    27/9/2020 ,14:49:29.678 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:29.693 Board1, Input:6, Value:1
    27/9/2020 ,14:49:29.703 Running Send to port, Data = h
    27/9/2020 ,14:49:29.707 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:32.406 Data Received:1 I 5 1
    27/9/2020 ,14:49:32.409 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:32.416 Board1, Input:5, Value:1
    27/9/2020 ,14:49:32.423 Running Send to port, Data = h
    27/9/2020 ,14:49:32.426 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:32.847 Data Received:1 I 6 0
    27/9/2020 ,14:49:32.850 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:32.862 Board1, Input:6, Value:0
    27/9/2020 ,14:49:32.880 Running Send to port, Data = h
    27/9/2020 ,14:49:32.885 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:32.954 Data Received:1 I 6 1
    27/9/2020 ,14:49:32.959 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:32.976 Board1, Input:6, Value:1
    27/9/2020 ,14:49:32.983 Running Send to port, Data = h
    27/9/2020 ,14:49:32.986 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:35.580 Data Received:1 I 5 0
    27/9/2020 ,14:49:35.583 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:35.594 Board1, Input:5, Value:0
    27/9/2020 ,14:49:35.620 Running Send to port, Data = h
    27/9/2020 ,14:49:35.623 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:36.017 Data Received:1 I 6 0
    27/9/2020 ,14:49:36.022 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:36.033 Board1, Input:6, Value:0
    27/9/2020 ,14:49:36.052 Running Send to port, Data = h
    27/9/2020 ,14:49:36.056 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:36.451 Data Received:1 I 2 1
    27/9/2020 ,14:49:36.453 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:36.458 Board1, Input:2, Value:1
    27/9/2020 ,14:49:36.462 Running Send to port, Data = h
    27/9/2020 ,14:49:36.464 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:37.221 Data Received:1 I 6 1
    27/9/2020 ,14:49:37.224 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:37.236 Board1, Input:6, Value:1
    27/9/2020 ,14:49:37.246 Running Send to port, Data = h
    27/9/2020 ,14:49:37.250 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:37.982 Data Received:1 I 5 1
    27/9/2020 ,14:49:37.983 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:37.986 Board1, Input:5, Value:1
    27/9/2020 ,14:49:37.988 Running Send to port, Data = h
    27/9/2020 ,14:49:37.989 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:38.974 Data Received:1 I 2 0
    27/9/2020 ,14:49:38.978 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:38.984 Board1, Input:2, Value:0
    27/9/2020 ,14:49:38.994 Running Send to port, Data = h
    27/9/2020 ,14:49:38.997 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:40.284 Data Received:1 I 6 0
    27/9/2020 ,14:49:40.286 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:40.294 Board1, Input:6, Value:0
    27/9/2020 ,14:49:40.305 Running Send to port, Data = h
    27/9/2020 ,14:49:40.308 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:40.500 Data Received:1 I 6 1
    27/9/2020 ,14:49:40.502 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:40.507 Board1, Input:6, Value:1
    27/9/2020 ,14:49:40.512 Running Send to port, Data = h
    27/9/2020 ,14:49:40.513 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:41.159 Data Received:1 I 5 0
    27/9/2020 ,14:49:41.162 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:41.173 Board1, Input:5, Value:0
    27/9/2020 ,14:49:41.191 Running Send to port, Data = h
    27/9/2020 ,14:49:41.196 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:49:43.672 Data Received:1 I 6 0
    27/9/2020 ,14:49:43.674 Timer 1 Reset Loc 1
    27/9/2020 ,14:49:43.680 Board1, Input:6, Value:0
    27/9/2020 ,14:49:43.689 Running Send to port, Data = h
    27/9/2020 ,14:49:43.690 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:05.222 Data Received:1 I 2 1
    27/9/2020 ,14:50:05.224 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:05.238 Board1, Input:2, Value:1
    27/9/2020 ,14:50:05.244 Running Send to port, Data = h
    27/9/2020 ,14:50:05.247 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:07.733 Data Received:1 I 2 0
    27/9/2020 ,14:50:07.734 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:07.737 Board1, Input:2, Value:0
    27/9/2020 ,14:50:07.742 Running Send to port, Data = h
    27/9/2020 ,14:50:07.743 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:07.957 Data Received:1 I 5 1
    27/9/2020 ,14:50:07.959 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:07.961 Board1, Input:5, Value:1
