Just wondering if there is a way to control the amount of time beyond 5sec for the PWM fade function. I was loolking to see if I can have variable dim setting between 0 to 120 minutes?
This not possible as I am using a library that only supports up to 5sec. You could do this is a HS script to notch the level down 1% over the time you need if you still wan to do it that way.
Greig.
Scripts = Various
