How can I control the Arduino from a HS script?
I would like to set a Digital output on and off.
Do in need to use "CAPI"?
Thanks, Drew
You should just need to set the device value like you would any device. I guess you could use hs.SetDeviceValueByRef(1234, 1, True) where 1234 is the device and 1 is on.
Greig.
Scripts = Various
Yes I have tried "hs.SetDeviceValueByRef(1234, 1, True)" it turns on the device in Homeseer Web Control, but does not set the Arduino pin. If I use the Homeseer Web Control "On" button it will set the Arduino pin.
