Arduino Plugin feature requests
This is a sticky topic.
  • Ron
    Value update
    Hi Greig,
    I'm experimenting with the Arduino plugin for some days now, and i'm strugling with some issues.
    I'm using the normal configuration (no API), and i'm wondering if it is possible in an analog input to have a choice between update variation like with the API configuration. (eg. value only, string only or value/string)?
    or
    make it possible to insert special signs in the "unit" field. i'm not able to put "℃" (or any other special signs) in the "unit" field.
    I've tried to use API configuration, but then i'm not able to send floating point data.
    regards
    Ron
  • petez69
    Hi Greig
    I've ordered myself a Weigand card reader to use as an access control system on my house. The reader will do all of the authentication in a standalone form however it has D0 and D1 outputs to interface with the Arduino.
    http://goo.gl/4se6gh
    i've had a good look around and there appears to be some very good weigand libraries to do the reader management.
    https://github.com/monkeyboard/Wiega...ry-for-Arduino
    https://github.com/ugge75/Wiegand-Pr...uino-MEGA-2560
    I'm going to use your API function to see how this thing works (when all of the parts arrive).
    Reason I ask this, if I use the API, its going to limit the use of the board longer term. If the library works well and makes Weigand interfacing easy, would you consider adding it to your base build ? Reason for the interface is to read the card ID and then "personalise" the house upon entry depending on what card entered the house ie: lighting, music, aircon etc....
    Thanks Pete
  • enigmatheatre
    Originally posted by ralphie View Post
    hi , it would be nice if the arduino has a "stand alone" function like many zwave switches have. like when i press a button that is connected to the arduino digital input it switches an digital output and sends it state to homeseer so if the server is down i still can switch my lights on and off.
    I to would love to be able to make this work but there are limits and this is one that I could not do.
    Sorry.
    Greig.
  • ralphie
    Stand alone function
  • enigmatheatre
    Originally posted by usLEDsupply View Post
    can we use the Arduino Map function in the math section on the analog inputs? Value = map(x, 0, 1023, 0, 150);
    or in my case something like Value = map(x, 50, 955, 0, 200);
    i have a bunch of analog sensors to measure water and air pressure and i can get the normal value pretty close with the standard math but it would be nice to get the full range more accurate
    Unfortunately not the map feature is an Arduino thing. I would need to have a think about this but as I have said before I am not the best at maths.
    Greig.
  • usLEDsupply
  • DMcKnight
    Doug,
    I can not add another to a single board but there is nothing stopping you running multiple boards each with a one wire pin or use the .API and create your own board and code with multiple one wire pins and send the data to homeseer from the board.
    Greig.
    Sent from my SM-G925F using Tapatalk
    Hi Greig,
    Yes, I'm going to spend some time thinking about the .API. That approach maybe makes most sense for this project for a couple of reasons.
    Doug
  • enigmatheatre
    Originally posted by DMcKnight View Post
    Hi Greig,
    I am wondering if it would be possible (easy?) to allow for more than 1 one-wire pin? I'm fine with the limitation of 15 devices on a bus, but having the opportunity to use more than one bus could be helpful under certain circumstances (e.g. different types of pull-ups etc).
    Regards
    Doug
    P.S. I've used one-wire quite a bit so I'm aware of the various limitations and tricks etc.
    doug
    Doug,
    Greig.
  • rprade
    Originally posted by dreambox View Post
    Hi Greg,
    Is it possible to change the maximum input from 30 to 32?
    Why?
    If you use the 2560 you can use a 32 (4*8) connector for all the inputs.
    Then you have only one connector for all the inputs.
    And 2 inputs more is not a big change?
    Alex
    What version of the plug-in are you using? The docs for the current beta 1.0.0.100 is limited to 40 input pins, but output pins are unlimited. On a Mega pins 50-52 are restricted when using an Ethernet adapter and pin 53 must be an output. To use pin 53 you must enable "Advanced Ethernet Settings if you are using that interface.
    The Ethernet adapter also impacts Analog 0 and 1 for SD card write protect and detection.
  • DMcKnight
    Another one-wire request
    Hi Greig,
    Regards
    Doug
    doug
  • dreambox
    Number of inputs from 30 to 32
    Hi Greg,
    Why?
    Alex
  • Pierre
    Serial data
    I would like to get rid of my quatech serial-to-ethernet-interface for reading a string my main AC counters delivers. (There is a potential risk not to have Quatech drivers for windows 10 and future)
    I found many ways to have this serial string received by an Arduino, and sent back after parsing to other medias.
    I am very new to this...
    At present I get this string from a com port in HS, and have it parsed, saved in devices by HS scripting.
    I imagined I could do the same if the Arduino could just send me this raw string, or that it could be parsed before using libraries easyli found on the net, and send sent to HS.
    I have seen in a precedent message the debate over local or central processing.
    My question is:
    Could we have a pin declared to "serial", and its content sent as a string to a device ?
    or
    Could an API setup take care of that ?
    Thanks for this great plugin, the Arduino world is wide opened to me ...
  • travisdh
    I may have asked this before, but it would be great if a variable could be pushed to an arduino board somehow, for example as a double you may push a variable temp=21, this would tell the arduino board to set a variable (e.g. name = temp) to 21.00
    The reason I ask this, is that I think the API is great, but it would be great to be able to offload stuff to just the Arduino and have it handle the PLC side of things, but be able to do that based on input from homeseer, so it might push onewire temperatures for inlet and outlet air for example to homeseer, and you set the variable for wanted temperature, so that way if homeseer is not running the arduino still keeps going doing it's thing, but later on you could push a different temperature and the program goes about doing it's thing with the new temperature.
    That is just a simple scenario, but no doubt variables would be handy for many other features as well.
    Main thing is that it is from Homeseer to the board, not the board to homeseer (which is achievable now).
  • kriz83
    Support for the RPI would be awesome :-)
  • usLEDsupply
    it would be great if there was a feature for the analog inputs that would only send a value if it has changed more than "X" so you wouldn't be wasting bandwidth if your sensor value hasn't changed yet you would still get fast responses when it does change
