Arduino Plugin not connecting to Access Point wifi
I am using Powerline internet and wifi at my home. Apparently my connection to my ESP8266 over wifi only works through "access point" wifi. I can get the ESP8266 to connect to my wifi in the sketch using the following code:
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid, pass);
WiFi.config(ip,gateway,subnet);
WiFi.begin();
This replaces the standard code
WiFi.begin(ssid, pass);
WiFi.config(ip, gateway, subnet);
WiFi.mode(WIFI_STA);
However, further code in the plug-in prevents the board to connect.
Is there a patch for this available?
Thanks for looking into this!
Arduino Plugin feature requests
This is a sticky topic.
Native support for ESP32 boards.
Ability to cache the individual/customised .ino files in homeseer so they can be downloaded and re-generated from any PC
I would like to have the ability to bind this PI to a secondary Network Card. I have been working on segmenting off my network and moving most of my Home Automation to an IOT VLAN that does not have access to the Internet. It appears that without binding this PI to a secondary NIC it is unable to talk with my IOT network.
Originally posted by Ronnie View PostHi,
Any chance for DHT22 support? I have not done a lot of arduino programming but would like to use several of the DHT22 sensors for temperature and humidity. I don't even know where to start for the programming of these.
Ronnie
It should not be too hard to do and I am sure if you are stuck you can ask on the forum and we will help out.
Ronnie
My feature request is to have the ability to upload API sketches over ethernet; it would require something like the Ariadne bootloader but would make it so much easier to update difficult to access Arduino boards.
Can you add a feature where you automatically detect the serial port. I guess you could query Windows for all available COM ports. Then you connect to all of those ports and send a message to reply with their board name (which would have to be modified when downloading the sketch). If somebody didn't modify the board name than auto detection is turned off. And there might be the need for an option in the plugin configuration to enable/disable the auto connection with some note that if you enable it you have to modify the board name. Maybe there is a better way to do this but that would be a great feature in my opinion.
I would still love to see support for the Map function for analog inputs as i use pressure sensors on my water and air lines and it is hard getting the correct value with simple math functions
Feature request for a counter running in the Arduino, with option to reset from HS and option to define the read-out time (similar to readout of analog input pins). Thank you.
Originally posted by RJS View PostAny plans to add support for the Uno Wifi Rev 2?
Robert
Greig,
Originally posted by Michelob View PostHi everyone,
Is it possible being warned if a plugin update will demand to upload sketches again ? Before to install it, I mean.
Thank you,
Michel
but i think a better option would be for the plugin to still work with the out of date version (it already knows what version the board has so it could just load a translator file or use the settings from that version of the plugin) but say mismatch in the log so you can update it when you have time but i don't know if this would be possible in the code so just an idea at least until the node MCU boards are updated automatically OTA from the plugin:-)
Thank you,
Michel
Sent from my SM-G973F using Tapatalk
Hi everyone,
Thank you,
Michel
Any plans for "sleep" modes in the NodeMCU application. I realize that I can use the NodeMCU API mode, but so far I haven't needed to go that route. The board mode, at least for the NodeMCU, has been able to handle most of what I needed.
