Contacting HomeSeer This Week
See more
See less
Arduino Plugin For Linux (Beta)
This is a sticky topic.
  • Arduino Plugin For Linux (Beta)
    The Arduino Plugin for Linux is in the Beta section of the updater.
    The only connection method supported is Ethernet. This is the only limitation.
    Please leave any comments or problems with this in this thread.
    Greig.
    Scripts =
    Various
    Hi Greg,
    In the beta part of the updater you have version .82 - is it backward compatible ? (and rather stable?)
    and is there a change log I can read before I install?
      Default State when connection errors
      Hi Greg,
      I installed the .84 version and if I understand your active pin correct, it can be used. But would I be possible to also create a "default" value on each digital output pin -and then if "default=active" or something - then arduino sketch would set the output to the default state if connection was lost?
        Will any Ethernet shield work? Is any particular model better than another?
          The standard Wiznet W5100 is the one you are after. The MiNi ENC28J60 will not work as it uses a different library.
          Greig.
          Scripts =
          Various
            Thanks.
            I'm thinking about grabbing one of these
            http://amzn.com/B00AXVX5D0
              Thanks.
              Yep that should do you just fine.
              Greig.
              Scripts =
              Various
                Thanks for the confirmation. I'll be ordering a few more on the slow boat from China, but for now, that and some 1-Wire temperature sensors will get me up and running.
                  Not possible to choose API mode
                  When adding a new board i cannot see an option to make it API mode. Is this mode supported for the Linux version (for my home troller-sel?)
                    Error
                    Installing on a new Linux build. Any idea why I am getting this error?
                    Error downloading file: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure
                      ERROR???
                      Is this a setup issue on my end or on the Homeseer server side?
                      ANYONE???
                        ANYONE???
                        Ok If i remember correct this is a problem on the Linux build of Homeseer. I will see if I can find Thread with the fix and will post it here.
                        Greig.
                        Scripts =
                        Various
                          The problem is that mono does not have any CA certs trusted by default.
                          To get all the CA certs without the hassle of typing yes for each I used the command
                          mozroots --import --sync
                          This should fix it for you.
                          Greig.
                          Scripts =
                          Various
                            Greig.
                            Greig,
                            I am not sure I understand the code, I get either mozroots command not found , or import not understood. This is on a Debian version 8 build. Sorry, as I said in a [previous post i am very green in the linux world.
                              Greig,
                              No problems. I to do not know anything about Linux but converted the plugin to run on a PI.
                              see here for info on your error.
                              I am sorry I can not help you further but someone on the board will help get you going.
                              Greig.
                              Scripts =
                              Various
