Error: conversion from string to integer not valid
    I'm getting the following error when the Arduino plugin is enabled.
    Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
    Looks like the error comes up when my Insteon Thermostat is reporting change in humidity.
    Anyone seen this? im not sure yet if its affecting anything.
    Martin
    That is a strange one. Can you send me a debug of this so I can have a look.
    Greig.
    Sent from my HTC One using Tapatalk
    Scripts =
    Various
      Debug log For Homeseer 3 Arduino Plugin By Enigmatheatre (Greig Dempster)
      Debugging Started at = 3/11/2014 ,19:15:05.061
      Arduino Plugin Version = 1.0.0.36
      *************************************Homeseer*************** ****************************
      Homeseer Version = 3.0.0.96
      Homeseer IP = 192.168.0.12
      OS Version = Microsoft Windows 7 Professional
      *************************************Plugins**************** ****************************
      Plug-In List, Arduino Plugin: is currently enabled.
      Plug-In List, HSTouch Server: is currently enabled.
      Plug-In List, Insteon Thermostat: is currently enabled.
      Plug-In List, Insteon: is currently enabled.
      **************************************Setup***************** ****************************
      3/11/2014 ,19:15:05.161 Arduino Devices Arduino Plugin Arduino Board No:1 | Address = Arduino, Board:1 | Ref = 87
      3/11/2014 ,19:15:05.171 Device Ref = 87, api = 0, autoconnect = 1, boardno = 1, comport = 7, index = 1, type = Board,
      3/11/2014 ,19:15:05.171 Arduino Devices Arduino Plugin Motion Sensor | Address = Arduino, Board:1, Input:1 | Ref = 88
      3/11/2014 ,19:15:05.171 Device Ref = 88, boardno = 1, index = 1, key = I, pin = 12, pinkey = I, type = Input,
      3/11/2014 ,19:15:05.171 Arduino Devices Arduino Plugin Light Sensor | Address = Arduino, Board:1, Analog Input:1 | Ref = 89
      3/11/2014 ,19:15:05.171 Device Ref = 89, boardno = 1, index = 1, invert = 0, key = a, pin = A5, pinkey = A, sum = Value*100/1023, time = 150000, type = AnalogIn, unit = ,
      3/11/2014 ,19:15:05.171 Arduino Devices Arduino Plugin LED Pin:13 | Address = Arduino, Board:1, Output:1 | Ref = 90
      3/11/2014 ,19:15:05.171 Device Ref = 90, boardno = 1, index = 1, key = O, pin = 13, pinkey = O, type = Output,
      3/11/2014 ,19:15:05.181 Board: 1 Board index: 87, Comport = 7
      ***************************************LOG****************** ****************************
      3/11/2014 ,19:15:10.471 Sent to com port No:7 = 1 K
      3/11/2014 ,19:15:10.481 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:15:10.671 Data Received:Alive 1
      3/11/2014 ,19:15:40.901 Sent to com port No:7 = 1 K
      3/11/2014 ,19:15:40.901 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:15:41.101 Data Received:Alive 1
      3/11/2014 ,19:16:11.311 Sent to com port No:7 = 1 K
      3/11/2014 ,19:16:11.321 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:16:11.511 Data Received:Alive 1
      3/11/2014 ,19:16:41.731 Sent to com port No:7 = 1 K
      3/11/2014 ,19:16:41.741 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:16:41.931 Data Received:Alive 1
      3/11/2014 ,19:17:12.151 Sent to com port No:7 = 1 K
      3/11/2014 ,19:17:12.161 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:17:12.351 Data Received:Alive 1
      3/11/2014 ,19:17:42.581 Sent to com port No:7 = 1 K
      3/11/2014 ,19:17:42.591 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:17:42.781 Data Received:Alive 1
      3/11/2014 ,19:18:12.991 Sent to com port No:7 = 1 K
      3/11/2014 ,19:18:13.001 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:18:13.201 Data Received:Alive 1
      3/11/2014 ,19:18:43.421 Sent to com port No:7 = 1 K
      3/11/2014 ,19:18:43.421 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:18:43.611 Data Received:Alive 1
      3/11/2014 ,19:19:13.831 Sent to com port No:7 = 1 K
      3/11/2014 ,19:19:13.841 Keeping Board: 1 Comport Alive.
