Plugin not working with Etherten
  • Plugin not working with Etherten
    Greig
    I couldnt wait for the W5100 boards to turn up so I paid for an overpriced etherten board to get me going. This board has the W5100 chipset and uses the standard Ethernet library.
    The plugin connects to the board fine and after 2 minutes disconnects and wont reconnect. I've run wireshark, i can see the initial handshake ok and then later 3 successive UDP packets go out from homeseer and no reply from the arduino, it then marks the connection as failed.
    IP stack seems to be running fine as it continues to respond to pings....
    Any ideas ?
    Peter
    HS 2.2.0.11
    Hi Pete,
    Same problem here, can';t get my finger behind it why......
      Originally posted by Redbull View Post
      Hi Pete,
      Can you send me a debug log and tell me your board setup.
      Sent from my HTC One using Tapatalk
      Scripts =
      Various
        Greig,
        See the other topic and posts : http://board.homeseer.com/showthread.php?t=170419