    27/9/2020 ,14:50:07.964 Running Send to port, Data = h
    27/9/2020 ,14:50:07.965 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:08.611 Data Received:1 I 6 1
    27/9/2020 ,14:50:08.613 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:08.620 Board1, Input:6, Value:1
    27/9/2020 ,14:50:08.627 Running Send to port, Data = h
    27/9/2020 ,14:50:08.630 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:09.487 Data Received:1 I 2 1
    27/9/2020 ,14:50:09.488 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:09.493 Board1, Input:2, Value:1
    27/9/2020 ,14:50:09.496 Running Send to port, Data = h
    27/9/2020 ,14:50:09.497 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:11.121 Data Received:1 I 5 0
    27/9/2020 ,14:50:11.123 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:11.128 Board1, Input:5, Value:0
    27/9/2020 ,14:50:11.132 Running Send to port, Data = h
    27/9/2020 ,14:50:11.133 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:11.782 Data Received:1 I 6 0
    27/9/2020 ,14:50:11.784 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:11.789 Board1, Input:6, Value:0
    27/9/2020 ,14:50:11.797 Running Send to port, Data = h
    27/9/2020 ,14:50:11.798 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:11.998 Data Received:1 I 2 0
    27/9/2020 ,14:50:11.999 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:12.002 Board1, Input:2, Value:0
    27/9/2020 ,14:50:12.006 Running Send to port, Data = h
    27/9/2020 ,14:50:12.007 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:12.436 Data Received:1 I 6 1
    27/9/2020 ,14:50:12.438 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:12.444 Board1, Input:6, Value:1
    27/9/2020 ,14:50:12.449 Running Send to port, Data = h
    27/9/2020 ,14:50:12.451 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:15.611 Data Received:1 I 6 0
    27/9/2020 ,14:50:15.612 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:15.616 Board1, Input:6, Value:0
    27/9/2020 ,14:50:15.621 Running Send to port, Data = h
    27/9/2020 ,14:50:15.622 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:19.546 Data Received:1 I 6 1
    27/9/2020 ,14:50:19.548 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:19.557 Board1, Input:6, Value:1
    27/9/2020 ,14:50:19.563 Running Send to port, Data = h
    27/9/2020 ,14:50:19.570 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:22.607 Data Received:1 I 6 0
    27/9/2020 ,14:50:22.608 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:22.613 Board1, Input:6, Value:0
    27/9/2020 ,14:50:22.620 Running Send to port, Data = h
    27/9/2020 ,14:50:22.622 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:31.579 Data Received:1 I 6 1
    27/9/2020 ,14:50:31.582 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:31.593 Board1, Input:6, Value:1
    27/9/2020 ,14:50:31.601 Running Send to port, Data = h
    27/9/2020 ,14:50:31.604 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:34.734 Data Received:1 I 6 0
    27/9/2020 ,14:50:34.735 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:34.738 Board1, Input:6, Value:0
    27/9/2020 ,14:50:34.742 Running Send to port, Data = h
    27/9/2020 ,14:50:34.743 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:40.750 Data Received:1 I 6 1
    27/9/2020 ,14:50:40.751 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:40.755 Board1, Input:6, Value:1
    27/9/2020 ,14:50:40.757 Running Send to port, Data = h
    27/9/2020 ,14:50:40.758 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:41.087 Data Received:1 I 5 1
    27/9/2020 ,14:50:41.088 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:41.104 Board1, Input:5, Value:1
    27/9/2020 ,14:50:41.107 Running Send to port, Data = h
    27/9/2020 ,14:50:41.108 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:43.922 Data Received:1 I 6 0
    27/9/2020 ,14:50:43.924 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:43.930 Board1, Input:6, Value:0
    27/9/2020 ,14:50:43.942 Running Send to port, Data = h
    27/9/2020 ,14:50:43.943 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:44.279 Data Received:1 I 5 0
    27/9/2020 ,14:50:44.290 Timer 1 Reset Loc 1
    27/9/2020 ,14:50:44.315 Board1, Input:5, Value:0
    27/9/2020 ,14:50:44.321 Running Send to port, Data = h
    27/9/2020 ,14:50:44.322 Sent to IP:10.0.0.16 Port No:8900 = 1 h ,Ack Command
    27/9/2020 ,14:50:44.831 postBackProc Debug=unchecked&id=Debug
    27/9/2020 ,14:50:44.837 Debug logging Disabled
    Is this normal or is my board misbehaving ?
