Hi,
I'd like to use arduino to send to HS data about electricity power.
I have a system that send a pulse (+5V) every watt.
Using this sketch on serial monitor all is ok:
Created a API board in HS, selected device 1 as IMPUT and loaded the arduino API sketch:
I'm having the error:
Were the translation of "Exception in RecievedText: Riferimento a un oggetto non impostato su un'istanza di oggetto." is "Exception in RecievedText: Object reference not set to an instance of an object."
Where I'm wrong?
This is my last step and then i can switch all my automation on arduino (I/O, PWM, etc. work well).
// Pin impulso const int getpulsepin = 2; // variabili float assorbimento = 0.0; unsigned long startime = 0; unsigned long durata = 0; int stato = 0; int pinval = 0; void setup() { Serial.begin(9600); pinMode(getpulsepin, INPUT); // pin dell'anemometro } void loop () { pinval = digitalRead(getpulsepin); // read sensor pin if ((stato == 0) & (pinval == 1)) { // transition point durata = millis() - startime; // duration pulse startime = millis(); // reset millis startime assorbimento = 3600.0/durata*1000; // Wh } stato = pinval; // Serial.print("assorbimento KW/h = "); Serial.println(assorbimento); }
//For serial set to 0 and for Ethernet set to 1 #define ISIP 0 //Do NOT modify these #if ISIP == 1 #include <EEPROM.h> #include <SPI.h> #include <Ethernet.h> #include <EthernetUdp.h> #endif /************************************************************ *Arduino to Homeseer 3 Plugin API writen by Enigma Theatre.* * V1.0.0.36 * * * *******Change the values below only************************* */ // Pin impulso const int getpulsepin = 2; // variabili float assorbimento = 0.0; unsigned long startime = 0; unsigned long durata = 0; int stato = 0; int pinval = 0; //Address of the board. const byte BoardAdd = 1; #if ISIP == 1 // Enter a MAC address and IP address for your board below. byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // The IP address will be dependent on your local network. IPAddress ip(192,168,0,100); //IP entered in HS config. const unsigned int localPort = 9000; //port entered in HS config. IPAddress HomeseerIP(192,168,0,123); //Homeseer IP address IPAddress ServerIP(EEPROM.read(2),EEPROM.read(3),EEPROM.read(4),EEPROM.read(5)); byte EEpromVersion = EEPROM.read(250); #endif //************Do not change anything in Here***************** int FromHS[10]; // * boolean IsConnected = false; // * #if ISIP == 1 // * char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // * EthernetUDP Udp; // * const unsigned int ServerPort = 8888; // * #endif // * void(* resetFunc) (void) = 0; // * //*********************************************************** void setup() { HSSetup(); //************************ //Add YOUR SETUP HERE; //************************ pinMode(getpulsepin, INPUT); // pin dell'anemometro } void loop() { #if ISIP == 1 IsUDP(); #endif //************************ //Add YOUR CODE HERE; //************************ /* To Send Data to Homeseer use SendToHS(Device,Value) Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes. Eg.. FromHS[5] would be the data from API Output device 5 All code that is located just below this block will execute regardless of connection status! You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue. If you only want code to execute when HomeSeer is connected, put it inside the if statement below. */ pinval = digitalRead(getpulsepin); // legge il pin del sensore if ((stato == 0) & (pinval == 1)) { // punto di transizione durata = millis() - startime; // calcola la durata della pulsazione startime = millis(); // setta il nuovo tempo di partenza assorbimento = 3600.0/durata*1000; // calcola consumo } stato = pinval; // imposta lo stato uguale alla lettura del pin SendToHS(1,assorbimento); /*Execute regardless of connection status*/ if (IsConnected == true) { /*Execute ONLY when HomeSeer is connected*/ } } const char* Version = "API1.0.0.36"; byte Byte1,Byte2,Byte3; int Byte4,Byte5; void HSSetup() { #if ISIP == 1 if (EEpromVersion!