Originally posted by completelyhis
View Post
The garage addition will have one Arduino mega tied to 2 man door sensors, 2 window sensors, 5 garage door sensors, 1 RGB led strip, 4 garage door openers and 3 PIR sensors. The setup in the house is so I could learn the basics and be ready once the garage addition is completed. So I have learned the basics, interfacing a push button (door sensor mockup), control a RGB led strip, control relays (garage door opener connection) and the PIR sensors as how it would be interfaced in the garage.
I have had issues with previous Arduino projects having the PS voltage dip due to a heavy load or even turning on a relay(s), so I went with a cheap 350w computer power supply. Super common and can put out a good chunk of power. The garage stuff will be fairly low loads, but the house I plan on running quite a few heavy load RGB LED strips...and to keep setups identical I am running the same PS for both. I also have a few kicking around so a power supply failure will be an easy quick fix.
The Arduino has a 5v and ground connection to the power supply. 12v and 5v sensor power running to the PIR sensor (on a breadboard for now), for a final setup I will be soldering up a board with terminal blocks to attach the wiring. The wiring is explained in post #9. Also in the plugin you create the specific pin ou are connecting the PIR sensor to as an analog pin, then set up the status graphics as shown in post #9.
You can run the sensor digitally as well, doesn't require the use of resistors and is faster to set up. I just wanted my setup to be similar to commercial alarm system and having the EOL is one part of it, also as I previously mentioned I won't have much for analog inputs so using them for the PIR is perfect as it uses less overall pins and allows me greater visibility to the status of the sensor.