    can i set anything different so this will stop or occur less ?
    Edit: i thought maybe my arduino mega board is broken so i took a new one out of the package and flashed it.
    But it seems that this is not the problem, or this mega is not good as well like the previous one ( they are from different vendors)
    How is the board powered as I have seen the boards reset with power fluctuations as the Ethernet shields are very sensitive to this. Is it on a separate supply to everything else?
    Scripts =
    Various
      Yes , i am supplying the board 5Volt on the input.
      I can use a adapter plug to see if this input would make a difference.
      The supply is a 5V 2 Amp thats set on exactly 5 Volts.
      Nothing more is connected on this psu
      Edit: ill find another psu to hopefully stop the "problem"
      But this looks like a power issue then ? its no normal behaviour ? im asking since i have been using the beta since 2 or 3 days so im not sure if this is a new build in function
      Edit: i have used another PSU its consuming about 227 mA at 5 Volts when running fine.
      then when running every sort of 3 minutes when the restart happens :
       [TABLE="class: log_table_row"]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:17:55 [/COLOR][/TD]
       			[TD="class: LogPri0, align: left"] [/TD]
       			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#0000FF]Arduino Plugin [/COLOR][/TD]
       			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Updating values on Board No: 2 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:17:55 [/COLOR][/TD]
       			[TD="class: LogPri1, align: left"] [/TD]
       			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#0000FF]Arduino Plugin [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Updating pins on Board No: 2 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
       			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Connected to Board No:2 at ip address 10.0.0.17 Port No:8901 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:17:53 [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Board 2 Version 1.0.0.166 and Plugin Version 1.0.0.166 are compatible. [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:17:53 [/COLOR][/TD]
       			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Connecting Board No:2 at ip address 10.0.0.17 Port No:8901 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:15:00 [/COLOR][/TD]
       			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Log Info [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]The log database is currently 49,98MB in size. [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:14:51 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:14:51 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:14:50 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:14:49 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:12:24 [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Debug logging Enabled [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:11:47 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:11:47 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:11:46 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:11:45 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:11:38 [/COLOR][/TD]
       			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Informational [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Discovered host 10.0.0.141 [] [08-C5-E1-3F-4D-9E] on 10.0.0.0. [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:08:43 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:08:43 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:08:41 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:08:41 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      [TR]
      [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:07:07 [/COLOR][/TD]
       			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Updating values on Board No: 2 [/COLOR][/TD]
       		[/TR]
      [/TABLE]
      the last cycle looked like a full reset since You can now see the voltage drop.
      The rest of the time the board is doing a sort of reset /cycle but then the usage stays on 226 mA.
      Going to test if it still keeps doing this when half of the pwm pins are off and 3/4 are off untill all are off.
        Well, i have tested several things.
        Different PSU ( which suddenly brought to my attention when testing with the stable arduino script i have been using this psu for powering the board and 1 light has been my working light for hours in a row without something like this, but can't be to carefull with troubleshooting)
        Tried a new arduino mega board , flashed it with the same script.
        Tried to turn off all channels / relays etc hoping this would affect the 3 minute restart ?
        now everything is off, only the arduino is on and it keeps resetting every 3 minutes.
