Controlling output pins on NodeMCU 8266
    I'm starting a project with a NodeMCU 8266 and all that I want to do is control a couple of output pins to turn on/off a relay. After creating the board and connecting it to my network (no problem), I added a couple of output pins (d3, d4) - GPIO0, GPIO2. So it appears the output devices have sliders with time in ms. Embarassing as it seems, do I need to create the status graphics for on and off in order to control? 0/255 or 0/100? in order to set the relay on or off?
    The outputs have 2 devices, one to set On/ Off / Blink/ One Flash or Toggle and the other sets the timing required for Blink And One Flash. Check you don't have the device filtered or in another location.
    Scripts =
    Various
      Thanks Greig, however I'm still on HS3. I wanted to get this last project done before I upgrade to HS4 in a couple of weeks.
      With HS3, there was just the slider. So I removed that and added a status/graphics on and off. Is this correct? It doesn't appear to do anything however as well.
        No, it is the same. Do not change the status/graphics of the time device as this will never control the on and off. You need to find the output device and not the output time device. Are you sure the other device is not filtered out?
        I would delete the pin and add it again as it should put both devices in the same location1 and location2.
        Greig.
        Scripts =
        Various
          Thanks again... this is what was created. No other output device.
            This is the plugin page and it looks to have no pins assigned to the board. Just add the pins again and the plugin will create 2 devices for each output. If the plugin has orphaned the device then delete them from the device manager then restart the plugin.
            Greig.
            Scripts =
            Various
              That is what I did originally.
              Click image for larger version  Name:	image.png Views:	0 Size:	14.7 KB ID:	1597363
              In Device manager: Slider only.
              Click image for larger version  Name:	image.png Views:	0 Size:	27.8 KB ID:	1597364
              and
                Devices 1557 and 1559 are the device you are looking for as the plugin created them in order.
                Scripts =
                Various
                  Oh man... that's embarrasing! Thanks so much for setting me straight.
                  Much appreciated.
                  Robert