      3/11/2014 ,19:19:14.031 Data Received:Alive 1
      Here is the HS3 log
      Nov-03 7:19:25 PM Arduino Plugin Debuging Disabled
      Nov-03 7:19:25 PM Info 6331 log entries retrieved, and this just added another!
      Nov-03 7:19:18 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:19:15 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:19:14 PM Insteon Thermostat HVAC switching from Heat to Off
      Nov-03 7:19:14 PM Insteon Thermostat Thermostat turning off HEAT
      Nov-03 7:19:14 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:19:13 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:19:12 PM Insteon Thermostat SetHeatSetpoint: Thermostat Heat SetPoint = 68
      Nov-03 7:19:12 PM Device Control Device: Thermostats Insteon Thermostat Heat to (68) by/from: CAPI Control Handler
      Nov-03 7:18:48 PM Insteon Thermostat Thermostat Heat SetPoint = 69
      Nov-03 7:18:48 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:18:45 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:18:44 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:18:44 PM Insteon Thermostat HVAC switching from Off to Heat
      Nov-03 7:18:44 PM Insteon Thermostat Thermostat calling for HEAT
      Nov-03 7:18:43 PM Insteon Thermostat SetHeatSetpoint: Thermostat Heat SetPoint = 70
      Nov-03 7:18:43 PM Device Control Device: Thermostats Insteon Thermostat Heat to (70) by/from: CAPI Control Handler
      Nov-03 7:18:43 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Thermostat" to type 'Integer' is not valid.
      Nov-03 7:18:42 PM Insteon Thermostat SetHeatSetpoint: Thermostat Heat SetPoint = 69
      Nov-03 7:18:42 PM Device Control Device: Thermostats Insteon Thermostat Heat to (69) by/from: CAPI Control Handler
      Nov-03 7:15:05 PM Arduino Plugin Debuging Enabled
        Martin
        Hello,
        Just wondering if there was a solution for this error. I'm currently having the same problem and im not sure what to do or where to start.
        This error shows up every time that the device value updates:
        Apr-02 2:22:57 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Freezer #02" to type 'Integer' is not valid.
        Apr-02 2:22:57 PM Insteon Thermostat Garage Heater Temp = 16
        Apr-02 2:22:57 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Garage Heater" to type 'Integer' is not valid.
        Apr-02 2:22:00 PM Z-Wave Device: Environment Energy Power Meter Lag 2 (Amps EP2) Set to 5.132 (5.132 Amperes Used)
        Apr-02 2:22:00 PM weatherXML Run between 0 23
        Apr-02 2:22:00 PM weatherXML Run timer items
        Apr-02 2:21:59 PM Z-Wave Device: Environment Energy Power Meter Lag 1 (Amps EP1) Set to 14.349 (14.349 Amperes Used)
        Apr-02 2:21:59 PM Z-Wave Device: Environment Energy Power Meter Lag 2 (Volts EP2) Set to 122.395 (122.395 Volts Used)
        Apr-02 2:21:59 PM Z-Wave Device: Environment Energy Power Meter Lag 1 (Volts EP1) Set to 122.395 (122.395 Volts Used)
        Apr-02 2:21:42 PM Z-Wave Device: Environment Energy Power Meter Lag 1 (Watts EP1) Set to 1602.314 (1602.314 Watts Used)
        Apr-02 2:21:31 PM Insteon Thermostat Garage Heater Humidity = 36
        Apr-02 2:21:31 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Conversion from string "Garage Heater" to type 'Integer' is not valid.
        The two devices listed above are Insteon Thermostats. One is the 2441TH Insteon Thermostat and the other one is 2441zTH thermostat.
        Evan G
          Originally posted by Egambell View Post
          Hello,
          Evan G
          Yes there is a fix. Drop me an email and I can send it to you. I want to put it in the beta section of the updater but there is a problem with it but it looks like the HSTeam don't want to fix it at the moment.
          Greig.
          Scripts =
          Various
            Greig.
            Hi - I am getting the same error.
            Any chance I could have the fix?
            Cheers
              Text removed, entered in error !