        Next thing just to be sure is check the network cable maybe since i just made it , a wire is mixed up and the network board is acting up because of it.
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:33:18 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:33:17 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:33:17 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:33:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:33:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:33:03 [/COLOR][/TD]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]MQTT [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Info: Publish. Topic=/ESP_bijkeuken/cmd payload=pwm,12,0,2000 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:33:03 [/COLOR][/TD]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]Event [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Bijkeuken uit" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Event [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Deleting event after run: "Delayed Actions Bijkeuken verlichting 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]Device Control [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Bijkeuken Bijkeuken verlichting 50% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Delayed Actions Bijkeuken verlichting 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:31:46 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Debug logging Disabled [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:30:46 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Remove Delayed Device Action Removed event: Delayed Actions Gang beneden 50% (Delayed Action) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:30:46 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 50% to On (100) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting gang beneden aan bij beweging - 2 uur na opgang tot ondergang" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:30:41 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Remove Delayed Device Action Removed event: Delayed Actions Gang beneden 50% (Delayed Action) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:30:41 [/COLOR][/TD]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Device Control [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 50% to On (100) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting gang beneden aan bij beweging - 2 uur na opgang tot ondergang" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:30:12 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:30:12 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Updating pins on Board No: 2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:30:11 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Connected to Board No:2 at ip address 10.0.0.17 Port No:8901 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:30:10 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Board 2 Version 1.0.0.166 and Plugin Version 1.0.0.166 are compatible. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:30:10 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Connecting Board No:2 at ip address 10.0.0.17 Port No:8901 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:30:03 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Remove Delayed Device Action Removed event: Delayed Actions Bijkeuken verlichting 50% (Delayed Action) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:30:03 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Bijkeuken Bijkeuken verlichting 50% to On (100) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting bijkeuken aan bij beweging 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:29:56 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Info: Publish. Topic=/ESP_bijkeuken/cmd payload=pwm,12,250,2000 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:29:56 [/COLOR][/TD]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]MQTT [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Info: Publish. Topic=/ESP_bijkeuken/cmd payload=pwm,13,200 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Bijkeuken spot 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Bijkeuken Bijkeuken verlichting 50% to On (100) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting bijkeuken aan bij beweging 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:29:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:29:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:29:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:29:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:29:11 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang beneden spot 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:29:11 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:27:06 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:27:06 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:27:05 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:27:04 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:24:02 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:24:02 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:24:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:24:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:21:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:21:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:20:57 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:20:57 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        Here is the debug.txt log file
        https://www.dropbox.com/s/1iytssmskz...Debug.txt?dl=0
        Edit:
        The next thing i have tried is delete all the pwm pins.
        Suddenly after more then 3 minutes there was no entry in the log. ( deleted them all and was done at 17.00)
        So i thought well, let's add some pins and see what happens.
        The check still comes up in the log, but the lights stay on this time withouth the first video, off/on etc etc.
        Haven't done more then removing the pins and readding them.
