Cannot connect to ESP32
    HS4 / Windows 10 pro / 4.0.2.19 BETA plugin / Adafruit ESP32 Feather V2 / Arduino IDE 1.8.19
    Trying to get values from environmental sensors to HS for air quality monitoring.
    Code compiles and runs on ESP32. Plugin will not connect (or stay "connected") or send data using SendToHS.
    Thanks for any insight! What am I missing?
    Debug log For HS4 Arduino-4 By Enigmatheatre (Greig Dempster)
    Debugging Started at = 27/12/2022 ,08:34:14.476
    Arduino Plugin Version = 4.0.2.19
    *************************************Homeseer*************** ****************************
    Homeseer Version = 4.2.16.0
    Homeseer IP = 10.0.1.184
    OS Version = Microsoft Windows 10 Pro (6.2.9200.0)
    **************************************Setup***************** ****************************
    1 Boards Found
    Board 1 Setup, Board Ref: 1091 Control Ref: 1092, IP = 10.0.1.199 Port No:8900
    Ref = 1092 | Address = Arduino, Board:1, Status autoconnect = 1, boardno = 1, boardtype = 7, comport = 1001, debounce = 30, ethershieldv2 = 0, index = 1, ipaddress = 10.0.1.199, isuno = 0, macaddress = xx:xx:xx:xx:xx:xx, onewirepin = , password = XXXXXXX, port = 8900, ssid = XXXXXXX, type = Status,
    Ref = 1093 | Address = Arduino, Board:1, API Input:1 boardno = 1, index = 1, type = APIInput, unit = H2, update = 0,
    ***************************************LOG****************** ****************************
    27/12/2022 ,08:34:59.864 #SetIOMulti# Control Ref:1092
    27/12/2022 ,08:34:59.864 #SetIOMulti# Control Device Value:1
    27/12/2022 ,08:34:59.864 #SetIOMulti# Control Device String:
    27/12/2022 ,08:34:59.864 Output Value = 1, String = , ref = 1092
    27/12/2022 ,08:34:59.864 #OutputThread# ,BoardNo = 1/ Type = Status/ Index = 1/ Key = / Pin =
    27/12/2022 ,08:34:59.880 ComNoArr = 1001 , BoardIPArr = 10.0.1.199 , BoardPortArr = 8900
    27/12/2022 ,08:34:59.896 Connecting Board No:1 at ip address 10.0.1.199 Port No:8900
    27/12/2022 ,08:34:59.896 Running Send to port, Data = C
    27/12/2022 ,08:34:59.896 Sent to IP:10.0.1.199 Port No:8900 = 1 C ,Connect
    27/12/2022 ,08:36:29.765 ComNoArr = 1001 , BoardIPArr = 10.0.1.199 , BoardPortArr = 8900
    27/12/2022 ,08:36:29.765 Connecting Board No:1 at ip address 10.0.1.199 Port No:8900
    27/12/2022 ,08:36:29.765 Running Send to port, Data = C
    27/12/2022 ,08:36:29.765 Sent to IP:10.0.1.199 Port No:8900 = 1 C ,Connect
    27/12/2022 ,08:36:30.280 Running Send to port, Data = r
    27/12/2022 ,08:36:30.280 Sent to IP:10.0.1.199 Port No:8900 = 1 r ,Reset
    27/12/2022 ,08:36:30.280 Board: 1 Connection FAILED running Reset.
    27/12/2022 ,08:36:59.811 Board: 1 Connection FAILED.
    27/12/2022 ,08:36:59.811 ComNoArr = 1001 , BoardIPArr = 10.0.1.199 , BoardPortArr = 8900
    27/12/2022 ,08:36:59.842 Connecting Board No:1 at ip address 10.0.1.199 Port No:8900
    27/12/2022 ,08:36:59.842 Running Send to port, Data = C
    27/12/2022 ,08:36:59.858 Sent to IP:10.0.1.199 Port No:8900 = 1 C ,Connect​
    Hi Memkey,
    Looks like your your esp board is not connected at all homeseer is trying but no response. See below a succesfull connect from my system (Nodemcu).
    28/12/2022 ,12:21:25.465 ComNoArr = 1001 , BoardIPArr = 192.168.1.204 , BoardPortArr = 8902
    28/12/2022 ,12:21:25.479 Connecting Board No:3 at ip address 192.168.1.204 Port No:8902
    28/12/2022 ,12:21:25.483 Running Send to port, Data = C
    28/12/2022 ,12:21:25.484 Sent to IP:192.168.1.204 Port No:8902 = 3 C ,Connect
    28/12/2022 ,12:21:25.500 Data Received:Version 3 4.0.2.18 HS4
    28/12/2022 ,12:21:25.510 Board 3 Version 4.0.2.18 and Plugin Version 4.0.2.19 are compatible.
    28/12/2022 ,12:21:25.515 Data Received:Connected 3
    28/12/2022 ,12:21:25.553 Connected to Board No:3 at ip address 192.168.1.204 Port No:8902
    28/12/2022 ,12:21:25.555 Updating pins on Board No: 3
    28/12/2022 ,12:21:25.564 Running Send to port, Data = X
    28/12/2022 ,12:21:25.605 Sent to IP:192.168.1.204 Port No:8902 = 3 X ,Pin Reset
    28/12/2022 ,12:21:25.671 Running Send to port, Data = H 4
    28/12/2022 ,12:21:25.673 Sent to IP:192.168.1.204 Port No:8902 = 3 H 4 ,Alive Pinset
    28/12/2022 ,12:21:25.734 Updating values on Board No: 3
    28/12/2022 ,12:21:25.736 Running Send to port, Data = O 5 1 1
    28/12/2022 ,12:21:25.740 Sent to IP:192.168.1.204 Port No:8902 = 3 O 5 1 1 ,Output Set
    28/12/2022 ,12:21:25.746 Running Send to port, Data = d 0 30
    28/12/2022 ,12:21:25.749 Sent to IP:192.168.1.204 Port No:8902 = 3 d 0 30 ,Debounce Set
    28/12/2022 ,12:21:25.833 Running Send to port, Data = c
    28/12/2022 ,12:21:25.858 Sent to IP:192.168.1.204 Port No:8902 = 3 c ,Connection established
    28/12/2022 ,12:21:26.656 Running Send to port, Data = K
    Are you sure your esp coard is connected to the network??
    Easy check try to ping it.
    Regards
    Marcel​
