Error During Startup
    I am on HS4. Each time I start up HS4 I get the following error:
    11/14/2020 5:23:07 PM Legacy-Plugin~!~Arduino Plugin~!~ Error = Exception in Logtofile : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS4\html\Arduino\ArduinoDebug.txt' because it is being used by another process.
    11/14/2020 5:23:07 PM Legacy-Plugin/Script~!~Arduino Plugin~!~Checking for Boards.
    11/14/2020 5:23:07 PM Legacy-Plugin/Script~!~Arduino Plugin~!~0 Boards found.
    11/14/2020 5:23:07 PM Legacy-Plugin/Script~!~Arduino Plugin~!~No Boards Found.
    11/14/2020 5:23:07 PM Legacy-Plugin/Script~!~Arduino Plugin~!~0 Input Pins Found.
    Is there anything in my plugin setup that causes the problem or is this an issue that needs to be fixed in the plugin? I am on version 1.0.0.161.
    Never mind, this was caused by a different plugin. I had one plugin log an error. After I have fixed that this error also went away. It doesn't make much sense to me, though. The error is thrown because of logging to ArduinoDebug.txt but I am sure that other plugin (RFXCOM) doesn't write to this log file. So something is odd.
    I am including a link to a message from somebody else who just had the same issue with a different plugin. There is a link to my original post regarding the RFXCOM plugin error.
    https://forums.homeseer.com/forum/se...07#post1433507
      This is odd... it should not lock files from other plugins. If this continues give me a shout and I will do some testing.
      Scripts =
      Various