        Hope this solves it
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:32:46 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:32:46 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:32:06 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:32:06 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:32:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:32:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:30:51 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 100% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:30:51 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 75% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 50% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 25% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 10% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 5% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 2% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang beneden spot uit" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Deleting event after run: "Delayed Actions Gang beneden 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 50% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Delayed Actions Gang beneden 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:30:03 [/COLOR][/TD]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]Log Maintenance [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]186 additional records were removed from the log database to reduce its size to 49,92MB. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:30:00 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]The log database is currently 50MB in size. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:26:54 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:26:54 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:26:53 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:26:53 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:25:51 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:25:51 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:25:45 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:25:45 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:23:52 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:23:51 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:23:51 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:23:50 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:23:50 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:23:48 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:23:48 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:23:40 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:23:40 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:23:35 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:23:35 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:20:48 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:20:48 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:20:47 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:20:46 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:17:44 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:17:44 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:17:43 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:17:42 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:15:11 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:11 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:15:08 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:08 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:20 Pin:31 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:15:05 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:05 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:04 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:19 Pin:30 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:15:04 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:15:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:15:01 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:18 Pin:29 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:59 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:59 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:58 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:17 Pin:28 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:57 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:55 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:55 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:16 Pin:27 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:53 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:53 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:52 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:52 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:15 Pin:26 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:48 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:48 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:14 Pin:25 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:47 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:47 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:46 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:44 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:44 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:13 Pin:24 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:42 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:42 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:41 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:12 Pin:22 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:41 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:38 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:37 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:11 Pin:9 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:37 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:36 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:34 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:34 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:10 Pin:8 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:32 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:32 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:31 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:31 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:30 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:9 Pin:7 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:15 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:14 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:14 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:8 Pin:21 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:12 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:12 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:14:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:14:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:7 Pin:20 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:13:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:13:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:13:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:13:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:10:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:10:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:10:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:10:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#D58000]Sep-27 17:08:27 [/COLOR][/TD]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#D58000]HSTouch Server Warning [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#D58000]Exception on Value Change callback: Object reference not set to an instance of an object. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#D58000]Sep-27 17:08:27 [/COLOR][/TD]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#D58000]HSTouch Server Warning [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#D58000]Exception on Value Change callback: Object reference not set to an instance of an object. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#D58000]Sep-27 17:08:26 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:08:23 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 100% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:08:23 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 75% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 25% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 10% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 5% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting beneden Gang voordeur Gang beneden 2% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang beneden spot uit" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Deleting event after run: "Delayed Actions Gang beneden 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Delayed Actions Gang beneden 50% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:18 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:16 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:6 Pin:19 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:14 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:14 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:13 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:12 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:11 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:5 Pin:18 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:08:08 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:08:08 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:4 Pin:17 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:31 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:31 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:30 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:29 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:29 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:3 Pin:16 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:25 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:25 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:23 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:2 Pin:15 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:07:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:07:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Adding PWMOutput:1 Pin:14 to board No:2 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:06:59 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 75% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:06:59 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 50% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 25% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 2% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 100% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 10% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:06:57 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang boven alles uit" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:06:57 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Deleting event after run: "Delayed Actions gang boven alles 10% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 10% to Off (0) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Delayed Actions gang boven alles 10% (Delayed Action)" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:06:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:06:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:06:20 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:06:19 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:06:02 [/COLOR][/TD]
         			[TD="class: LogType0, colspan: 3, align: left"][COLOR=#000000]Energy DB Info [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]All energy database compacting routines completed. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:06:02 [/COLOR][/TD]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Energy DB [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Database is 14,10742 MB in size. No further compaction needed. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:06:01 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Compacting remaining data... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:06:01 [/COLOR][/TD]
         			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]Energy DB Info [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Compacting data older than 4 months... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Compacting data older than 1 year... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:06:00 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Compacting data older than 3 years... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:06:00 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Compacting data older than 5 years... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Compacting data older than 10 years... [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Energy database compaction initiated. [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:03:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:03:23 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:03:15 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:03:15 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:03:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:03:10 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:03:01 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Remove Delayed Device Action Removed event: Delayed Actions Bijkeuken verlichting 50% (Delayed Action) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:03:01 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:02:40 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:02:40 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:02:07 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:02:07 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:02:00 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Info: Publish. Topic=/ESP_bijkeuken/cmd payload=pwm,12,250,2000 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:02:00 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Info: Publish. Topic=/ESP_bijkeuken/cmd payload=pwm,13,200 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Bijkeuken spot 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:47 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Remove Delayed Device Action Removed event: Delayed Actions gang boven alles 10% (Delayed Action) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:47 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#000000]Device: Verlichting boven Gang boven gang boven alles 10% to On (100) [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting gang boven aan bij beweging slaapkamer sensor - 2 uur na zonsopgang tot zonsondergang" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:42 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:42 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:38 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang boven alles 10%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:38 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Verlichting virtuele settings voor beweging en multi knop functies Verlichting gang boven aan bij beweging trapgat sensor - 2 uur na zonsopgang tot zonsondergang" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:34 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:34 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:29 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:29 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:24 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 17:01:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 17:01:21 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:00:17 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:00:17 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 17:00:16 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 17:00:15 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#000000]Sep-27 16:59:41 [/COLOR][/TD]
         			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]Event Trigger "Virtuele licht knoppen Gang beneden spot 50%" [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#000000]Sep-27 16:59:41 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:57:56 [/COLOR][/TD]
         			[TD="class: LogEntry0, colspan: 8, align: left"][COLOR=#0000FF]Debug logging Enabled [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:57:14 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:57:13 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime1, align: left"][COLOR=#0000FF]Sep-27 16:57:13 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        [TR]
        [TD="class: LogDateLong LogDateTime0, align: left"][COLOR=#0000FF]Sep-27 16:57:12 [/COLOR][/TD]
         		[/TR]
        [/TABLE]
        EDIT:
        Well the board/plugin was still acting up but took a bit longer.
