NodeMCU - Verify Sketch
    I get the following error
    HomeSeerBoard1:38:10: fatal error: ESP8266WiFi.h: No such file or directory
    #include <ESP8266WiFi.h>
    compilation terminated.
    exit status 1
    I have added the NodeMCU board via Arduino Tools - Added via Board Manager
    I have installed the libraries as per the Plugin (5 libraries that are copied into the Arduino/libraries folder
    Get this error when compiling, as can't find the header files.
    Am I missing something in the configuration of the softrware?
    Thanks for any help
    Never mind that error. I had to reselect the NodeMCU board in the tools menu - somehow it went back to Genuine Arduino.
    Now I am compiling, and get this error (after about 30 seconds of compiling)
    no matching function for call to 'ESP8266HTTPUpdate::update(char*&)'
      I found this - but not sure how to fix it
      v3.0.0 compile error with ESPhttpUpdate · Issue #8052 · esp8266/Arduino · GitHub
        I installed an older version of NodeMCU (2.3.0) and that allowed it to compile.
        I uploaded it successfully to the board, but so far no connection with Homeseer plugin. I use an IP address in the 172.16.3.X range, but my gateway is in the 192.168.0.X range (there is a router that bridges the segments).
        I see on my sonicwall that the device gets registered when plugging and unplugging it.
        I am unable to ping it (assuming it would actually respond to pings), and the blue LED on the WIFI board is never blinking
        This is what I get from teh serial output
        WiFi 1 -65, Sent to 192.168.0.60
        Connect 1, Sent to 192.168.0.60
        67,0,0,0
        Recieved C
        Sending Version
        Version 1 4.0.2.5 HS4, Sent to 192.168.0.60
        Sending Connected
        Connected 1, Sent to 192.168.0.60
        114,0,0,0
        Reset
        ets Jan 8 2013,rst cause:2, boot mode3,6)
        load 0x4010f000, len 1384, room 16
        tail 8
        chksum 0x2d
        csum 0x2d
        v3de0c112
        ~ld
        debug Start......
        WiFi 1 -64, Sent to 192.168.0.60
        67,0,0,0
        Recieved C
        Sending Version
        Sending Connected
        114,0,0,0
        Reset
        tail 8
        chksum 0x2d
        csum 0x2d
        v3de0c112
        ~ld
        debug Start......
        WiFi 1 -63, Sent to 192.168.0.60
          When I press connect on the HomeSeer Web page, I get immediately on the Arduino
          67,0,0,0
          Recieved C
          Sending Version
          Sending Connected
          However, the device stays disconnected
          It also properly handles a reset, as well as communicating that a disconnect occurred.
          My sonicwall shows that the packets coming from homeseer, but not much in the Arduino to Homeseer direction
          # Time Ingress Egress Source IP Destination IP Ether Type Packet Type Ports[Src, Dst] Status Length [Actual]
          1 09/20/2021 22:15:34.368 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          2 09/20/2021 22:15:34.368 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          3 09/20/2021 22:15:34.848 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          4 09/20/2021 22:15:34.848 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          I disconnected the USB - Maybe can't use it and WiFi at the same time
          I let it run for a while, and this is the output from the sonicwall
          09/20/2021 22:37:11.496 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          8 09/20/2021 22:37:11.496 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          9 09/20/2021 22:40:11.048 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          10 09/20/2021 22:40:11.048 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          11 09/20/2021 22:40:11.528 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          12 09/20/2021 22:40:11.528 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          13 09/20/2021 22:40:35.752 X4*(i) -- 172.16.3.230 224.0.0.251 IP UDP 5353,5353 DROPPED 356[356]
          14 09/20/2021 22:43:11.048 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          15 09/20/2021 22:43:11.048 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          16 09/20/2021 22:43:11.528 X0*(i) X4 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 60[60]
          17 09/20/2021 22:43:11.528 -- X4* 192.168.0.60 172.16.3.230 IP UDP 63486,8900 FORWARDED 55[55]
          There is only an output from the device to a multicast address - and it is dropped?
          Any ideas anyone.
            If I load an example program (Advanced Web Server) - It works perfectly - I can access it from PC, from phone, and USB can be plugged in at same time as WiFi is working.
            Figured it out - thee gateway had to be the gateway for the WLAN to the LAN (172.16.3.1), not the gateway to the WAN (192.168.0.1)
