With HS3 and the HS3 Arduino plugin I recall you could be able to select the RBG value with a color wheel via the config page. That option isn't available anymore? I don't see the ability to change it to a specific value via the color wheel or with a color # value (either via the device page or by an event)? I am running HS4 with the upgraded HS4 plugin
RBG color selection?
Yes, you should be able to. I tested this in HS4 and it worked fine but something must have changed with the layout on the device manager page. Was the device created in HS3 or HS4?Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