        Seems then when adding PWM pins trouble starts.
        I reverted back to the stable arduino version and put 5 led panels on a port so i had enough pwm pins.
        Not one time the same board was disconnected or whatsoever , pity since i liked the beta plugin.
          the reconnect every 2 or 3 minutes is something that happen on the plugin randomly and have been a bug since a very long time for me
          The fix i have for that is to go to the general plugin management page , turn plugin off, wait 10 sec , turn plugin on
          it will fix cyclic reconnect every 3 minutes
          The reason of the bug after many troubleshooting is if plugin loose connection to a board it will try to reset it , and even if the board reconnect the plugin will be in a reset loop every 3 minutes.
          ( its been a very long time since my investigation and i may be wrong about how to trigger the bug , but it was something close to that)
            Thanks, i have switched over to esp32 and esp8266 boards now.
            Most of the system at home is now on mqtt, does actually run pretty good.
              I'm getting this almost constantly - does it have any detrimental effect if I just ignore it? It only has two LEDs attached as warning indicators and a good quality PSU.
              Cheers
              Scott
                Cheers
                Scott
                Scott,
                This should not be a problem but I thought it was fixed. Are you still running the HS3 version or the updated HS4 version?
                Scripts =
                Various
                  Hi Greg - still on HS3. Not sure HS4 is ready yet :-) I wanted to check that there wasn't an issue with this - I am having a horrible time where the CPU goes about 50% for hs3.exe and it stops processing events. I was blaming the zwave plugin, and have almost totally replaced them with ZigBee - I think it's helping, I don't get the event engine stopping as often.
                    That is strange as a plugin should not affect the HS.exe but I think Zwave has some built-in functionality so might be the cause. I have never seen anything like the events stop running, but I guess it could have been a bad Zwave device causing the plugin to freeze as I once had this as a problem until it was removed. I also have had no problem with HS4 only in the Beta phase was their problems.
                    Scripts =
                    Various
                      When a bunch of z-wave data comes in at the same time, it looks like it overwhelms the plugin, pumps the proc up to about 55-60% at which point no events are processed until the proc reduces back to 2-3%, then everything continues as normal - the missed events don't catch up - they are just missed. It's been driving me crazy - so much so, that I was seriously considering dumping HS altogether as only working sometimes is worse then not working at all!! If it wasn't for the extensibility of HS, I would have jumped by now - especially as HS4 isn't all it's cracked up to be - and it uses the same zwave plugin as HS3!
                        Hi all,
                        I just added a NodeMCU to my setup (only two inputs and not using API, PI ver 1.0.0.66) and have the same problem, the board, and only this one, is constantly resetting, about every 3 min.
                        I have try to reset the plugin, reset HS; reset Windows, changed power supply.
                        I also ordered another NodeMCU and will try to swap it
                        My log is full of blue lines ......
                          Originally posted by Pierre View Post
                          Hi all,
                          Mine does this intermittently--every few days--and then corrects itself somehow. Apparently the bug is still there.
                          Arduino PI v.1.0.0.166, HS v.4.2.5.0.
                          -Wade
