Ethernet Conenction Error
  • Ethernet Conenction Error
    I am seeing a connection error a few times a day. With auto reconnect it usually reconnects within a second. Depending on the status of the I/P bits I sometimes see some errors/warning posted by my scripts as the Arduino reconnects.
    This is what I am seeing in the HS log.
    Dec-30 2:59:07 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
    Dec-30 2:59:05 PM Arduino Plugin Updating Values on Board No: 1
    Dec-30 2:59:05 PM Arduino Plugin Updating pins on Board No: 1
    Dec-30 2:59:05 PM Arduino Plugin Connected to Board No:1 at ip address 192.168.0.27 Port No:9000
    Dec-30 2:59:04 PM Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying.
    Dec-30 12:27:47 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
    Dec-30 12:27:45 PM Arduino Plugin Updating Values on Board No: 1
    Dec-30 12:27:45 PM Arduino Plugin Updating pins on Board No: 1
    Dec-30 12:27:45 PM Arduino Plugin Connected to Board No:1 at ip address 192.168.0.27 Port No:9000
    Dec-30 12:27:44 PM Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying.
    Dec-29 11:36:28 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
    Dec-29 11:36:27 PM Arduino Plugin Updating Values on Board No: 1
    Dec-29 11:36:26 PM Arduino Plugin Updating pins on Board No: 1
    Dec-29 11:36:26 PM Arduino Plugin Connected to Board No:1 at ip address 192.168.0.27 Port No:9000
    Dec-29 11:36:25 PM Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying.
    I have attached a debug log.
    Thanks;
    Paul
    Hi Paul,
    Did you get the beta I sent you today? This has lots of changes and the connection routine is one of them. Give it a go and get back to me if you still have problems.
    Greig.
    Scripts =
    Various
