NodeMCU API for beginners
    All,
    Does anyone have available a simple NodeMCU API sketch performing a simple process? For example- blinking a light or something else very basic. I am a complete novice who has managed to get a light to blink using the IDE alone and figured out how to use the Homeseer with the Arduino Plugin but this API stuff is not clicking yet. So far all the examples/sketches I found seem too complicated with LCD and sensors I don't have yet.
    I have also looked (unsuccessfully) to see if a post exists as a library of successful sketches people have made for this plugin.
    Thanks!
    Russ
    This is an example of a NodeMCU API sketch that has 5 temperature sensors, flashing lights and LCD panel. The example contains a lot of screenshots of the setup as well as having the code commented. Hopefully this will help get you going. See https://forums.homeseer.com/forum/an...-panel-example
    Greig also has a few examples in the documentation for plugin
    Hopefully this will get you going.
    Billy
      Thanks Billy, I ordered the recommended humidity sensors to see if I can get it to work.
      Currently in inventory for things I am trying to figure out are:
      MQ2
      HX711
      MAX31850K
      SHT30
      DHT22 (on order)
      I've had luck with one-wire DS18B20, infrared fluid switch, float switch, reed switch, fluid flow meter but all those used Grieg's existing functionality so it was fairly foolproof. Connecting the dots with API where we take Arduino code and allow HS to use it is where I am having a mental block.
        Finally figured it all out, here is my library so far which includes HX711, DHT22, MQ2. This is only the top API portion of the sketch and simplified as much as I could make it.
        HX711
        Arduino to HS4 Plugin API written by Enigma Theatre.
        V4.0.2.16 VALUE AND STRING
        int FromHS[50];
        boolean IsConnected = false;
        byte AlivePin = 255;
        //To Use the Alive pin change the 255 to the pin number above.
        //**************Declare your variables here*******************
        [HASHTAG="t3158"]include[/HASHTAG] "HX711.h"
        // HX711 circuit wiring DT d6 SCK d7 VCC 3v3 GRD
        const int LOADCELL_DOUT_PIN = 12;
        const int LOADCELL_SCK_PIN = 13;
        HX711 scale;
        void HSSetup() {
        //Add YOUR SETUP HERE;
        Serial.begin(115200);
        Serial.println("HX711 Demo");
        Serial.println("Initializing the scale");
        scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
        Serial.println("Before setting up the scale:");
        Serial.print("read: \t\t");
        Serial.println(scale.read()); // print a raw reading from the ADC
        Serial.print("read average: \t\t");
        Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
        Serial.print("get value: \t\t");
        Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
        Serial.print("get units: \t\t");
        Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
        // by the SCALE parameter (not set yet)
        scale.set_scale(42.648);
        //scale.set_scale(-471.497); // this value is obtained by calibrating the scale with known weights; see the README for details
        scale.tare(); // reset the scale to 0
        Serial.println("After setting up the scale:");
        Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
        Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
        // by the SCALE parameter set with set_scale
        Serial.println("Readings:");
        void HSloop() {
        //Add YOUR CODE HERE;
        /* To Send Data to Homeseer use SendToHS(Device,Value)
        Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send
        To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes.
        Eg.. FromHS[5] would be the data from API Output device 5
        All code that is located just below this block will execute regardless of connection status!
        You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue.
        If you only want code to execute when HomeSeer is connected, put it inside the if statement below.
        /*Execute regardless of connection status*/
        Serial.print("one reading:\t");
        Serial.print(scale.get_units(), 1);
        Serial.print("\t| average:\t");
        Serial.println(scale.get_units(10), 5);
        SendToHS(1,scale.get_units());
        //Voids After here.
        DHT22
        V4.0.2.16
        int FromHS[50];
        [HASHTAG="t3158"]include[/HASHTAG] "DHT.h"
        #define DHTPIN 0 // what digital pin the DHT22 is conected to
        #define DHTTYPE DHT22 // there are multiple kinds of DHT sensors
        DHT dht(DHTPIN, DHTTYPE);
        void HSSetup() {
        dht.begin();
        void HSloop() {
        Serial.print("Humidity: ");
        Serial.print(dht.readHumidity());
        SendToHS(1,dht.readHumidity());
        Serial.print("%\t");
        Serial.print("Temperature: ");
        Serial.print(dht.readTemperature(true));
        SendToHS(2,dht.readTemperature(true));
        Serial.println("F");
        delay(5000);
        //Voids After here.