=22) { ServerIP=HomeseerIP; EEPROM.write(2,ServerIP[0]); EEPROM.write(3,ServerIP[1]); EEPROM.write(4,ServerIP[2]); EEPROM.write(5,ServerIP[3]); EEPROM.write(250,22); //Store the version where the eeprom data layout was last changed EEpromVersion=22; } Ethernet.begin(mac,ip); Udp.begin(localPort); Udp.setTimeout(0); delay(1000); SendConnect(); #else Serial.begin(115200); Serial.flush(); Serial.setTimeout(0); delay(1000); Serial.print("Connect "); Serial.println(BoardAdd); #endif IsConnected = false; } void SendConnect() { #if ISIP == 0 Serial.print("Connect "); Serial.println(BoardAdd); #else Udp.beginPacket(ServerIP,ServerPort); //First send a connect packet to the dynamic IP stored in eeprom Udp.print("Connect "); Udp.print(BoardAdd); Udp.endPacket(); if (ServerIP!=HomeseerIP) { Udp.beginPacket(HomeseerIP,ServerPort); //Then if the stored value doesn't match the pre-specified one, send a connect packet there also Udp.print("Connect "); Udp.print(BoardAdd); Udp.endPacket(); } #endif } #if ISIP == 1 void IsUDP(){ int packetSize = Udp.parsePacket(); if(packetSize) { IPAddress remote = Udp.remoteIP(); Byte1 =Udp.parseInt(); Udp.read(); Byte2 =Udp.read(); Byte3 =Udp.parseInt(); Byte4 =Udp.parseInt(); Byte5 =Udp.parseInt(); DataEvent(); } } #else void serialEvent() { while (Serial.available() > 0) { delay(17); Byte1 = Serial.parseInt(); Serial.read(); Byte2 = Serial.read(); Byte3 = Serial.parseInt(); Byte4 = Serial.parseInt(); Byte5 = Serial.parseInt(); DataEvent(); } } #endif /* Used Data Input Cases D Disconnect r reset K Keepalive O PinMode Output Set d Input debounce time set C Connect request c Connection established - report current status */ void DataEvent() { if (Byte1 == BoardAdd) { switch (Byte2) { case 'c': IsConnected = true; #if ISIP == 1 if (Udp.remoteIP() != ServerIP) { ServerIP=Udp.remoteIP(); EEPROM.write(2,ServerIP[0]); EEPROM.write(3,ServerIP[1]); EEPROM.write(4,ServerIP[2]); EEPROM.write(5,ServerIP[3]); } #endif break; case 'C': #if ISIP == 1 Udp.beginPacket(Udp.remoteIP(), ServerPort); Udp.print("Version "); Udp.print(BoardAdd); Udp.print(" "); Udp.print(Version); Udp.println(" HS3"); Udp.endPacket(); Udp.beginPacket(Udp.remoteIP(), ServerPort); delay(100); Udp.print("Connected "); Udp.println(BoardAdd); Udp.endPacket(); #else Serial.print("Version "); Serial.print(BoardAdd); Serial.print(" "); Serial.print(Version); Serial.println(" HS3"); delay(100); Serial.print("Connected "); Serial.println(BoardAdd); #endif delay(100); IsConnected = false; break; case 'K': delay(200); #if ISIP == 1 Udp.beginPacket(Udp.remoteIP(), ServerPort); Udp.print("Alive "); Udp.println(BoardAdd); Udp.endPacket(); if (Udp.remoteIP() != ServerIP) { ServerIP=Udp.remoteIP(); EEPROM.write(2,ServerIP[0]); EEPROM.write(3,ServerIP[1]); EEPROM.write(4,ServerIP[2]); EEPROM.write(5,ServerIP[3]); } #else Serial.print("Alive "); Serial.println(BoardAdd); #endif break; case 'r': delay(200); resetFunc(); //call reset break; case 'O': FromHS[Byte3] = Byte4; break; case 'D': IsConnected = false; break; } } } void SendToHS(byte Device, long Data){ if (IsConnected == true) { #if ISIP == 1 Udp.beginPacket(Udp.remoteIP(), ServerPort); Udp.print(BoardAdd); Udp.print(" API "); Udp.print(Device); Udp.print(" "); Udp.print(Data); Udp.endPacket(); #else Serial.print(BoardAdd); Serial.print(" API "); Serial.print(Device); Serial.print(" "); Serial.println(Data); #endif } }
PHP Code:
lug-12 11:50:27 Arduino Plugin Exception in RecievedText: Riferimento a un oggetto non impostato su un'istanza di oggetto.
lug-12 11:50:27 Arduino Plugin Board 1, Device Ref = 4, API Input 1, Value = 0, String = 0Wh
Where I'm wrong?
