Problem Assigning More Than 41 Inputs
    Hi Greig, I can not assign more than 41 inputs to a board. I am using a 2560 Mega which has digital pins that go way beyond that...... not sure if the issue is related to the UI, see below. Thanks for the support.
    -Ron
    Correction, seems like the plug-in is limited to 40 inputs.
      Yes the HS3 Version if the plugin is limited to 40 inputs. You can add a second board if you need more because I no longer support the HS3 Version.
      Scripts =
      Various
