New Node NodeMCU
    New Node NodeMCU
    Howdy everyone! I've been enjoying the Arduino plugin for a while, but recently got a NodeMCU board, so I updated to the beta and followed the instructions, installed the ESP8266 Community version 2.7.4. Then when compiling I get the following error. It seems like its not redirecting to the folder that has io.h in it.
    Build options changed, rebuilding all
    C:\Program Files (x86)\Arduino\libraries\SoftPWM\SoftPWM.cpp:26:20: fatal error: avr/io.h: No such file or directory
    #include <avr/io.h>
    compilation terminated.
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
    Did some google searching, but didn't really find a thread to follow. Any pointers would be greatly appreciated!
    Did you install the SoftPWM Library in the IDE as this looks like it is missing?
    Scripts =
    Various
      I believe so. To make sure I have it right, I uninstalled/reinstalled Arduino, then copied the libraries from the plugin into C:\program files (x86)\Arduino\libraries, which includes SoftPWM. Then I added the URL to the preferences as noted in the homeseer help. Upon first compile, it had two conflicting libraries,Ethernet and Servo. One folder under C:\program files (x86)\Arduino\libraries and one under c:\users\user\appdata\local\Arduino15\packages\esp8266\hardw are\esp8266\2.7.4\libraries\. I deleted the two under the esp8266 path, and I got back to the original problem mentioning avr/io.h.
      For what its worth, I have the file, its under C:\Program Files (x86)\Arduino\hardware\tools\avr\avr\include\avr
      Here are the libraries that show up.
        So, I just noticed, if its set to the Arduino Genuino Uno board, it'll compile, its only when I compile for the NodeMCU that it has the issue. Not sure if that narrows it down or complicates it.
          Did you set up the board as a NodeMCU in the plugin then download the sketch for that board or are u using an old sketch? Can you send it to me to check?
          Scripts =
          Various
            Yessir, I believe I have it right. Will DM you the sketch.