        MQ2
        V4.0.2.16
        int FromHS[50];
        int Gas_analog = A0; // used for ESP8266
        int Gas_digital = D1; // used for ESP8266
        void HSSetup() {
        pinMode(D5, OUTPUT);
        pinMode(Gas_digital, INPUT);
        void HSloop() {
        Gasoline fumes are between 1.4% (14,000 ppm) and 7.6% (76,000 ppm).
        int gassensorAnalog = analogRead(Gas_analog);
        int gassensorDigital = digitalRead(Gas_digital);
        Serial.println(gassensorAnalog);
        SendToHS(1,gassensorAnalog);
        if (gassensorAnalog > 1000) {
        SendToHS(2,HIGH);
        digitalWrite (D5, HIGH) ; //Red Alert
        else {
        SendToHS(2,LOW);
        digitalWrite (D5, LOW) ; //no tone
        delay(5000);
        //Voids After here.
          Nice job, glad you were able to make progress!
          Billy
            Just as a note, this code will work as test code but you need to remove the Delay() that you have in each section as this will stop the plugin sketch section from running when required and you will see connection errors. Look up Arduino Blink Without Delay.
            Scripts =
            Various
              Greig,
              I originally had the delay out but found the plugin would get stuck, not update the value or trigger any events. I added the delay and then it worked as expected.
              Billy,
              Thanks!
                Originally posted by crossing@marker99.com View Post
                Greig,
                Billy,
                Thanks!
                Yes, You need the delay just not using the delay function, with no delay the plugin will be flooded with information on every run off the loop but as I said using the delay function will cause the Arduino to stop at that section and will not respond to any commands from HS so you need to update to use something like:
                V4.0.2.16
                int FromHS[50];
                void HSSetup() {
                void HSloop() {
                const long interval = 10000;
                unsigned long currentMillis = millis();
                if (currentMillis - previousMillis >= interval) {
                // save the last time you blinked the LED
                previousMillis = currentMillis;
                SendToHS(2,HIGH);
                else {
                SendToHS(2,LOW);
                delay(5000);
                //Voids After here.
                The other way to do it is to store the last sent value in the Arduino then check if it has changed and update HS only if it has changed.
                Scripts =
                Various
                  Greig,
                  Just saw your "Arduino Blink Without Delay" comment as you were posting your response. I will take a look and improve/update the code!
                  Russ
                    Hi crossing@marker99.com ,
                    Do you have any other sketches that you got working in the API that you would share?
                    Tim
                      Sure, these are only the top portions of the sketches above the "//Voids After here" line.
                      It took me a while to understand how this is all supposed to work but most everything you need to know is in the manual Greig provides like using Blink Without Delay and SendToHS() which is critical. Assume my code is not perfect.
                      Counter for Flow Meter
                      V4.0.2.16
                      int FromHS[50];
                      const int input = 12; // This is where the input is fed.
                      int pulse = 0; // Variable for saving pulses count.
                      int var = 0;
                      void HSSetup() {
                      pinMode(input, INPUT);
                      void HSloop() {
                      if(digitalRead(input) > var)
                      var = 1;
                      pulse++;
                      Serial.println(pulse);
                      SendToHS(1,pulse);
                      if(digitalRead(input) == 0) {var = 0;}
                      //Voids After here.
                      Single DS18B20
                      V4.0.2.16
                      int FromHS[50];
                      [HASHTAG="t3158"]include[/HASHTAG] <OneWire.h>
                      [HASHTAG="t3158"]include[/HASHTAG] <DallasTemperature.h>
                      unsigned long previousMillis = 0;
                      const long interval = 5000;
                      // GPIO where the DS18B20 is connected to
                      const int oneWireBus = 4;
                      // Setup a oneWire instance to communicate with any OneWire devices
                      OneWire oneWire(oneWireBus);
                      // Pass our oneWire reference to Dallas Temperature sensor
                      DallasTemperature sensors(&oneWire);
                      void HSSetup() {
                      // Start the Serial Monitor
                      // Start the DS18B20 sensor
                      sensors.begin();
                      void HSloop() {
                      sensors.requestTemperatures();
                      float temperatureF = sensors.getTempFByIndex(0);
                      Serial.print(temperatureF);
                      Serial.println("ºF");
                      SendToHS(2,temperatureF);
                      //Voids After here.
                      MQ2 Sensor and DHT11 combo
                      V4.0.2.16
                      int FromHS[50];
                      // Generally, you should use "unsigned long" for variables that hold time
                      // The value will quickly become too large for an int to store
                      unsigned long previousMillis = 0; // will store last time LED was updated
                      // constants won't change:
                      const long interval = 60000; // interval at which to blink (milliseconds)
                      void HSSetup() {
                      // put your setup code here, to run once:
                      dht.begin();
                      void HSloop() {
                      // put your main code here, to run repeatedly:
                      Serial.print(gassensorAnalog);
                      Serial.print("u\t");
                      SendToHS(2,dht.readHumidity());
                      SendToHS(3,dht.readTemperature(true));
                      digitalWrite(D5, FromHS[1]);
                      digitalWrite(D4, FromHS[0]);
                      //Voids After here.
                        Thank you for that!
